Old February 14th, 2016, 11:07 AM   #1
Mike K
Mike K's Avatar
Motorcycle(s): 2014 Ninja 300 track bike, 2007 Suzuki GSXR 750 track bike, 2002 Yamaha R6, 1995 CBR600RR f3 track bike
Sprocket fit question
Are the sprockets the same shaft size from year to year?
Track, track, track
Mike K is offline   Reply With Quote
Old February 14th, 2016, 11:08 AM   #2
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Countershaft sprockets?
Goin' fast on slow bikes!
Old February 14th, 2016, 11:29 AM   #3
Mike K
Mike K's Avatar
Front sprocket. On the engine output shaft.
Track, track, track
Old February 14th, 2016, 12:18 PM   #4
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!)
MOTM - Nov '15
Front sprocket is the countershaft sprocket. But sorry; can't answer your question. If you search parts lists you might find if they use the same part number for the different years.
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over
SLOWn60 is offline   Reply With Quote
Old February 14th, 2016, 12:20 PM   #5
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
They don't because the pre-gens use two bolts and a plate to retain the sprocket while the new gens use a large nut on the output shaft.
The countershafts use the same output bearing which means the shaft is the same size. However, this doesn't say anything about tooth count or shaft diameter reduction where the sprocket sits.
In short, I don't know either.
Old February 14th, 2016, 01:04 PM   #6
VaFish
VaFish's Avatar
MOTM - Jan '16
JT Sprockets lists different part numbers in their catalog for the front sprocket. The rear has the same part number for both generations.
so I would guess they are different.
Old February 14th, 2016, 01:40 PM   #7
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
new gen is different then pre gen
TEAM ALFALFA
www.apexassassins.com
Old February 14th, 2016, 03:43 PM   #8
hfd1 tuner
Motorcycle(s): many mostly racebikes cbr565 fzr490 ex250ish
sprocket offset is different from old to new.
hfd1 tuner is offline   Reply With Quote
Old February 16th, 2016, 10:40 AM   #9
Mike K
Mike K's Avatar
Thanks for the info.
Track, track, track
Old February 16th, 2016, 11:01 AM   #10
HoneyBadgerRy
HoneyBadgerRy's Avatar
The sprocket shaft is the same size, both will fit on both shafts, but the newgen and pregen have different offsets, so get a 07 previous for pregen and 08 newer for newgen.
Old February 16th, 2016, 11:42 AM   #11
Mike K
Mike K's Avatar
Thanks, that's exactly what I needed to know.
Track, track, track
Old February 16th, 2016, 03:30 PM   #12
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
BAM! Thanks!
Old February 16th, 2016, 03:32 PM   #13
Mike K
Mike K's Avatar
I'm considering going -1 on the front. It's a race only bike now.
File Type: jpg 12660240_10205382654661081_134440000_n.jpg (108.9 KB, 0 views)
Track, track, track
Chain and sprocket question Baron 2008 - 2012 Ninja 250R Tech Talk 12 July 11th, 2014 01:35 PM
Rear sprocket question reroka 2008 - 2012 Ninja 250R Tech Talk 8 April 27th, 2014 09:36 PM
JT Front Sprocket Question Jim Moore 1986 - 2007 Ninja 250R Tech Talk 10 June 27th, 2012 04:45 AM
Sprocket question from a newbie cryllyn 2008 - 2012 Ninja 250R Tech Talk 4 April 16th, 2012 10:25 PM
Stupid Sprocket Question demp 2008 - 2012 Ninja 250R Tech Talk 14 September 7th, 2010 01:32 PM
