April 8th, 2010, 01:49 PM | #1 |
Starting in First
Did a quick search and didn't come up with anything. Apologies if this is yet another redundant thread.
Anyone else have issues starting the engine in first gear? Yes I'm putting the kickstand up before I try to start (most of the time). Sometimes it will start in 1st gear, sometimes it won't. Always starts when I kick it over to N, just strikes me as a little odd. Also checked for vapor lock (below) Kinda think the kickstand kill switch was going on me, but wouldn't it kill the engine soon as I put it in gear from a start in N? If not the kickstand switch, then what? Also think I'm getting a little vapor lock, which I haven't had to deal with before. Bike runs fine, but if I pulled over in the direct sun for more than a couple minutes, it was constantly whining and reluctant to start until I popped the tank lid for a sec. Sound about right to you people that have hotter weather? Suggested remedies?
April 8th, 2010, 02:01 PM | #2 |
Join Date: Mar 2009 Motorcycle(s): '09 Ninja 250 Black Posts: A lot.
I've had issues when i thought i was in first cause N light wasn't on but let go of the clutch and didn't move. The only way i know for sure if i'm in first i fell a clunk when shifting to first and the N light is off.
I'm not small, I'm fun sized |
April 8th, 2010, 02:21 PM | #3 |
You are sleeping
I don't think mine starts in first unless I'm rolling down a hill and dump the clutch. I'll go check..
Edit: Woops it does start in first if kickstand is up. I would think if the kill switch on the stand broke the bike would still run normally? Only it wouldn't shut off if you put the kickstand down when in first and would start with the kick stand down in first. (scary)
<Yeah, it's a 250. LMFAO! Weaksauce |
April 8th, 2010, 05:03 PM | #4 |
Join Date: Dec 2008 Motorcycle(s): 08 Ninja 250R Candy Plasma Blue Posts: 129
Sounds like your switch in the clutch lever is sticking. The clutch needs to be pulled in for the bike to start in gear. If the switch sticks it thinks the clutch is not disengaged and won't start.
Posted via Mobile Device |
April 8th, 2010, 05:07 PM | #5 |
Hmm, there's actually a switch/sensor in the clutch lever? Interesting I hadn't noticed that. I'll have to take a look at that, mebbe shoot a little contact cleaner or lubricant in there tomorrow. Thanks for the idea.
I don't have any issues starting it in N with the clutch out but tryin to start in gear, I always have the clutch lever pulled. Been driving a manual truck for the last decade that won't start for any reason unless the clutch is in. Edit: found the switch. PN 27010-0098. Guess I'll see if I can get it to replicate the issue by jamming it in place or something. Might also be the 'wiggle' in my clutch lever just not pushing on it in the right direction.
April 8th, 2010, 05:19 PM | #6 |
I am not familiar with all the switches and safety stuff designed to save ourselves from ourselves------but, like a dumb s---, I left my fog lights on and my battery was dead. I put the bike into second gear, switched the ignition to ON, and gave the bike a good shove, jumped on, and dumped the clutch. Bike started right up. Had about five hours left to get to where I was going, so it was no sweat. Lesson learned: Don`t leave your fog lights on when stopping for a cup of coffee. Sure wish the Ninja had a kick starter.
April 8th, 2010, 05:26 PM | #7 |
Right with ya... I leave the headlights on in my truck more often than I want to remember. I carry one of those portable battery jumpers and use it for that reason alone at least once a month (and hook the battery up to a charger when I get home). Glad the lights are on an ignition switch on the ninjette
April 8th, 2010, 05:54 PM | #8 |
Yep, and it's known for misbehaving. Jiggle it around, make sure it is moving properly, and it might fix the problem for awhile. Kawi uses the same iffy switch on many of their models.
April 8th, 2010, 06:07 PM | #9 |
Thanks for confirming Alex.
Argh why Kawai?! You cheap cornballs...
April 9th, 2010, 05:27 PM | #10 |
Yep, that's all it was. If I don't have the clutch lever 100% back to the handlebar it sometimes still depresses the switch a tidbit, depending on whether the lever is on the 'up' or 'down' section of its wobble. Think I'm gonna try to take the switch apart tomorrow and adjust the junction a little so it's not quite as finicky.
April 12th, 2010, 06:08 PM | #11 |
Mine starts in 1st without clutch.
I think the sensor is bad or something. When I first got the bike, it didn't do it but now it does hehe. |
April 12th, 2010, 06:57 PM | #12 |
Wound up taking the switch apart yesterday afternoon. Here's what I found:
DSC05090.jpg DSC05091.jpg Needless to say, that's not how it's supposed to be. Checked the connection across the contacts before I pulled it apart (just plastic tabs holding it together, 2 loc-tite'd screws holding it to the bike) and the connection was poor to say it gently. 5 minutes later with some contact cleaner and a few q-tips, it was clean, reassembled and back on the bike. No trouble starting in gear on 10 consecutive starts so long as the clutch was pulled ~90%. For what it's worth, it seems to me that the switch can't really get stuck in the 'clutch not disengaged' position without also jamming the clutch lever itself, as that's the position with the pin out (spring decompressed). Thanks for notifying me there is a switch there though. Been fiddling with this bike for 18months now and still learning lots
starting up probs | UltraHarley1 | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 16th, 2014 07:33 AM |
Starting a MotoVlog! | YamiLionheart | Videos | 3 | April 22nd, 2013 03:28 PM |
Not starting with ether? | cgborders | 1986 - 2007 Ninja 250R Tech Talk | 6 | February 8th, 2012 08:28 AM |
Trouble Starting | dlebe250 | 1986 - 2007 Ninja 250R Tech Talk | 7 | January 12th, 2011 07:47 AM |
starting bike | james250ninja | 1986 - 2007 Ninja 250R Tech Talk | 3 | April 3rd, 2010 12:12 PM |
