Old April 23rd, 2012, 01:49 PM   #121
2.1 seconds.
Old April 23rd, 2012, 01:59 PM   #122
akima
Nooblet
akima's Avatar
MOTM - Oct '13
^ lies
Old April 23rd, 2012, 02:24 PM   #123
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
21 seconds? U suck the cack
AFM #676
Supersports are for n00bs
Old April 23rd, 2012, 03:12 PM   #124
Felipe the Ant
Motorcycle(s): 2011 Ninja 250R SE GREEN!
Hmm...
Trust me, I'm a banana!
Felipe the Ant is offline   Reply With Quote
Old April 23rd, 2012, 03:40 PM   #125
i suck this cac:
Old April 23rd, 2012, 05:25 PM   #126
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Hmm I wouldn't no suckin that cac
AFM #676
Old April 24th, 2012, 05:47 PM   #127
Miles_Prower
One Loyal Fox
Miles_Prower's Avatar
Motorcycle(s): 2012 Ninja 250R (RIP), 2011 ZX-6R
so i was trying to accelerate quickly on my ride today..and I could speed up pretty well after third gear or so but, what's the gearing technique? do you run 1st gear up pretty high then start shifting or do you get to a certain gear before cranking it??
Miles_Prower is offline   Reply With Quote
Old April 24th, 2012, 06:51 PM   #128
Watch the video in the first post.
The trick is the launch, then just **** gears at about 13,000 rpm until you get to 60mph actual speed.
Old April 24th, 2012, 08:37 PM   #129
Miles_Prower
One Loyal Fox
ok great..i havent broken my bike in completely yet, just wanted to know how to get off the line quicker..my starts are soooo slow and i feel like im holding up traffic lol
Old April 24th, 2012, 08:43 PM   #130
give it more gas. a normal start off the line from 3k is perfectly fine
Old April 25th, 2012, 05:18 AM   #131
Miles_Prower
One Loyal Fox
i guess i'm just not used to revving the thing yet. i think that 4k is high lol but I guess i'll get used to the fact that it's really low on these bikes.
Old April 25th, 2012, 07:11 AM   #132
yeah 4k is nothing
Old April 25th, 2012, 06:39 PM   #133
zzrguy
zzrguy's Avatar
Motorcycle(s): 2002 ZZR 250
I pulled a flat 7 today, watch the video its the second run. my speedo is in km/h so when it hits 100 thats 0-60
I think i could pull faster once i get my jetting right. I need way less gas it bogs down when im below 8k
http://www.youtube.com/watch?v=XNkKVhEMMRg
zzrguy is offline   Reply With Quote
Old April 25th, 2012, 08:03 PM   #134
n4mwd
n4mwd's Avatar
I rebuilt my carbs today, but I think I made my 0-60 times worse. I'm not super clear on the best approach to set the mixture screws. It had a lot of extra hang time until I rode it around a while.
My Ninja Blog
Old April 25th, 2012, 08:05 PM   #135
Felipe the Ant
too lean
Old April 25th, 2012, 08:46 PM   #136
Originally Posted by Felipe the Ant View Post
too lean
+1. turn them out 1/4 and see if it's better.
Old April 26th, 2012, 04:39 AM   #137
n4mwd
n4mwd's Avatar
When I rebuilt it, it still had the factory plugs in the mixture screw holes, but one carb had its mixture needle much farther into the venturi. To complicate things, I changed them out to new mixture screws, springs and seats - so the settings wont be identical.
I did find that the main jet on one side and the pilot jet on the other was partially blocked, so it wasn't a total waste of time. However, the idling is still unsteady. The idle on my friend's Ninja is rock solid which is what tipped me off.
I'm going riding today so we'll see if it works itself out. I think I'm going to ride for a few days before I play with the screws again.
My Ninja Blog
Old April 26th, 2012, 06:13 AM   #138
Felipe the Ant
You could be out of sync too
Old April 26th, 2012, 06:42 AM   #139
set them both to 2.5 turns out. test by blipping once the bike is fully warm.
Old April 29th, 2012, 02:59 PM   #140
gadgit0
gadgit0's Avatar
Motorcycle(s): 1971 Honda CB450, 2012 Ninja 250
ok ran out and gave it a try for my 0-60 using my speedview app on my droid x.. my times were 9.1 with a 4-6k launch and 9.0 with a 6-8k launch.. its a sunny 61 out today and with me being a bigger guy i wasn't expecting it to be real fast times. sry no video i can try again in the next couple days. going to be super nice out and ill take video or both the app and my speedo.
2012 Candy Lime Green, 15/45 setup, shimmed needles, solo seat cowl, chopped rear fender, green leds
gadgit0 is offline   Reply With Quote
Old April 29th, 2012, 06:51 PM   #141
n4mwd
n4mwd's Avatar
Sounds like that 15:42 ratio is hurting your times.
