Old September 13th, 2014, 02:34 PM   #1
wardie
Motorcycle(s): 06 KLR 650,12 250 Ninja, 86 DR 125, 07 CRF 100, 09 Tomos Streetmate LEL Record Holder, 88 K100 RT
wobble at different speeds
Sometimes when I take my hands off the grips I'll get a wobble which can turn into a tank slapper if I would let it go that far? Doesn't do it all the time and it does it at different speeds. I've checked tire pressure and checked rear wheel to front wheel alignment. I haven't lifted the front end to see if triple tree bearings could be loose nor have I checked the factory balance. Has done it since day one. New non current 2012 with 4K. Anyone else experience any problems like this?
wardie
wardie is offline   Reply With Quote
Old September 13th, 2014, 05:39 PM   #2
Nemy
Nemy's Avatar
Motorcycle(s): 2009 SE Ninja 250R
Since you say you've double-checked the rear wheel, I'd say make sure the chain is adjusted properly and get your tires balanced.
Nemy is offline   Reply With Quote
Old September 13th, 2014, 07:15 PM   #3
https://www.ninjette.org/wiki/Front_End_Wobbles
Old September 14th, 2014, 11:11 PM   #4
BravoDelta
Motorcycle(s): YZF R15, CBR 250R, Ninja 250R, KTM RC 390
Had the same issue and first thought it was due to the worn out tyres. Changed the tyres and the problem did not go off.
the steering stem bearing had worn off and replacing it did the trick for me. i was hoping for damaged bearing cause of the road conditions here. My ninja is on off-road conditions 60% of the time
BravoDelta is offline   Reply With Quote
Steering Wobble Around 50mph 255 2008 - 2012 Ninja 250R Tech Talk 10 May 21st, 2014 04:00 AM
Handlebars wobble Sykes92 General Motorcycling Discussion 20 December 5th, 2013 08:51 PM
rear wheel wobble focus101 1986 - 2007 Ninja 250R Tech Talk 9 July 11th, 2013 05:29 PM
Dies at higher speeds/slowing down from higher speeds TheFranchise216 1986 - 2007 Ninja 250R Tech Talk 67 April 20th, 2012 01:13 PM
[nytimes.com] - Wobble and Weave Ninjette Newsbot Motorcycling News 0 August 27th, 2010 12:40 AM
