Old July 25th, 2013, 09:33 AM   #161
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
I cut up a yoshimaura header. It had swiveling head pipe flanges. I figured it was one less thing to line up. And after two weeks of cutting and welding. I would have used this or springs.
Worlds fastest 250 ninja
Old July 25th, 2013, 09:53 AM   #162
Racer x
Racer x's Avatar
Just spoke with an engine expert and he said I will burn up the 02 sensors. I should mount them down stream from the turbo 18 inches and 20 deg from vertical.
This is for UEGO sensors. Looks like I have to read all about 02 sensors now
Old July 25th, 2013, 01:47 PM   #163
Racer x
Racer x's Avatar
OK after three tries the turbo is in place. High enough to drain oil back to the crankcase. Close enough to the head so the wheel will not touch.
Now I need to rethink the exhaust pipe from the turbo. I guess I need to get one wide band sensor and use it for both cylinders. I guess i can use an a/f gauge off the sensor also.
Next step is oil feed and return lines and fittings.
Old July 25th, 2013, 05:13 PM   #164
Racer x
Racer x's Avatar
This is a better shot. Just throwing together stuff with fittings I have around. The hose will get replaced with steel braided stuff.
Old July 25th, 2013, 05:18 PM   #165
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Wonder when a ninjette will hit 200?
Old July 25th, 2013, 05:20 PM   #166
Racer x
Racer x's Avatar
When I hit the mega lottery jackpot.
Old July 25th, 2013, 06:08 PM   #167
JohnnyBravo
You will be in my thoughts and prayers... Lemme get a few bucks when ya win
Old July 25th, 2013, 06:09 PM   #168
Racer x
Racer x's Avatar
Pit crew pay is real good.
Old July 25th, 2013, 06:23 PM   #169
lgk
Prolly have to go through similar efforts as the guy who got 2000hp out of his lancer...
Old July 25th, 2013, 06:31 PM   #170
Racer x
Racer x's Avatar
You mean this one?
http://youtu.be/eZBHJhyAVzE
Old July 25th, 2013, 06:58 PM   #171
lgk
I think it was these guys.
http://forums.bimmerforums.com/forum....php?t=1575817
Old August 4th, 2013, 04:01 PM   #172
Racer x
Racer x's Avatar
Just an update
I have the header finished and will finish the rest of the exhaust tomorrow.
I am making an exhaust pipe that will hold a single wide band o2 sensor. This sensor from Ecotron. Will read the air fuel ratio send a signal to the computer so it can adjust the ratio automatically. Plus I will have a gauge.
This information will also down load and play back later.
I have the fuel tank finished 1.5 gallon with two outlets and a nice air vent. Plus an extra inlet if I need it.
The next step is the seat and rear swing arm.
I have a lot of stuff to put on this bike. Wires ,hoses ,computers. I need to get my seating position together before I mount anything.
Nothing will happen with this build for another two months. I need to order my seat. It will take a months or two to make.
Old August 4th, 2013, 08:03 PM   #173
quarterliter
Motorcycle(s): 2004 Ninja 250
Eric have you had any clutch slip issues with all this extra power over stock? If so how did you cure it?
Old August 4th, 2013, 11:37 PM   #174
Racer x
Racer x's Avatar
I have not had any clutch issues since switching to a Barnett Clufch and springs. But if I do then I will have a lock up clutch and custom side cover.
Old August 5th, 2013, 06:06 AM   #175
Racer x
Racer x's Avatar
I finished the welding on the pipe. Still need to add a hanger tab and wrap with heat covering.
Old August 30th, 2013, 10:02 AM   #176
lgk
Hows the bike coming along?
Old August 30th, 2013, 01:16 PM   #177
Racer x
Racer x's Avatar
Great. ut things have to wait a while. I just got back from the Bonnevile Salt Flats. And I am racing in Ohio at the end of September.
But I have a couple small things done.
Old September 7th, 2013, 08:30 AM   #178
Racer x
Racer x's Avatar
I finished the exhaust system. It it painted, welded and wrapped . I made a little bracket to support it . It has a single wide band O2 sensor. The next step is to get the intercooler made.
I also finished the center stand. I just needed to make a stop. It normally sits on the muffler. But I don't have a muffler so it went to high up and the spring would fall off.
Old September 7th, 2013, 08:34 AM   #179
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
wouldn't ceramic coating be better than wrapping?
Old September 7th, 2013, 08:55 AM   #180
Racer x
Racer x's Avatar
Yes but the wrap cost $13.00. And hides my welding. ;-)
Old September 14th, 2013, 10:18 AM   #181
JohnnyBravo
Are these engines happier with or without restriction? AreaP vs Jardine?
Looks like yours is fine open, but you have a whole different animal
Old September 14th, 2013, 10:22 AM   #182
Racer x
Racer x's Avatar
If you mean exhaust restriction. Then yes. Back pressure seems to help. I had my exhaust open. And also just cut off short. Long and open with just the right amount of back pressure works best. But with a turbo. Wide open for now.
