September 19th, 2011, 06:05 PM | #1 |
Motorcycle repair
Join Date: Sep 2011 Motorcycle(s): '05 Ninja ZX6-RR, '08 GY6 scooter for wife, '02 Shadow ACE, '05 Buell Blast Posts: 28
The importance of synchronizing carbs
I did this writeup on another forum and thought some people here might benefit from it as I explain what synchronizing(synching) is, and why it's important to synch your carburetors/throttle bodys, and most importantly the benefits like better gas mileage. Feel free to post any questions.
Here's the link: http://www.twtex.com/forums/showthre...+synchronizing
"You can't know where you're going until you know where you've been" www.monkeywrenchmotorcycles.com |
September 19th, 2011, 06:25 PM | #2 | |
Jigglin' your Jiglets
MOTM - Apr '13
September 19th, 2011, 06:27 PM | #3 |
Motorcycle repair
Thanks. I'm at home on the iPad and can't copy/paste paragraphs.
September 19th, 2011, 06:32 PM | #4 |
MOTM - Apr '13
Tap and hold part of the paragraph, the press select all, then copy, and then paste
September 19th, 2011, 07:52 PM | #5 |
Thanks for the paste Sean.
September 19th, 2011, 08:09 PM | #6 |
Yoshi
Join Date: Jan 2011 Motorcycle(s): 11 Ninja 250 Posts: 63
How often/miles you recommend to sync the carbs?
Non synch carbs possibly cause the engine to slightly rev at times? Barely noticeable on the rpm gauge but audibly noticeable. |
September 19th, 2011, 08:20 PM | #7 | |
Motorcycle repair
It definitely needs set after any carb work or when the valve adjustment is done as either will change the synchronization. If they are out it can cause erratic idle as you are essentially opening one carb more than the other and thus putting more fuel in one cylinder.
September 19th, 2011, 08:27 PM | #8 |
Yoshi
Ty sir.
October 9th, 2011, 02:48 AM | #9 |
I'm positive that mine are out of sync.
October 9th, 2011, 04:11 AM | #10 |
User Title Free Since '12
Join Date: Dec 2010 Motorcycle(s): '10 Ninja 250R Special Edition Green Posts: A lot.
MOTM - Feb '12
If this has motivated anyone to synch their carbs, the DIY can be found here.
"Improvement makes straight roads, but the crooked roads without improvement, are roads of genius." — William Blake |
January 12th, 2012, 04:46 AM | #11 |
Join Date: Dec 2011 Motorcycle(s): 2011 Kawasaki Ninja 250R Posts: 23
I'm new at this. When synchronizing the carbs, do I need to remove / release the throttle cables? or just leave it as it is and balance the carbs directly using the screw in the middle?
January 12th, 2012, 05:57 AM | #12 |
Make sure the bike is warmed up and idle is adjusted properly before you start. Leave the throttle cables attached. They play no part in it as there shouldn't be any tension on them at idle.
Ç¥ñ頻| ßÿ Ñâ7µ®é. Äñt¡~§º¢Ïä| ßý Çhøî©è. |
January 12th, 2012, 08:36 AM | #13 | |
Motorcycle repair
I always start with the basics. First i replace spark plugs, then check valve adjustment, then synch carbs. That way your covering all the major bases and your not doing double the work. There are many good writeups on doing valve adjustments and carb synchs.
January 13th, 2012, 10:14 PM | #14 |
Milkshake Drinker
Join Date: Aug 2011 Motorcycle(s): 2007 Orange DRZ400-S, 2005 Ninja 250 & Custom Thundercunt Dirt Chopper Posts: A lot.
I've got to agree...it is kind of important...here are my plugs...
"What a sweetheart."- ninja_sleeper to me |
January 15th, 2012, 11:34 PM | #15 |
So the one is running lean and the other is running rich?
January 18th, 2012, 10:07 PM | #16 |
Milkshake Drinker
Yeah...well, one is running VERY rich, and one is running EXTREMELY lean.
January 19th, 2012, 08:10 AM | #17 |
1/4 English, 3/4 Kick Ass
Join Date: Sep 2011 Motorcycle(s): 2002 Triumph Speed Triple 955i, '05 Suzuki SV650S(retired), '11 Ninja 250R(sold) Posts: A lot.
January 19th, 2012, 11:01 PM | #18 |
Milkshake Drinker
it's an 06 with 25,000, but this was taken after a ride where I lost an exhaust gasket--you'd never have this kind of discrepancy in normal conditions.
January 20th, 2012, 06:04 AM | #19 |
[hell for leather] - The Importance Of Talking To Yourself | Ninjette Newsbot | Motorcycling News | 0 | July 23rd, 2013 09:40 PM |
Alex's silly pet peeve of no importance... :-) | Alex | Forum Information | 57 | April 15th, 2013 09:14 AM |
The importance of paying attention. | csmith12 | Riding Skills | 29 | November 23rd, 2012 06:23 PM |
got a new toy...and learned the importance of gear... | welcome2thedawn | General Motorcycling Discussion | 23 | September 22nd, 2010 12:20 PM |
The Importance of Safety Gear | kazam58 | Off-Topic | 8 | March 12th, 2009 09:29 PM |
