Old August 31st, 2010, 06:02 PM   #1
illrational
illrational's Avatar
Motorcycle(s): Black '11 ZX-6R
I think i really messed up....
Last weekend i took bike apart and shimmed my washers. I also got my rims painted.I put everything back together but now im hearing liek a rattling noise and when im slowing dwn its like a grinding noise. i wish i could tape the noise while im riding. I put on stands and turned wheels and i didnt get the noise. I think i might just take to mechanic because im a lil scared!!!LOLand
Any thoughts gurus?
My 250 is mine and mine alone, you may see better you'll definitely see worse but mine, she's one of a kind!!!!btw, SHE'S SEXY!!!
illrational is offline   Reply With Quote
Old September 1st, 2010, 05:11 PM   #2
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old September 1st, 2010, 07:03 PM   #3
illrational
Originally Posted by noche_caliente View Post
What do you mean bump?
Old September 1st, 2010, 07:08 PM   #4
PitBull
PitBull's Avatar
Motorcycle(s): 09 Ninja 250
She "bumped" it so it would go to the top of the list so maybe someone will see it and help you out.
PitBull is offline   Reply With Quote
Old September 1st, 2010, 07:14 PM   #5
scotty
scotty's Avatar
Motorcycle(s): Yahama v star 650 classic
Where is the noise comming from? All bolts tight? Gas tank on their well? Comming from the wheels? More Deatils!! =)
scotty is offline   Reply With Quote
Old September 1st, 2010, 07:18 PM   #6
illrational
Oh ok thanks Noche..I have no idea where it coming from, i thought i was wheels then i thoughtit was engne, i have no idea and icant make it do it on the stands... i torqued all screws accoding to specs
Old September 1st, 2010, 07:21 PM   #7
nyczs2k
nyczs2k
nyczs2k's Avatar
Motorcycle(s): 2010 Ninja EX250 JAF
Did you align your wheel correctly? You should also check the amount of slack you have on your chain. Triple check that everything is assembled properly.
Most mechanics are thieves, if you have decent knowledge about bikes, you should figure out the problem on your own. It is in these moments when you really get to know your bike and learn to appreciate the bike that much more!
GL and keep us posted
nyczs2k is offline   Reply With Quote
Old September 1st, 2010, 07:21 PM   #8
scotty
scotty's Avatar
The wheels on tight? Straight? when you painted the wheels did you remove the tires and get them rebalanced? (Sp?) Im just throwing ideas out. Lol
Old September 1st, 2010, 07:48 PM   #9
illrational
i didnt get rebalanced, i think everythings tight, i aligned tires using the hash marks o the swwingarm
Old September 1st, 2010, 08:01 PM   #10
mikedabike64
Motorcycle(s): 2008 ninja 250
is the chain too tight? n/t
could be coming from a strain on the output shaft. (sprocket)
mikedabike64 is offline   Reply With Quote
Old September 1st, 2010, 08:15 PM   #11
illrational
I did also add shogun frame sliders...my chain is snug i can move +- around half inch or so
Old September 1st, 2010, 08:24 PM   #12
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
Bearings were installed into the front rim after the painting?
Also the swingarm markings aren't very useful when aligning your rear sprocket/tire. I use a MotionPro tool, but I believe an alignment tool can me made for relatively cheap.
k-os is offline   Reply With Quote
Old September 1st, 2010, 08:26 PM   #13
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
1/2" is too tight. The chain tenses up as the suspension moves up and down. IIRC the slack should be 1" to 1 1/4".
Old September 1st, 2010, 08:28 PM   #14
nyczs2k
nyczs2k
nyczs2k's Avatar
Swingarm markings are not reliable.
Old September 1st, 2010, 08:34 PM   #15
illrational
should it be a inch up and a inch down
Old September 1st, 2010, 08:48 PM   #16
no pull it up halfway between sprockets, then push it down. total distance between up and down
Old September 2nd, 2010, 08:17 AM   #17
illrational
What would i do with out yall...i readjusted the chain and the grind is gone, i hope i didnt do too much damage by having it too tight...Thanks again!!!
Old September 2nd, 2010, 08:25 AM   #18
dubojr1
dubojr1's Avatar
You should be fine. No worries!
Old September 2nd, 2010, 08:26 AM   #19
dubojr1
dubojr1's Avatar
BTW... where's the new pics?
Old September 2nd, 2010, 08:29 AM   #20
Glad it worked out.
Old September 2nd, 2010, 05:56 PM   #21
illrational
I have one of her with the painted rims on the stands in updated pics.
Matter fact....
I got messed up modded !%@*#$%!)@#&!%@ I crashed! 32 August 16th, 2013 09:49 PM
I messed up...how would you have taken this turn? watsyurface Riding Skills 46 March 20th, 2013 03:45 PM
This is messed up Apex Off-Topic 6 January 20th, 2013 12:49 AM
Messed up diaphragm THE BIG SITT Motorcycle-related 0 May 30th, 2012 05:25 PM
Messed up dash speedo EMSRacer07 1986 - 2007 Ninja 250R Tech Talk 1 January 23rd, 2012 06:29 AM
