Go Back   ninjette.org > Marketplace > Motorcycle-related
Old November 29th, 2011, 11:38 PM   #1
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
Helping a friend with a part out! Lots of stuff 08+ all for sale!!
Helping out a good friend
Figured I'd post this on this forum (belong to some 250 forums) in case some of you have 250's and in the event some parts may indeed fit or you're up to some custom work.
Parts came off a 2008 Kawasaki Ninja 250R, should fit other 250 Ninja's in the '08-'12 range, and possibly the earlier generations, but that is upon you to make sure it fits.
Shipping to the 48 States, prices do not include shipping, send zip code for quote, and I accept Paypal. Located near Alton, IL if you want to pickup locally and save on shipping costs.
$225 - Black Rim, blue reflective tape (remove if you want), with new Arromax GT 501 130/70/17 tire.
$Make ANY offer$ shipping will be about $125 - Frame, clean/clear title, "neck" is slight bent, small dent one bar (see pictures below), perfect if you know how to do metal work I don't.
$75Headlight, one of the four tabs is slightly cracked (can barely see in picture below), but still mounts perfectly fine the way it is especially if you were to epoxy glue back together.
$40 - Front Seat
$30 -Rear Seat
$15 - Left underseat fairing
$Make Offer$ - Right underseat fairing, part of plastic peeled/cracked away (see picture below).
$Make Offer$ - RPM Gauge and Fuel Gauge
$20 - Left fairing, 3 cracks
$5 - Left Rider peg (just the PEG)
$35 - Left Passenger peg and bracket assembly
$35 - Right Passenger peg and bracket assembly
$10 - Gauge plate cover, has a tiny crack of the clear plastic window of the fuel gauge spot (far right)
$80 - Complete lock set, one key, ignition still attached to triple tree, fuel tank cap/lock, and rear seat lock/cable.
$35 - Swingarm
$5 - Battery Tray
$10 - Clutch lever
$10 - 4 frame Caps
$15 - Middle tail fairing, goes right behind seat/above tail light, minimal sun fade.
$15 - Front brake caliber with line and brake lever has some damage
$15 - Rear caliber with line
$10 - Rear brake reservoir with line
$20 - Fan Sensor
$5 - Chain Guard
$30 - Radiator Fan
$10 - Coolant Tank
$20 - Shifter Lever Assembly
$25 - Underbody/Undertail Tray/Fairing
$20 - OEM Kickstand with sensor
$25 - Roaring Toyz lowering links (some scrapes on side that faced ground)
$10 - Left clip on
$20 - Engine Cover
$30 - Fuel Tank
Pictures:
(The Speedometer gauge, the middle one in the picture, is sold)
[IMG]http://i234.photobucket.com/albums/ee180/jvello15/2011-11-
Please send Jvello15 PM's guys, I dont have time to focus on the thread. If you dont PM Jvello15 you loose sorry
----> My Youtube! <----
Last futzed with by Kevin2109; November 30th, 2011 at 11:39 PM.
Old November 30th, 2011, 12:33 AM   #2
andylawcc
Motorcycle(s): 2007 Ninja 250 faster red
hummm...... these are good for the pre-gen conversion
andylawcc is offline   Reply With Quote
Old November 30th, 2011, 12:47 AM   #3
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
Hey Kevin, Alex and I agreed I might need a new return cable for my throttle since it wasn't rolling back. Ask your friend if if I can get the cables and for how much?
Also does he have the plastic piece that the complete gauge cluster sets in to that goes around the whole front of the bike?
Trailerboy531 is offline   Reply With Quote
Old November 30th, 2011, 07:54 AM   #4
CynicalC
CynicalC's Avatar
Motorcycle(s): '96 EX250
4 frame caps shipped to 94901?
Ç¥ñ頻| ßÿ Ñâ7µ®é. Äñt¡~§º¢Ïä| ßý Çhøî©è.
Old November 30th, 2011, 07:57 AM   #5
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
I'll take the fuel tank and swingarm. Please let him know.
Old November 30th, 2011, 08:48 AM   #6
Momaru
Momaru's Avatar
Crapsticks. An hour late, wanted to snag the tank since it's a color-match for me.
That said, I'd like to get the rear brake reservoir/line. Shipped to 24060 por favor
Proud member of the Blue Army
Last futzed with by Momaru; November 30th, 2011 at 11:58 AM.
Old November 30th, 2011, 08:48 AM   #7
PlaneGuy
Annoying gadfly
PlaneGuy's Avatar
Motorcycle(s): 2006 Ninja EX250R
Darn. I need more fairing and I need the right side. Oh well.