Old September 14th, 2013, 10:25 AM   #183
JohnnyBravo
That's just what I meant, and just the answer I expected, but wasn't hoping for. Thanks... How'd the salt treat ya? Best of luck in ohio
Old September 14th, 2013, 10:32 AM   #184
Racer x
Racer x's Avatar
We set six records in two classes. And everyone went home safe. Then it started to rain. Now there is four inches of water on the salt. They hope it will dry out by the 18th. The big boys are trying to go five hundred mph with four wheels and four hundred on two.. but mother nature says different.
Old September 14th, 2013, 10:53 AM   #185
JohnnyBravo
Congrats... 500mph you say, some folks just crazy haha
Old September 14th, 2013, 11:22 AM   #186
Racer x
Racer x's Avatar
Actually 550.
WWW.target550.com
This thing has Two count em two Keith Black blown hemi's
Old September 14th, 2013, 02:08 PM   #187
JohnnyBravo
Yikes
Old September 26th, 2013, 03:29 AM   #188
QuickSiR
QuickSiR's Avatar
Motorcycle(s): Honda 599
Read all 5 pages! Keep up the good work!
QuickSiR is offline   Reply With Quote
Old September 26th, 2013, 03:57 AM   #189
Racer x
Racer x's Avatar
Thanks
things are going to move again. This weekend I test the nitrous bike. Then the motor will go into the turbo.
Old September 26th, 2013, 07:26 AM   #190
greenaero
Motorcycle Hypermiler
greenaero's Avatar
Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's
Congratulations!!!!
greenaero is offline   Reply With Quote
Old October 17th, 2013, 04:44 PM   #191
Racer x
Racer x's Avatar
I made a little progres. I ordered the swingarm extentions. They will move the wheel 4-6 inches back. I need a lot of room to adjust the chain for different gear combos. And to comply with the rules the fairing can be more than three inches behind the tire. This is a small tire but it is about in the right place.
Once the wheel and fairing is inplace I can make the seat then mount the shifter breakpedal and the throttle/ clutch cable.
Old October 18th, 2013, 04:07 PM   #192
Racer x
Racer x's Avatar
I got the extentions. They are great. I will mount the fairing now and go to work making it fit. And make the seat.
Old October 18th, 2013, 05:08 PM   #193
cuong-nutz
cuong-nutz's Avatar
Awesome!
HalfFast Racing Team
Old October 18th, 2013, 05:54 PM   #194
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Wow that really looks great
Old October 18th, 2013, 06:24 PM   #195
mgentz
Board Member
So who made extensions for a 250?
Old October 18th, 2013, 07:15 PM   #196
allanoue
allanoue's Avatar
MOTM - Sep '14
Originally Posted by Somchai View Post
Old October 18th, 2013, 08:29 PM   #197
mgentz
Board Member
Crazy...
Old October 19th, 2013, 05:20 PM   #198
Racer x
Racer x's Avatar
Now we are getting somewhere. I got a huge amount done today. Belly pan made chain guard. Lots of little things.
Old October 20th, 2013, 06:15 AM   #199
JohnnyBravo
Glad ya got it sorted an into rule compliance
Looks longer an lower to, sure hope it helps!
Old October 20th, 2013, 06:36 AM   #200
Racer x
Racer x's Avatar
Funny you should mention the rules. Fortunately I am friends with the head tech inspector for the AMA and the FIM. He took one look at it and said I better measure. Modified rules are no more than 10% wheel base extention.
The package says four to six inches of extention with the plug in pieces I just bought. Well its more like five to eight. Stock wheelbase is 55.1 inch and I have to show documentation for that. 55.1 + 5.51 (10%) = 60.61.
The minimum wheel base I can get it 61 inch. If I have to pull the chain tight it gets bigger.
Also if I want to run the open class with no front fairing I can not allow the rear fairing to go past the rear tire at all. So I need a front fairing. And I am pushed to into the altered class. That makes the new proper designation ((Altered Partial Streamliner / blown fuel 350)). APS/BF-350 This is the big time.
Turbo250.com - My Turbo Build Blog garth285 2008 - 2012 Ninja 250R Tech Talk 319 June 19th, 2015 08:04 AM
My 07 250 cafe racer build elephantman78 1986 - 2007 Ninja 250R Farkles 12 December 25th, 2014 07:09 AM
My Cafe Racer Build girlracer 1986 - 2007 Ninja 250R Farkles 17 December 2nd, 2014 08:14 AM
Racer X engine build thread Racer x 2008 - 2012 Ninja 250R Tech Talk 189 June 12th, 2013 07:34 AM
I want to buy or build an 08+ 250R racer. Seanslides Ninjettes At Speed 20 March 1st, 2010 07:34 AM
