Old February 17th, 2019, 10:47 AM   #1
Greenlawnracing
Motorcycle(s): Ninja 250, SV 650
Bike sat for two years.....
Super mad at myself for doing this twice....
Race bike sat for a year with minimal use. I'd start it here and there, but it progressively starting running worse.
I cleaned the carbs, during which time I noticed the diaphragms were a bit deformed and essentially would not go back into the carbs. Fortunately I had a spare set on my parts bike.
Bike ran great afterwards, but I still didn't race it. I ran it here and there, but for the last year it has been in off site storage.
I tore into it last night and this morning. New plugs and fuel, but wouldn't start. Pulled the carbs and cleaned them.
Diaphragms are deformed again. Can't get them to seat in the carbs properly.
Is there any "saving" of them? They appear to cost $125ish each, which is crazy.
Thanks for the help, and bring on the "bad bike owner" comments.
Greenlawnracing is offline   Reply With Quote
Old February 17th, 2019, 11:29 AM   #2
ducatiman
ducatiman's Avatar
WTF? With the flower petal like appearance...would indicate they were not seated correctly....and/or subjected to chemical exposure? creating such an abnormal pattern? Did you use some sort of starting fluid or carb cleaner?
You could try washing them in warm soapy water (NO harsh chemicals), followed by bathing them in a product called Rubber Renue...see what happens. But NO GUARANTEES.
Next cheapest option? Probably...look for used slides or salvage carbs on the board here? Or ebay?
Other options...
if interested I've got a fully refurbed, like new carbset in stock for '08-'12 models (you didn't specify what year you've got in your post)
I've got aftermarket rubbers in stock, they require intense surgery to swap over....but can do if needed.
PM me if I can be of further service.
Good luck with it.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Last futzed with by ducatiman; February 17th, 2019 at 11:32 AM. Reason: clarity
Old February 17th, 2019, 11:46 AM   #3
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
And another thought....you say it's a race bike, what fuel are you running?
Old February 17th, 2019, 12:45 PM   #4
Greenlawnracing
Other options...
No chemicals. But the old fuel was two years old and had Stabil in it.
After massaging them a bit and letting them sit - i was able to get them back to "normal" form and get them to seat in the carbs again. Didn't open the other side because I don't want to tempt fate.
I took out the bowls and cleaned the jets, etc with carb cleaner.
Any other thoughts before I reassemble and try to start?
Going to hit a bicycle ride and try to wrap this up tonight.
Good luck with it.
Old February 18th, 2019, 09:09 AM   #5
Greenlawnracing
Think I'm making progress, but I cannot get the airbox back on the carbs to save my life. I don't have a ton of experience with it - until I moved to "WERA Land" I used pod filters as they were legal with CMRA.
Is there some trick to getting this thing back on?
Old February 18th, 2019, 09:50 AM   #6
See if this helps - https://faq.ninja250.org/wiki/Removing_the_airbox
This may or may not be legal in your class - https://faq.ninja250.org/wiki/Batter...r_carb_removal
Old February 18th, 2019, 07:03 PM   #7
To get airbox back on:
1. Push carbs onto boots on head. Tighten all 4 hose-clamps
2. Loosen both hose-clamps on airbox to maximim, 1-thread from falling off
3. Push/wiggle airbox onto carbs so they are fully seated
4. Tighten both hose-clamps
5. Connect crankcase vent
6. Route carb vent down middle back down to shock
7. Re-install cables.
Bike Sat For Years calypsia6978 1986 - 2007 Ninja 250R Tech Talk 18 June 5th, 2018 07:45 AM
I feel in love the first time I sat on my bike Liv2ride2liv New Members 23 March 3rd, 2012 07:28 AM
2004 sat for 5 years JoeLansing 2008 - 2012 Ninja 250R Tech Talk 3 July 19th, 2011 06:56 PM
Got a bike that was dropped and sat for 4 years. mordac 1986 - 2007 Ninja 250R Tech Talk 14 October 7th, 2010 05:02 PM
Gipsy sat on my bike :) bogdanb General Motorcycling Discussion 32 May 28th, 2009 10:06 AM
