September 6th, 2017, 09:10 AM | #1 |
[motorcycle.com] - 2018 Yamaha Star Eluder Bagger Revealed
As we predicted, Yamaha revealed a new touring model based on its new Star Venture called the “Star Eluder.” Essentially a Star Venture without the trunk and a smaller windscreen, the Star Eluder also lacks some of the Venture’s more luxury features, bringing it in at a lower price point at $22,499, with a GT Option package bumping the price to $23,999 (the Star Venture starts at $24,999 with a Transcontinental Option package adding another $2,000 to the sticker). The 2018 Yamaha Eluder shares much in common with the Star Venture, including the same air-cooled 1854cc V-Twin engine and six-speed transmission. A ride-by-wire throttle control system offers two modes, touring and sport, delivering power via belt to the rear wheel. Traction control comes standard, as does cruise control which is to be expected on a touring model. The chassis is also the same, with a main steel frame paired with an aluminum diecast subframe. Up front, a 46mm telescopic fork offers 5.1 inches of travel while a remote preload-adjustable rear shock with 4.3 inches of travel is used at the rear. Dual front calipers grasp 298mm discs while a single 320mm disc is equipped on the rear wheel. ABS is standard, as is Yamaha’s Unified Brake System which dynamically balances front and rear brake pressure for a linear feel. The Star Eluder comes with a 7-inch LCD infotainment system that is controlled by a touch screen, handlebar controls or voice commands over a connected Bluetooth device. The Eluder also boasts a radio package that can also stream music via Pandora from a smart phone. What it lacks, however, is the Star Venture’s rear speakers. Other standard features include a smart key system, USB ports and a 12V outlet. The GT Option package adds GPS navigation, satellite radio, CB radio and a security alarm. Beyond loosing the trunk and passenger backrest, the Eluder also lacks some of the Star Venture’s other luxuries including: the reverse-drive Sure-Park system, grip heaters, electronically-adjustable windscreen, tire pressure monitor and fog lights. The Star Eluder does have a weight advantage, with Yamaha claiming a wet weight of relatively svelte 875 pounds (877 pounds with the GT Option) compared to 957 pounds for the Star Venture. “We are very excited to introduce the Star Eluder as we further expand our transcontinental touring motorcycle line-up,” says Mike Doughty, general manager of Yamaha’s motorcycle group. “With its aggressive styling and infotainment technology unlike any other motorcycle in its class, it will truly empower riders to elude conformity while experiencing the thrill of the road.” The 2018 Yamaha Star Eluder will be offered in three color options: Impact Blue, Raven and Liquid Silver. Specifications 2018 Yamaha Star Eluder 2018 Yamaha Star Venture MSRP $23,999 – Impact Blue – GT Option Package – Availability TBD $22,499 – Impact Blue – Availability TBD $23,999 – Raven – GT Option Package – Availability TBD $22,499 – Raven – Availability TBD $23,999 – Liquid Silver – GT Option Package – Availability TBD $22,499 – Liquid Silver – Availability TBD $26,999 – Granite Gray – Transcontinental Option Package – Available from December 2017 $24,999 – Granite Gray – Available from December 2017 $26,999 – Raspberry Metallic – Transcontinental Option Package – Available from December 2017 $24,999 – Raspberry Metallic – Available from December 2017 Engine Type 113-cubic-inch (1854cc) air-cooled OHV V-twin; 8 valves 113-cubic-inch (1854cc) air-cooled OHV V-twin; 8 valves Bore x Stroke 100.0mm x 118.0mm 100.0mm x 118.0mm Compression Ratio 9.5:1 9.5:1 Fuel Delivery Yamaha Fuel Injection with YCC-T and D-Mode Yamaha Fuel Injection with YCC-T and D-Mode Ignition TCI: Transistor Controlled Ignition TCI: Transistor Controlled Ignition Transmission 6-speed; multiplate assist and slipper wet clutch 6-speed; multiplate assist and slipper wet clutch Final Drive Belt Belt Front Suspension 46mm telescopic fork; 5.1-in travel 46mm telescopic fork; 5.1-in travel Rear Suspension Single shock with remote preload adjustment; 4.3-in travel Single shock with remote preload adjustment; 4.3-in travel Front Brakes Dual hydraulic disc, 298mm; Unified Brake System and ABS Dual hydraulic disc, 298mm; Unified Brake System and ABS Rear Brakes Hydraulic disc, 320mm; Unified Brake System and ABS Hydraulic disc, 320mm; Unified Brake System and ABS Front Tires 130/70R18 Bridgestone Exedra 130/70R18 Bridgestone Exedra Rear Tires 200/55R16 Bridgestone Exedra 200/55R16 Bridgestone Exedra L x W x H 98.0 in x 38.4 in x 55.5 – 50.2 in 106.3 in x 39.9 in x 55.5 – 59.1 in Seat Height 27.4 in 27.4 in Wheelbase 67.6 in 67.6 in Rake (Caster Angle) 31.0° 31.0° Trail 5.7 in 5.7 in Maximum Ground Clearance 5.5 in 5.5 in Fuel Capacity 6.6 gal 6.6 gal Fuel Economy 34.0 mpg 34.0 mpg Wet Weight Star Eluder / Star Eluder GT 875 lb / 877 lb Star Venture / Star Venture Transcontinental 957 lb / 963 lb Warranty 5 Year Warranty Coverage* (*1 year limited factory warranty + 4 years Yamaha Extended Service = 5 years coverage.) 5 Year Warranty Coverage* (*1 year limited factory warranty + 4 years Yamaha Extended Service = 5 years coverage.) 2018 Yamaha Star Eluder Bagger Revealed appeared first on Motorcycle.com. Click here for full story...
[RideApart] - Yamaha Says No 2018 Star Venture Until Christmas | Ninjette Newsbot | Motorcycling News | 0 | September 5th, 2017 04:40 PM |
[motorcycle.com] - 2018 Yamaha Star Venture First Ride | Ninjette Newsbot | Motorcycling News | 0 | July 18th, 2017 03:40 PM |
[motorcyclistonline] - First Ride Review: 2018 Yamaha Star Venture | Ninjette Newsbot | Motorcycling News | 0 | July 17th, 2017 11:30 AM |
[motorcycle.com] - 2018 Yamaha Star Venture Revealed | Ninjette Newsbot | Motorcycling News | 0 | June 5th, 2017 05:00 PM |
[motorcyclistonline] - First Look: 2018 Yamaha Star Venture | Ninjette Newsbot | Motorcycling News | 0 | June 5th, 2017 05:00 PM |