Brian --
World domination through science!
PlaneGuy is offline   Reply With Quote
Old November 30th, 2011, 09:14 AM   #8
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
I'd also check the spring on your carb bodies. Might be that it just needs some lubricating as it should be strong enough to pull the Pull cable back without the push cable.
k-os is offline   Reply With Quote
Old November 30th, 2011, 09:25 AM   #9
PlaneGuy
Annoying gadfly
PlaneGuy's Avatar
I agree with this 100%. I was having some trouble with the throttle returning to idle and with the idle RPM being consistent. All the problems went away after properly lubing the throttle cable, throttle return cable, and the linkages on the carb bodies.
I use the Protect All clamp-on cable lubing adaptor with LPS-2 lubricant for lubing cables. (I have used LPS-2 and LPS-3 extensively for decades on aircraft hinges and cables. Use LPS-2 for cables and linkages. Use LPS-3 for hinges and fixed fasteners you want to protect from water incursion so you can take them apart again later.)
Brian --
Old November 30th, 2011, 11:39 AM   #10
burningscooter
clutch
burningscooter's Avatar
Motorcycle(s): L1 GSXR600
interested in fuel tank.
price shipped to 21701 please.
thanks
burningscooter is offline   Reply With Quote
Old November 30th, 2011, 11:44 AM   #11
andylawcc
thanks
dude, read above, two ppl are ahead of you.
Old November 30th, 2011, 12:02 PM   #12
burningscooter
clutch
its okay, youre here to read for me.
Old November 30th, 2011, 12:08 PM   #13
andylawcc
haha
Old November 30th, 2011, 12:38 PM   #14
bob706
bob706's Avatar
pm sent - front seat
http://sandollarmotorcycleclub.com/
Old November 30th, 2011, 01:15 PM   #15
Kevin2109
KThanksBye
Kevin2109's Avatar
Please send Jvello15 a PM guys, I dont have time to focus on the thread. If you dont PM Jvello15 you loose sorry
Old November 30th, 2011, 11:35 PM   #16
Jvello15
Jvello15's Avatar
Motorcycle(s): 2007 Ninja 650R
Hey guys, I am the one he's trying to help out. I am a member of the forum but haven't put in my 30 days yet. Feel free to PM me instead of Kevin. I'm waiting to get a hold of Kevin to have him edit in the thread that you guys can PM me as well but you can also take notice that the pictures from above came from my Photobucket account.
Jvello15 is offline   Reply With Quote
Old November 30th, 2011, 11:40 PM   #17
Kevin2109
KThanksBye
Kevin2109's Avatar
Changed it for you jake! Good luck with the sale man, glad I could help out "thumbup:
Old November 30th, 2011, 11:46 PM   #18
Jvello15
Jvello15's Avatar
Thanks a lot Kevin, really appreciate the help!
Frame caps SOLD to CynicalC
Also, for those who were interested in the fuel tank I'd like to apologize. For some reason it did not post the picture of the other side of the gas tank and it is dented.
Old November 30th, 2011, 11:50 PM   #19
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
I'll pass on the fuel tank. It's all yours guys. LMAO!!!
Old December 1st, 2011, 12:04 AM   #20
Jvello15
Jvello15's Avatar
Lol Yeah, sorry to get your hopes up on the gas tank guys. Again I apologize for the picture not working.
Old December 1st, 2011, 12:05 AM   #21
andylawcc
haha.....
Old December 1st, 2011, 12:56 AM   #22
Jvello15
Jvello15's Avatar
then again what did you guys expect for a $30 gas tank lol
Old December 1st, 2011, 06:43 AM   #23
Momaru
Momaru's Avatar
Haha, wow! Makes sense though. I think Nemesis and I (and probably the others interested as well) were thinking "Holy shnikies!, a near-perfect tank for $30, hell yes!"
Thanks for posting the update; afraid I'll be passing as well
Old December 1st, 2011, 07:12 AM   #24
burningscooter
clutch
Were all passing. You messin up J. LOLOL
Old December 1st, 2011, 07:16 AM   #25
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
I call bait and switch!
j/k
Best wishes on the sale.
Old December 1st, 2011, 07:45 AM   #26
Uncool, folks. I'll let this thread stand as people are already buying/selling included items, but Kevin, please don't do this again. There are good reasons why the restrictions are part of our rules here, and I won't overlook it a second time.
Old December 1st, 2011, 07:52 AM   #27
jdoucet93
jdoucet93's Avatar
Motorcycle(s): 2009 R6
Still have the gauge face?
jdoucet93 is offline   Reply With Quote
Old December 1st, 2011, 09:31 AM   #28
Jvello15
Jvello15's Avatar
Thank you Alex. I'm an honest seller and reputable member on other Kawi forums as well. I just need to get these parts out of the garage.
