Old January 9th, 2011, 04:05 PM   #1
dlebe250
Motorcycle(s): 1994 250
Trouble Starting
Hey guys,
Today I took my bike out around town to do some errands, and the last time I started the bike it would not start. The lights were on but when I hit the start button it would give that, "eh eh eh" sound and then nothing. I have enough fuel so it's not that. So I waited 5-10min and then hit the start button while using a little throttle and it finally worked (used throttle during previous tries as well). I'm not sure what this could mean but if anyone has an idea please let me know. Possibly needs a new battery? (any way to tell?). I'll be calling my mechanic tomorrow to inquire too.
dlebe250 is offline   Reply With Quote
Old January 9th, 2011, 04:35 PM   #2
bob706
bob706's Avatar
Could be the battery but if it happens again open the gas cap. You may have some vapor lock going on.
Old January 9th, 2011, 07:16 PM   #3
how old is the battery?
Old January 9th, 2011, 08:27 PM   #4
dlebe250
It's a 94' and I bought it used a few months ago and the previous owner didn't have any maintenance records. So it could be 17years old? Does the battery have a date on it?
Old January 9th, 2011, 09:06 PM   #5
I highly doubt it's the original battery. If you can't see any type of date on the battery case, assume the worst that it's due for replacement.
You can try and recharge it and see if it holds a charge, but personally, when a battery starts giving me problems, I change it out knowing that it will work until you are farthest from your house then die.
Also, AFAIK, the lights are not supposed to come on until the engine has been started, though this may only apply to the new gen bikes.
Old January 10th, 2011, 08:33 AM   #6
mrlmd
mrlmd's Avatar
Charge up your battery then get it load tested. That's the only way to see if it is any good other than guessing and just buying a new one.
If the engine was turning over (starter was running) it may have nothing to do with your battery and may be related to fuel or carb problems. Put some Berryman's B12 or Seafoam in the gas 1oz/gal to clean out and keep the carbs clean, especially if you know nothing of the previous owner's maintenance.
Don't panic and start replacing parts - charge the battery, use the carb cleaner and see how it runs.
Old January 12th, 2011, 01:10 AM   #7
dlebe250
Solution
Hey guys,
So I took the battery to my mechanic and he charged it over night and then load tested it. Told me its pretty good still and that it should turn over the bike. He said one reason this might have happened was me turning the key to the lock position but the one with the parking tail light still on. My "P" was worn away so I had no idea that this was an option. I have no idea why anyone would want to do that, since it just drains the battery. Anyway, I installed the newly charged battery and she starts right up. My mechanic is real nice and didn't charge me and told me to swing by and he'll check the voltage out while running the engine. Thanks for all the help!
Dan
Old January 12th, 2011, 07:47 AM   #8
mrlmd
mrlmd's Avatar
That key position is a safety feature if you're parked on the side of the road so someone can see you there. Many riders, esp. if you don't read the owners manual, don't even know it's there. Just check each time you walk away from the bike you don't accidentally leave it in that position with the tail light on all night. It shouldn't happen again now that you are aware of it.
Trouble starting bike. Floki General Motorcycling Discussion 56 January 2nd, 2015 03:28 PM
Bike has trouble starting capriccio 2008 - 2012 Ninja 250R Tech Talk 7 July 19th, 2012 10:37 AM
Trouble with starting speed vmlp 1986 - 2007 Ninja 250R Tech Talk 13 May 26th, 2012 09:12 PM
Having trouble starting in cold weather. d16soda 1986 - 2007 Ninja 250R Tech Talk 7 September 20th, 2011 10:47 AM
trouble starting... n4v1n 2008 - 2012 Ninja 250R Tech Talk 4 August 9th, 2009 03:18 PM
