Old March 30th, 2012, 02:00 PM   #1
47ninja
Problems with ignition lock
Has anyone else experienced problems with the ignition lock? Even after I turn my front wheel completely to the left, I am often not able to engage the lock. I twist the key to the left and down, but it doesn't quite turn all the way over to the lock position. I'd say this happens about 90% of the time. The times where it does turn all the way, I am able to lock and unlock repeatedly. Any thoughts?
Thanks.
47ninja is offline   Reply With Quote
Old March 30th, 2012, 02:04 PM   #2
GreenNinja
GreenNinja's Avatar
Name: I'm a ninja!
Motorcycle(s): 2009 Ninja 250
I usually wiggle and the wheel locks somewhere halfway - it doesn't have to go all the way to the left.
GreenNinja is offline   Reply With Quote
Old March 30th, 2012, 02:06 PM   #3
EthioKnight
Super Noob
EthioKnight's Avatar
Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc
After fully turning the wheel to the left, push down and turn the key to the lock position while turning the handlebars a bit to the right. That should do the trick...I hope.
EthioKnight is offline   Reply With Quote
Old March 30th, 2012, 11:07 PM   #4
MikeBudd
MikeBudd's Avatar
Motorcycle(s): RED 2010 Ninja 250r
What they said^
Mine ignition will not lock in the full left position. I just turn it then put the key in and try to lock it and slowly turn the handle bars to the right until it will properly lock
MikeBudd is offline   Reply With Quote
Old March 30th, 2012, 11:48 PM   #5
Pudge Ate Me
2012 Ninja 250R Green
Pudge Ate Me's Avatar
Motorcycle(s): 2012 Ninja 250R Green
Yea I felt stupid for the first week I had mine untill I realized you had to nudge it to the right an inch untill it locks
Pudge Ate Me is offline   Reply With Quote
Old March 31st, 2012, 09:53 AM   #6
47ninja
This works perfectly. Thanks for all the input guys!
2008 Ignition, Fuel Tank, and Trunk Lock Set garth285 Motorcycle-related 7 December 17th, 2016 06:40 PM
Stuck ignition lock corksil 2008 - 2012 Ninja 250R Tech Talk 16 June 15th, 2014 06:12 PM
Bought new triple with ignition but steering lock is on my bike Eltim 2008 - 2012 Ninja 250R Tech Talk 4 August 1st, 2013 10:26 PM
