Old January 8th, 2019, 10:10 AM   #1
CoffinBuilder38
Motorcycle(s): 2011 Ninja 250EX
Question Exhaust slip-on fit?
Hi I'm new to this thread, so if this is in the wrong place forgive my ignorance.
I'm trying to buy a slip-on exhaust but can't find the size I need anywhere. Do I need 38mm? 51mm? I want to buy the right size to avoid any welding, because that would defeat the purpose for me. Any help would be appreciated.
CoffinBuilder38 is offline   Reply With Quote
Old January 8th, 2019, 10:46 AM   #2
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
you need something like this. el cheapo mufflers from Ali Express come with this adapter. this is sold buy itself
by the way welcome
"trying not to get old"
Old January 8th, 2019, 10:49 AM   #3
maverick9611
MOTM - Feb '18
check out my el cheapo exhaust threads. might save some cash.
Old January 8th, 2019, 12:42 PM   #4
Factory exhaust is 35mm OD where factory muffler slips on. Factory pipe is offset and angled from muffler; you'll notice inlet of muffer is angled and offset to match.
Option-1 Cone Adapter - Tip of cone-adapter is slightly large for factory exhaust (38mm). Shim with couple layers of soda/beer can. Due to offset of factory pipe, it will bring muffler very close to swingarm if it's an oval canister. Round mufflers will hit swingarm if used with cone-adapter.
Option-2 Angled adapter - this adapter does not need shimming to fit factory pipe. Its angled outlet will let you use any muffler with centre inlet.
Last futzed with by DannoXYZ; January 8th, 2019 at 02:57 PM.
Old January 9th, 2019, 11:15 AM   #5
Ceeloo Yello
Motorcycle(s): 250
Good info here.
Old January 9th, 2019, 05:16 PM   #6
CoffinBuilder38
Awesome that's exactly what I needed! Thanks y'all!!
Old January 9th, 2019, 06:34 PM   #7
maverick9611
MOTM - Feb '18
great, introduce yourself and your ride.
How to remove stock exhaust and install aftermarket Slip-On Exhaust System Ninja 300 SON1C 2013 - 2017 Ninja 300 Tech Talk 4 August 14th, 2014 05:45 PM
slip-on exhaust KVR 2008 - 2012 Ninja 250R Tech Talk 2 April 11th, 2009 07:40 PM