My Ninja Blog
Old April 29th, 2012, 07:01 PM   #142
n4mwd
n4mwd's Avatar
It has a rough feel when it idles warm. When its cold it slowly dies down until it stalls. I have to use the choke or else it will stall when cold. When on the choke it sounds really crappy. The carbs are synced perfectly. I'm probably going to do the valves again in a month or two. I'll check to see if they have an issue.
I haven't done any new 0-60 runs since I rebuilt the carbs, but there isn't any noticeable performance loss.
My Ninja Blog
Old April 29th, 2012, 07:15 PM   #143
have you tried playing with the idle mix when it's warm? 2.5 turns is just a starting place.
Old April 29th, 2012, 07:22 PM   #144
n4mwd
n4mwd's Avatar
Yes. I got it better, but not right.
My Ninja Blog
Old April 30th, 2012, 06:48 AM   #145
gadgit0
gadgit0's Avatar
i went to 15/42 cause i didnt like the high rpms on the stock 14/45.. but oh well im not racing on it
Old May 2nd, 2012, 04:44 PM   #146
n4mwd
n4mwd's Avatar
Carb Problems
Rather than continuing to hijack your thread, I started a new one.
http://www.ninjette.org/forums/showt...540#post488540
My Ninja Blog
Old May 2nd, 2012, 06:10 PM   #147
Appreciated
bump on any more 0-60 videos!
Old May 2nd, 2012, 06:12 PM   #148
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I'm going to go make a video of me going 0-60 in my wheel chair
AFM #676
Old May 2nd, 2012, 06:13 PM   #149
Freefall or giant hill?
Old May 2nd, 2012, 06:14 PM   #150
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Just going to use my one mandick of power. It will be 0-60(cm/s)
AFM #676
Old May 2nd, 2012, 06:16 PM   #151
Old May 12th, 2012, 06:55 AM   #152
akima
Nooblet
akima's Avatar
MOTM - Oct '13
I haven't tried 0-60 yet, but a while ago I said I'd try for 100mph. Last weekend I made it! I had to tuck down, but she got there. The tach needle was just touching redline (13k). I was on a flat road when I did it with low wind that day.
Old May 12th, 2012, 01:14 PM   #153
nice @akima!
I just installed my Muzzy pipe and re-jetted. All I can say is wow what a difference! I really didn't think it would be so huge of a change from my slip-ons, but it really is! I'll try and get some more 0-60 tries tomorrow, and then again once I get my efi kit and it's all installed in a few weeks...
Old May 12th, 2012, 02:03 PM   #154
Stingray1000
Stingray1000's Avatar
Motorcycle(s): 2003 Kawasaki Ninja 250R
Interesting.... I hit 105 the other day and my needle was 1/8th of an inch away from red....... Why is my 250 possibly faster then your 250??? LOL
http://www.facebook.com/groups/DeMdNjPagrouprides/
I live my life a quarter mile at a time!
Who is affraid of the big bad jiggles???? LOL
Stingray1000 is offline   Reply With Quote
Old May 12th, 2012, 02:05 PM   #155
Stingray1000
Hope you don't have to choke it to get it started.... LOL
Old May 12th, 2012, 02:17 PM   #156
Jiggles
Jiggles's Avatar
MOTM - Apr '13
That was good haha
AFM #676
Old May 12th, 2012, 05:52 PM   #157
n4mwd
n4mwd's Avatar
Video or it didn't happen!
My Ninja Blog
Old May 12th, 2012, 11:42 PM   #158
akima
Nooblet
akima's Avatar
MOTM - Oct '13
From what people have already said on this forum, I already assumed the pre-2008 ninjettes have a higher top speed.
If that's not the case, the only thing I can think of is that your bike isn't faster, but your speedo is less accurate. I think the FI 2008+ ninjettes use a different (possibly more accurate) way of measuring speed.
Old May 13th, 2012, 12:43 AM   #159
Jiggles
Jiggles's Avatar
MOTM - Apr '13
The pregen 250s have a massive speedo error. From what people have reported, it looks like they got more accurate on the 2011 models
AFM #676
Old May 13th, 2012, 01:09 AM   #160
i just got the 13t front... can i still put a time in
2012 TTP Racing 250 Challenge TTPRacing Ninjettes At Speed 37 August 1st, 2012 09:19 PM
AFM Round 4 @ Sonoma Raceway FLAP 250 Challenge KazMan Videos 2 July 9th, 2012 12:18 PM
[faster and faster] - KTM announces M32 engine for Moto3, sports 250 streetbike to fo Ninjette Newsbot General Motorcycling Discussion 4 October 8th, 2011 08:23 AM
[faster and faster] - Scomadi Turismo Leggera 250 runs wild… Ninjette Newsbot Motorcycling News 0 March 24th, 2010 09:30 PM
[faster and faster] - Suzuki Gemma 250 goes on sale in Japan Ninjette Newsbot Motorcycling News 0 July 2nd, 2008 12:00 PM
