February 3rd, 2014, 06:06 PM | #1 |
Dogbone options?
Rexbo hasnt responded to my PM.
I am looking for some dogbones, the gsxr shock lowered my rear end alot so I need something that will raise it back up. I have short legs so I would like it to be similar to stock height or maybe 1/4" higher. |
February 3rd, 2014, 07:04 PM | #2 |
Freedom for Germany
Hello Chris take a look at Webike, maybe you'll find what you're looking for
http://japan.webike.net/ps/#!p.m=5921&p.c=1080&p.sk=1 |
February 4th, 2014, 04:59 PM | #3 |
I ordered from some random site I found. They had 1" raise dogbones.
February 4th, 2014, 07:25 PM | #4 |
Board Member
I do not believe that Rexbo does this anymore.....
February 5th, 2014, 08:08 AM | #5 |
Join Date: Sep 2013 Motorcycle(s): Ducati 1198s, Triumph D675, Suzuki SV1000s, `08 Ninja 250, `11 Ninja 250, Suzuki GS750 Posts: 368
This picture was taken before my jam nuts showed up but I bought all the parts to make my own adjustable dog bones.
Not only did I get back the inch lost from installing the GSXR shock I was able to raise it an extra 1.25" with still a little more to go. I wouldn't recommend going that high but if you wanted to its possible... Haven't had time to test it out 100% but if they work without major modification Ill have two sets to sell.
MCRA.com |
February 5th, 2014, 08:12 AM | #6 |
Join Date: Apr 2013 Motorcycle(s): 2004 Ninja 250 Posts: 465
How expensive were these to put together?
February 5th, 2014, 08:13 AM | #7 |
If they work out I was going to sell for $60 a set.
MCRA.com |
GSXR Shock dogbone solution!! Cheap too! | ChrisJuliano | 2008 - 2012 Ninja 250R Tech Talk | 54 | July 13th, 2015 06:11 PM |
Tachometer options | Konaunit1 | Ninjettes At Speed | 30 | July 22nd, 2014 03:39 PM |
stock 2008 rear link suspension links (dogbone) | cuong-nutz | Items Wanted | 8 | May 4th, 2011 03:19 PM |
Tire options | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 12 | August 27th, 2009 10:42 PM |
Seat Options | sm0kediver | 2008 - 2012 Ninja 250R Farkles | 44 | August 11th, 2009 02:12 PM |