Yes, jdoucet, I still have the guage face. Go ahead and send me a pm and I'll get it weighed and boxed up for an accurate shipping quote and hopefully we can get this in the mail today!
Old December 1st, 2011, 01:27 PM   #29
cerberusrex25
Accesories Guru
cerberusrex25's Avatar
Motorcycle(s): '99 EX250(Cafe/fighter project)
I would like to buy your rear brake disc, both calipers and the 4 frame caps. Also question about the wheel, is it a back or a front? you never specified.
cerberusrex25 is offline   Reply With Quote
Old December 1st, 2011, 01:33 PM   #30
Jvello15
Jvello15's Avatar
Pm'd
Old December 1st, 2011, 01:44 PM   #31
jdoucet93
jdoucet93's Avatar
Pm'd as well.
Old December 1st, 2011, 01:51 PM   #32
andylawcc
probably the rear, as his front is xxxx-ed pretty hard.
Old December 1st, 2011, 02:09 PM   #33
Shaol1n Monk
shaol1n ninja stuntman
Shaol1n Monk's Avatar
Motorcycle(s): 2006 Yamaha YZF R6 Anniversary "Yoshiko" 2007 Honda CBR600RR "Katsumi"(SOLD) 2010 Ninja ZX-2R "JADE" (RIP)
hey is the clutch lever still available??? i need a replacement perch ASAP!
$10 plus whatever it costs to ship as fast as possible.
pm me please
YOSHIKO 06 R6 Flushmount signals,Comp Werkes fender elim,GYTR Carbon Fiber Exhaust,Gold Shorty Levers,Shogun Frame Sliders,custom carbon fiber tank pad,white powder coated wheels,Dunlop Q2 tires
Shaol1n Monk is offline   Reply With Quote
Old December 1st, 2011, 02:23 PM   #34
Jvello15
Jvello15's Avatar
Recently SOLD items:
Front Seat
Rear Brake Reservoir
Frame Caps
Kickstand (sensor + bungee still available)
Gauge face
Rear rim
BOTH passenger pegs/brackets
Undertail/Undertray
Left clip on
Pending Sales
BOTH Calipers & rear brake disc
Pm'd as well.
I will have to send messages to your email now. I guess there is a 20 private message limit and I have exceeded it and can not send anymore for the next 24 hours. Your total will be $17 shipped. PayPal to JakeAvello15@hotmail.com
Edit: Received payment and taking to the post office now. Thanks Josh.
pm me please
Your total will be $16 shipped. Paypal to JakeAvello15@hotmail.com
Last futzed with by Jvello15; December 8th, 2011 at 11:48 AM. Reason: Items sold
Old December 1st, 2011, 05:45 PM   #35
CynicalC
CynicalC's Avatar
oi oi oi hands off my frame caps!
Old December 1st, 2011, 07:20 PM   #36
cerberusrex25
Accesories Guru
Blast you Cynical C, you have foiled me again!!!!
Old December 1st, 2011, 07:22 PM   #37
jdoucet93
jdoucet93's Avatar
Sweet! Ill finally have a green neutral light again instead of just a blinding white light!
Old December 2nd, 2011, 01:15 AM   #38
CynicalC
CynicalC's Avatar
Seriously how many bikes are you building? You should have enough parts now for a fleet!
Old December 2nd, 2011, 10:09 AM   #39
cerberusrex25
Accesories Guru
Just the one, I just keep coming up with ideas.
Old December 3rd, 2011, 12:00 AM   #40
Jvello15
Jvello15's Avatar
Rear rim was sold to abhijitz
Rear tire is now for sale! $90 OBO for damn near new Arromax GT 501 130/70/17 tire! (still has nubs)
Helping out a LEO friend PLEASE pass this along! garth285 Off-Topic 5 October 28th, 2014 05:13 AM
Helping a friend with a clutch plate problem! skilletmo 2008 - 2012 Ninja 250R Tech Talk 109 April 28th, 2013 06:09 PM
helping a friend start her 250, quick battery question. cerberusrex25 1986 - 2007 Ninja 250R Tech Talk 15 July 30th, 2012 07:38 PM
Helping a friend out: water in exhaust! EthioKnight 2008 - 2012 Ninja 250R Tech Talk 33 July 23rd, 2012 06:15 PM
Black 2009 bodywork (new) and LOTS of other stuff for 250s RaceBikeRentals Motorcycle-related 84 April 22nd, 2009 01:29 PM
