March 23rd, 2015, 10:22 AM | #1 |
Join Date: Feb 2015 Motorcycle(s): Ninja 300, Duke 690 Posts: 33
Ninja 300 w/ QS drops down in gear
Just came back from a great AFM weekend at Buttonwillow - it was a blast!
However, during the entire weekend I had problems with falling out of 5th and 6th gear (mostly 6th) - not into neutral but into one gear down. Needless to say, this made for some exciting fast corners, and brought be off the track once (because I was surprised by it, when it happened later I rode it out). I'm using a Dynojet QS, I'm not sure if that's related or not. "Double-pushing" down the lever seemed to help a lot (while keeping the lever down to not trigger another QS shift), but certainly didn't make it disappear. Any thoughts here? Anyone experienced something similar on the track and solved it? I can certainly just ride it and be prepared for it to happen, but it would be nice if that mental capacity could be spent going faster. |
March 23rd, 2015, 10:28 AM | #2 |
March 23rd, 2015, 10:43 AM | #3 |
Uh oh, what did I step in to.
March 23rd, 2015, 11:19 AM | #5 |
KAWASAKI GURU
Join Date: Jul 2013 Motorcycle(s): Turbo Ninja 250 Posts: 863
Are you running your shifter in reverse? Meaning to go from 1st to 2nd you have to push the lever down?
Or to go from 1st to 2nd do you have to pull up? Give us as much info as you can about your setup! |
March 23rd, 2015, 11:22 AM | #6 |
is the timing for the QS adjustable per gear? maybe you can simply set the kill for 5 and 6 higher? they make aftermarket shift hub locker springs that make it lock in a bit better. alternatively you can simply shim the current spring. another option is an aftermarket shift star, or even simply grinding your oem shift star to be steeper.
March 23rd, 2015, 11:27 AM | #7 |
KAWASAKI GURU
Not saying this could be your issue but I have had a "lazy" shifter before where it took a little bit of pushing to get into gear, cause was a worn out shift detent sping.
The shifter detent spring keeps pressure on the detent arm... the detent arm keeps the shift star which is connected to the shift drum which decides which gear to throw... ** Sorry if I lost you there** Basically if that spring looses its tension it could fall out of gear. Factory pro makes a replacement arm and spring and their stuff has worked great for many many years. You may want to check it out but I just looked and its $100 bucks for their kit or you can buy a new spring from the factory MSRP is $1.37 lol... part number 92145-0895 |
March 23rd, 2015, 11:28 AM | #8 |
KAWASAKI GURU
March 23rd, 2015, 11:31 AM | #10 |
KAWASAKI GURU
March 23rd, 2015, 12:49 PM | #12 |
Thanks for all the great replies! I was a bit worried I had entered a mine field by the initial popcorn, but this thread is turning out great.
I'm running Woodcraft rearsets, GP-shift, and a Dynojet QS unit attached to a Power Commander V. I have not attached the speed pickup to the PCV, so I can't do per-gear timing at the moment. I'll certainly look into the options suggested above, I've also heard racers putting on the "Pro Shift Detent Arm and Spring Kit " from Factory Pro which seems to work in line with what people are suggesting above. Edit: And the factory pro kit has already been suggested, thank you garth and sorry for missing that part when reading through the thread |
March 23rd, 2015, 12:53 PM | #13 |
KAWASAKI GURU
Good info.... question for ya.... does it happen immediately when you are shifting or will it do it only at say part throttle or something like that?
I'd say if you can spare the $100 go for the shift kit, factory pro kits are great, a little pricy for a spring and a arm but their ball bearing roller in my opinion is the best part of the upgrade. |
March 23rd, 2015, 12:53 PM | #14 |
KAWASAKI GURU
Oh also forgot to ask, do you know what the kill time is set to?
March 23rd, 2015, 01:03 PM | #15 |
i would think it would solve your issues if you got the speed sensor so you can set the cutoff time for 5 and 6 higher
March 23rd, 2015, 01:25 PM | #16 | |
Kill time is 65ms. Would that be a shorter or a longer kill time that is required? |
March 23rd, 2015, 01:28 PM | #17 |
KAWASAKI GURU
you normally shorten up the shift kill time as you go up in gear, most people will shorten it by 5ms per gear after 2nd.
1 - 65 2 - 65 3 - 60 4 - 55 5 - 50 6 - 45 |
March 23rd, 2015, 01:28 PM | #18 |
KAWASAKI GURU
If its doing it after you shift though I dont think its your quick shifter, I'd say if the shift detent spring.
