Old March 16th, 2012, 03:49 PM   #1
fyv0h
fyv0h's Avatar
Motorcycle(s): 2008 250r, of the blue variety (bestowed to Ninja_Duck22), 1998 CBR Smokin' Joe
Bye Bye Rect-O-fier
Or something like that...
We had an issue a while back where the battery would die while riding. Never enough to kill the bike, but enough to not want to start back up. So we tested the 4 year old battery. It wasn't doing too well. We replaced it and went on our merry way. Fast forward a couple weeks and the battery is dead after a ride. I check voltage, it's reading 7v. I put it on the tender. I yank the fairings to test the Recto and the Alt, but I only got as far as the rectifier before I noticed that the connector that runs into the Recto has a fried wire. It's a yellow one. Positioned on the front right side of the connector. The connector is burnt through.
I'll order a rectifier, if for nothing more than peace of mind. But the questions are as follows: If this is an alternator wire, would the alternator be shot? And with the connector melted at this port (exposes adjacent ports slightly), what are my options for repair? I REALLY don't want to replace the harness.
fyv0h is offline   Reply With Quote
Old March 16th, 2012, 03:58 PM   #2
loz944
loz944's Avatar
Motorcycle(s): Green 2012 Ninja 250SE and a Yamaha fino scooter (my wife's really)
If you are lucky you maybe able to find a replacement connector block (just the plastic part)
or even get one from a breakers yard
Be safe ride smart .....a dumb rider is a dead rider
loz944 is offline   Reply With Quote
Old March 16th, 2012, 05:13 PM   #3
when i replaced my fried VRR, my connector block was also melted. i used terminal block connectors to replace it. my stator was fine. but i also had a fried crank position pickup coil and i had to replace that which comes as a single part stator+pickup coil. you probably dont need to replace it but its pretty quick to test the stator, just use an ohm meter across each of the 3 coil leads. testing one set at a time (ie- 1 and 2, 2 and 3, 3 and 1). if any of them are open / no connection, you know the stator is bad. oem stators are pretty expensive. you can pick up fine used ones from the wrecker or aftermarket stators from places like rickystator or electrosport.
Old March 17th, 2012, 12:01 PM   #4
fyv0h
fyv0h's Avatar
Put the meter on the battery. At 5k revs, voltage changes very little, even dips slightly when held at 5k. So I checked the alternator output. Book calls for ~40vAC across the three yellows. "Output voltage much higher...the rectifier is damaged" says the book. Define "much higher." I'm reading ~50vAC. Is 25% high tooooooooo dang high?
Old March 17th, 2012, 12:32 PM   #5
50vac is kinda high. the book should list resistance values also. check the resistance of each coil to make sure one is actually bad.
Old March 17th, 2012, 12:37 PM   #6
Mountain Dew
Ambrosia.
Mountain Dew's Avatar
Motorcycle(s): 1974 Honda CB550K0 W.I.P.
I always call it the rectal fire :3
Life's better on the Mountain.
Mountain Dew is offline   Reply With Quote
Old March 17th, 2012, 12:48 PM   #7
fyv0h
fyv0h's Avatar
book calls for 0.05 - 0.6 ohms, measuring across all yellows shows spot on 0.6.
Old March 17th, 2012, 01:51 PM   #8
sounds fine to me. like i said mine was fine after i fried the VR/R.
Back to a 250! Bye-bye 636 :) My new blue baby... Pipyr Pictures 8 March 24th, 2013 05:01 PM
bye bye new exhaust (trad: Belin mi han fatto lo scarico) faxeman General Motorcycling Discussion 4 June 11th, 2012 06:17 AM
[crash.net - MotoGP] - Last chance to say ‘Bye Bye Baby' Ninjette Newsbot Motorcycling News 0 March 18th, 2011 11:50 AM
[crash.net - MotoGP] - Valentino says ‘Bye, Bye Baby' Ninjette Newsbot Motorcycling News 0 November 12th, 2010 09:50 AM
[topix.net] - Bye bye Bajaj: Sun sets on Indiaa s beloved scooter Ninjette Newsbot Motorcycling News 0 March 19th, 2010 12:01 AM
