Go Back   ninjette.org > General > Videos
Old October 16th, 2012, 11:59 AM   #41
Kokosun
Are you sure about that?
Name: That's "Sir" to you!
Motorcycle(s): Ninja 250R-F16, Versys KLE650 CAF
Originally Posted by Malicious Logic View Post
Not sure what this Paraffin/kerosene stuff you're talking about is. Is this O-ring safe or just random chemicals? o.O I personally use the DuPont chain degreaser along with their cleaning brush and it looks fine to me. I'm sure my standard of a clean chain may be different than others though.
Kerosene (US term) is paraffin (UK term). It's what most motorcycle manufacturers recommend to clean chains.
Kokosun is offline   Reply With Quote
Old October 16th, 2012, 12:02 PM   #42
Malicious Logic
hates stupid people
Malicious Logic's Avatar
Motorcycle(s): 2005 ZX6R
Ah, ok. Definitely going to have to try that after seeing some of the results other people are getting from it.
My vlogging channel: Ma1iciousLogic
Malicious Logic is offline   Reply With Quote
Old October 16th, 2012, 12:46 PM   #43
Kokosun
I just checked the service manual. It say's:
CAUTION
- The o-rings between the side plates seal in the lubricant between the pin and the bushing. To avoid damaging the o-rings and resultant loss of lubricant, observe the following rules.
- Use only kerosene or diesel oil for cleaning an o-ring drive chain. Other cleaning solution such as gasoline or trichloroethylene will cause deterioration and swelling of the o-rings.
- Immediately blow the chain dry with compressed air after cleaning.
- Complete cleaning and drying the chain within 10 minutes.
It goes on to say:
- Apply oil [aka lube] to the sides of the rollers so that oil will penetrate to the rollers and bushings. Apply the oil to the o-rings so that the o-rings will be coated with oil.
- Wipe off any excess oil
But, I think that most of the commercial chain cleaning fluids are pretty safe, and there are lots of people that really like them. I don't think that they're as good as kerosene and elbow grease - and they are definitely a lot more expensive.
Old October 16th, 2012, 01:14 PM   #44
Malicious Logic
hates stupid people
Yeah, I definitely may give it a try if it's cheaper than the commercial cleaning fluids. I really wanna remove my chain guard and the front sprocket cover and really give it a good, thorough cleaning so if Kerosene works better, it'd make sense to use it.
Found something odd in my short research though. This link shows using kerosene and seems to say that WD-40 is a bad cleaning agent but the study they link here actually shows the opposite....that WD-40 doesn't appear to have a negative effect on the o-rings....*shrugs* Just something I thought I'd add to the pool of knowledge that is this thread.
Old October 16th, 2012, 02:08 PM   #45
Kokosun
I think that one of the main ingredients of WD-40 is kerosene, so I doubt that it's really bad. Lots of people use it, and it doesn't seem to have any really bad effect. Personally, I love WD-40. It's like a miracle substance. But it's much more expensive than POK (plain old kerosene).
Old October 16th, 2012, 04:25 PM   #46
Malicious Logic
hates stupid people
Part II here shows that it ends up reducing the strength of the O-ring in a long term environment.
Old October 16th, 2012, 04:57 PM   #47
http://en.wikipedia.org/wiki/Kerosene
It's just fine for cleaning anything that needs to be de-greased like chains, bearings, etc. Just make sure all the Kerosene has evaporated before you go re-lube, or else all your brand new lube not stay put.
EDIT: oops, you guys already covered that... But I will note that somewhere on here, I read that WD40 is not bad for the o-rings, it's the stuff in the can for pressurization that's harmful to o-rings
Old July 24th, 2013, 10:45 AM   #48
ally99
Ninja chick
ally99's Avatar
Motorcycle(s): '13 Ninja 300
MOTM - Dec '13, Feb '15
Awesome video, great thread! I love ninjette.org!
Postwhores are COOL! ~Allyson
How often should you clean/lube chain? clintalmighty 2008 - 2012 Ninja 250R Tech Talk 11 January 8th, 2011 03:22 PM
Clean and lube chain Help! BlueRaven 2008 - 2012 Ninja 250R Tech Talk 18 June 20th, 2010 07:10 PM
[visordown.com] - Free Silkolene chain clean and lube at Cadwell Ninjette Newsbot Motorcycling News 0 June 9th, 2010 11:40 AM
Clean chain & lube interval randomwalk101 2008 - 2012 Ninja 250R Tech Talk 3 July 20th, 2009 10:18 PM
[webbikeworld.com] - DuPont Chain Saver Motorcycle Chain Lube Review Ninjette Newsbot Motorcycling News 0 May 18th, 2009 09:50 PM