March 23rd, 2015, 01:33 PM | #19 | |
Sorry about the popcorn giving you the wrong impression. I like learning stuff. Great info thus far!
March 23rd, 2015, 02:44 PM | #20 |
Before going into major surgery, I would check the easy probable cause first: the external mechanism.
Ask a friend switch gears while the tire can rotate and pay attention to the extreme positions of the mechanism regarding hitting some solid part or simply adopting a position of poor leverage at the end of the stroke. If you find nothing wrong, post some pics later.
March 24th, 2015, 10:36 AM | #21 | |
March 24th, 2015, 10:39 AM | #22 | |
March 30th, 2015, 09:42 PM | #23 |
Join Date: May 2009 Motorcycle(s): 2007 EX250 (street), 1994 EX250 (Race), 2008 250R (Race), 2000 250 (project), 1991 EL250 (a cruiser!) Posts: 287
March 30th, 2015, 09:51 PM | #24 |
March 30th, 2015, 09:54 PM | #25 |
To be specific went off in club corner.
March 30th, 2015, 10:12 PM | #26 |
That must have been Friday I was thinking of. I think you had just passed me on the front straight or out of #2 then I saw you in the dirt.
And I'm always confused where Cotton starts and ends. Ha! I spent 10 minutes talking to people about coming over the wheelie bump there (and me not knowing what it was called) before everyone came to an agreement as to what we were talking about. I'm me on BARF. lol Good luck with the QS. I've got the standard issues of popping out of gear at the wrong times... I'll see you at Sonoma!
AFM #867 (5309) |
March 30th, 2015, 10:28 PM | #27 |
Here's the video of me dirt tracking (of course on the gopro the downshift looks like a complete non-event, in real life the rear end felt pretty messed up! Anyway, had I been mentally prepared I wouldn't have gone off)
https://www.facebook.com/video.php?v=10155331248235414 |
March 30th, 2015, 11:13 PM | #28 | |
AFM #867 (5309) |
March 31st, 2015, 12:24 AM | #29 |
Freedom for Germany
@kalleh, allow me to ask a silly question please.
When I look at the PC-Website I can see they offer the push type sensor 4-114 for the 300 only and while you have gp-shift, do you have the right sensor since for gp-shift you need the pull type sensor? If you have the right one please forget about my question. |
March 31st, 2015, 08:09 AM | #30 | |
April 1st, 2015, 10:03 AM | #31 |
Join Date: Dec 2014 Motorcycle(s): Ninja 300, GSXR-750, Ducati M1100 Posts: 185
Shifting problems
Some of the CMRA guys are having the same problems on the 300
http://www.cmraracing.com/showthread...Shifting-Issue I'm also having a problem, but only on hard braking/deceleration. Coming into a corner after hard braking, I'll let off the brakes and while under engine braking start turning in and it will seem to pop out of gear, it will them re-engage a second or two later which has almost caused me to high side a couple of times. |
April 1st, 2015, 10:48 AM | #32 | |
I have a factory pro spring kit on the way, will make a point to make sure the entire mechanism is working optimally as well. I'll report back after the next race which is 2-3 May. edit: wow, s h i t t y is a banned word? |
April 1st, 2015, 11:01 AM | #33 |
Inline 4!!!
April 1st, 2015, 03:43 PM | #34 | |
April 12th, 2015, 03:01 PM | #35 | |
Join Date: Jan 2012 Motorcycle(s): Race bikes:08 Ninja 250,11 R6,16 ZX6,SV650.3 HD-1947,2-2003,2010. 1946 Indian and a lot of dirt bikes.2 Posts: 999
April 12th, 2015, 03:03 PM | #36 |
all 3 of my track bikes down shift from 6 to 5 regulary. one has a quick shifter, 2 have the factory spring and the 3rd is all stock,
Last futzed with by bruce71198; April 12th, 2015 at 03:03 PM. Reason: typo |
April 13th, 2015, 10:41 AM | #37 | |
Sad to hear that the factory pro kit doesn't seem to work for this issue |
April 13th, 2015, 10:43 AM | #38 |
April 13th, 2015, 10:43 AM | #39 |
April 13th, 2015, 12:50 PM | #40 | |
I will try the clutch shift for 5/6 upshift this weekend and see if it helps. |
2013 Ninja 300 PZRacing Gear Plug and Play Indicators - Ninjette.org Special Pricing! | SlowBoyRacing | Motorcycle-related | 8 | April 17th, 2014 01:41 PM |
