Old December 20th, 2015, 10:43 AM   #1
daverdfw
Motorcycle(s): 2009 Ninja 250
question about safety switches (clutch)
I am working to make my 2009 a dedicated track bike. From what I gathered on the kickstand switch I just solder the 2 wires together. But I am trying to eliminate the left hand cluster or switches. What do I do with the clutch safety switch?
daverdfw is offline   Reply With Quote
Old December 20th, 2015, 12:51 PM   #2
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Take it off, al it does is makes it so you can start the bike in gear.
TEAM ALFALFA
www.apexassassins.com
Old December 20th, 2015, 12:51 PM   #3
daverdfw
ok thanks! Thats what I thought after reading the wiki, but I wanted to verify.
Old December 20th, 2015, 12:52 PM   #4
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
this is my set up:
TEAM ALFALFA
Old December 20th, 2015, 12:53 PM   #5
daverdfw
this is my set up:
ah you swapped the kill switch to the left, was that because of the motion pro requiring their kill switch?
Old December 20th, 2015, 02:24 PM   #6
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
more space on the left for the kill switch
TEAM ALFALFA
Old December 26th, 2015, 02:59 PM   #7
kalleh
Motorcycle(s): Ninja 300, Duke 690
My bike doesn't have the switch right now now, but I'm planning on changing that for the next racing season (at least adding a jumper cable). Why? Stalling in the wrong spot is can be dangerous on a race track, and not having to fiddle with getting the bike into neutral can get you going faster.
This is particularly true at a race start, but I can imagine some track day scenarios as well.
AFM#977 - http://racingdreamz.com
kalleh is offline   Reply With Quote
Old December 26th, 2015, 05:12 PM   #8
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
you are racing the wrong level and wrong bike if those are your concerns.
TEAM ALFALFA
Old December 26th, 2015, 10:12 PM   #9
kalleh
I have no idea what that means.
Old December 27th, 2015, 09:03 AM   #10
AchyGrappler
Motorbike Obsessed
AchyGrappler's Avatar
Motorcycle(s): 2004 Kawasaki EX250, 2004 Yamaha FZ1, 2006 Honda CRF 450 Flat Track Race Bike
I want to do the right-cluster-to-left swap with the quick turn throttle on my pregen race bike. I will be keeping the clutch switch as there is no point in removing it if you are looking for weight loss as it only weighs grams. I can get the same performance boost if I stop drinking beer (not going to happen BTW).
My race Ninja build and more motorcycle content. My Motorbike Obsessions
AchyGrappler is offline   Reply With Quote
Old December 28th, 2015, 12:18 AM   #11
MrAtom
MOTM - July '15
Hmm... My pregen's clutch safety switch broke, and I'm pretty sure I can start it in gear. Is it different?
Old December 28th, 2015, 09:33 AM   #12
rc racer
rc racer's Avatar
Motorcycle(s): 2015 R3, 1969 CB160, 2002 TTR125, 2007 KX250F
I completely agree with this. I recently prepped my bike and removed all the wiring to the left handlebar including the clutch safety switch. Next race weekend during one of my starts after gridding up and waiting for the flagger to go through his starting process I pulled the clutch and dropped it into first. There was enough resistance to the engine that it died. Instinctively I kept the clutch pulled and frantically stabbed the starter button but it will not start unless I found neutral again. Green flag was shown and all I could do was wave my arms while the grid thankfully went around me without incident. Then finally find neutral, start the bike and chase the pack.
I wired in a jumper in the next day.
rc racer is offline   Reply With Quote
Old December 29th, 2015, 04:48 PM   #13
daverdfw
what part of the harness is the switch? there are like 2 connectors, One is a 2 wire and then a bigger complex like 6 or 8 connector one.
Old December 30th, 2015, 06:43 AM   #14
rc racer
rc racer's Avatar
The switch is on the clutch lever perch with a little plunger that makes contact with the clutch lever. The switch will just have two wires and if you remove the left switch cluster and all wiring associated with it the bike does not know if you have the clutch pulled. I just followed the two wires back to where they plugged into the main harness under the tank and put a jumper in place of the clutch lever switch wires.
Now I can start the bike in gear in an emergency. Only problem is the bike always thinks the clutch is pulled so it can be started in gear even without the clutch lever being pulled. I am much less worried about that possibility though.
Sorry I cant tell you specifics about wire colors or positions in the plug. I did this a while ago and don't remember but its pretty easy to trace by looking at wire colors.
Old December 30th, 2015, 08:03 AM   #15
Dsheumaker
Dsheumaker's Avatar
Motorcycle(s): 14 Ninja 300 (Track Only), 07 CRF150RB
Maybe im reading this wrong, but to me it looks like the circuit is opened when the clutch is pulled in, this snip is from the wiring diagram.
Dsheumaker is offline   Reply With Quote
Old December 30th, 2015, 08:04 AM   #16
Dsheumaker
Dsheumaker's Avatar
Oh and that is for the NewGen BTW! not sure if the same for the pregen.
Old January 2nd, 2016, 10:29 PM   #17
daverdfw
I tracked it down, and all I did was cut the cover to the wires and pulled out the separate ones for the switch. So I wont have the huge connector with all the other wires, just the 2 going to the switch.
Safety Switches biblefreak 1986 - 2007 Ninja 250R Tech Talk 2 June 5th, 2015 06:14 AM
clutch question... yujayn 1986 - 2007 Ninja 250R Tech Talk 7 August 4th, 2011 12:40 PM
Personal safety Question. Kitdog General Motorcycling Discussion 41 July 26th, 2010 11:25 PM
[topix.net] - Safety foundation asks important motorcycle question of new riders Ninjette Newsbot Motorcycling News 0 May 5th, 2009 06:20 PM
