Old June 25th, 2016, 01:21 PM   #1
Macharity
Pothole damaged my bike...
Hey you guys, I've got some bad news. Earlier today I made the trip up to Skyline Drive about 2.5 hours away to do some riding..had a blast! Unfortunately after leaving, and less than 5 minutes away from my house I hit a pothole followed by a large scratching/rubbing noise from the rear of my bike.
Somehow the pothole caused my fender eliminator to get knocked loose and get caught on my NEW rear wheel, causing multiple large scratches into the tire. Not to mention the brake light fell out because somehow the bump must have snapped the connecting wires
As if it couldnt be worse this is the second time this has happened. On Saturday I was out for a casual ride when suddenly the fender eliminator fell out when i braked to take a highway exit. Figuring this was due to the previous owner improperly installing the fender, i simply ordered a new piece and had it overnighted so i would have it for my ride today. So I installed the piece Friday night and went for an hour long ride to make sure everything was installed correctly. Then this morning i recheck everything before heading out and for 5 hours of riding everything is fine.
Riding is not a solo act, it takes two. You need to listen to the bike, as much as, you need the bike to listen to you!
Macharity is offline   Reply With Quote
Old June 25th, 2016, 01:27 PM   #2
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Ouch! What brand is the FE? Unless it was really installed incorrectly, it's hard to imagine how it would just come loose along with the rear/brake light.
These two items are held in place by a few nuts and bolts. Unless all of them got loose, I don't see how it would just fall off from something hitting it.
Riding it like I financed it.
Old June 25th, 2016, 01:50 PM   #3
Macharity
Its a Hotbodies eliminator. I have no clue either about how this happened, considering theres not much but two bolts that connect everything. I'm probably going to go through everything on the bike while I wait for all these parts to come in. I figure im looking at, at least 300$ to get everything fixed
Old June 26th, 2016, 08:21 AM   #4
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
Blue Loctite is your friend. Put it on anything that doesn't need to come apart regularly (and maybe even a few things that do).
I am surprised that it would happen twice, after you specifically checked on it too. It seems like there's got to be something (vibration?) working the bolts loose. Loctite should keep them from vibrating loose, but I'd want to find the root cause of why it happened.
Old June 26th, 2016, 09:16 AM   #5
HoneyBadgerRy
HoneyBadgerRy's Avatar
If I'm not mistaken, blue is for stuff that comes apart regularly, green is for stuff that rarely comes off, and red is for break rotor and sprockets bolts, etc that you do not want coming off at all. (Even though you change sprockets often enough)
Old June 26th, 2016, 10:16 AM   #6
InvisiBill
InvisiBill's Avatar
I've only used blue and red. I generally consider red to be "permanent" and blue to be temporary. http://www.us.henkel-adhesives-blog....Threadlockers/ has some info about the different formulas.
An appropriate threadlocker of some type should keep the bolts from coming loose. But I'm still curious about why they're coming loose in the first place. Back ends falling off isn't really a common thing around here.
Old June 26th, 2016, 04:07 PM   #7
HoneyBadgerRy
I am about the same, I generally used green if I had problems with something vibrating loose, and red if I wanted it to be permanently adhered with the small chance of disassembly. After reading this, I am likely to switch over from green to blue. Thanks for the link.
I'd bet that its not assembled right, or something is striped out. There should be no reason for it to just fail. Then again, I have no idea what wrong with my bike.
[motorcycle.com] - If my motorcycle is badly damaged after hitting a pothole in the r Ninjette Newsbot Motorcycling News 0 July 16th, 2013 08:20 PM
My valves had no clearance--have I damaged my bike? AlanDog 1986 - 2007 Ninja 250R Tech Talk 4 March 31st, 2012 11:05 PM
My brand new bike baby damaged TxriderMike !%@*#$%!)@#&!%@ I crashed! 32 October 4th, 2011 12:04 AM
Good deal on damaged bike newTo_riding General Motorcycling Discussion 8 May 15th, 2011 03:29 PM
Dropped the bike again due to pothole jorgecornet !%@*#$%!)@#&!%@ I crashed! 13 May 21st, 2010 02:56 PM
