Old January 29th, 2019, 01:00 PM   #1
Whitedogpoo
Motorcycle(s): Ninja 400 / CBR600
Intermittent tail light issue
My tail/rear light keeps going out for around 5-10 seconds when I first start my 2009 Ninja 250R, then comes back on again... then it'll go out, then on, then out, then on... cycles through this a few times, then seems to stay on!
When it's off, the brake light still works fine whilst using either front or back brake, and it seems fine once it's done it's on/off bit for a while. Wiring looks fine, can't see anything loose, could it just be the bulb? Going to replace this at the weekend just in case - anybody know the correct bulb I need to get in the UK?
Light seems fine once the bikes been running for a few minutes and doesn't always go off either when I first start it up.
Just wondering if anyone else has had this issue?
Whitedogpoo is offline   Reply With Quote
Old January 29th, 2019, 03:41 PM   #2
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
My first guess is that the filament in the bulb is broken, the vibrations of the engine running makes it bonce around and make and break contact, new bulb would fix that. Could also be a dirty connection in the bulb socket and or on the bulb. Maybe a weak spring in the socket, or a poor connection were the wire from the socket plugs into the wiring harness.
Old January 29th, 2019, 09:47 PM   #3
Electricity is not shallow! It doesn't care about looks! If I had nickel every time I heard fuse "looks good"!!!
You've got an intermittent disconnection. We need to track that down. Pull out multimeter and measure:
- bulb resistance, shake bulb around and re-measure
- voltage at bulb-socket with key ON (have assistant shake harness wires)
- voltage at harness connector with key ON (have assistant shake harness wires upstream of connector)
Last futzed with by DannoXYZ; January 30th, 2019 at 09:09 AM.
Old February 1st, 2019, 12:48 PM   #4
Whitedogpoo
Strangely, since posting this thread, it’s been fine and I haven’t touched it! Going on the theory of ‘If it ain’t broke, don’t fix it’ I think I’ll just keep an eye on it until it happens again!
Intermittent FI Light + stalling FluxX 2008 - 2012 Ninja 250R Tech Talk 16 November 14th, 2018 04:47 PM
Tach light intermittent but mostly off. Plus battery question Cep 2008 - 2012 Ninja 250R Tech Talk 5 July 3rd, 2018 05:24 PM
Sequential LED Tail Light small issue ez12a 2008 - 2012 Ninja 250R Tech Talk 7 April 5th, 2015 05:46 PM
Oh No, not another LED tail light issue...please see video ryker 2008 - 2012 Ninja 250R Farkles 1 April 4th, 2015 03:31 PM
Just noticed a slight issue with my tail light, need some advice. beta7 2008 - 2012 Ninja 250R Tech Talk 7 July 9th, 2013 06:43 PM
