Old October 8th, 2014, 06:38 PM   #1
Ninja14
Motorcycle(s): 2012 Ninja 250R Passion Red
Noob question- turn signals
I'm new to this forum so I apologize in advance if it has already been posted.
I have replaced my two front turn signals after bike was dropped and they work fine. a few days ago I awoke to find it knocked over (still not sure if it was due to wind/didnt put side stand down properly/unleveled ground/ or a parked car that was in front knocked it over) but anyways, my left front and rear turn signals were smashed.
I was looking to replace them, and couldn't help but notice that a certain side turn signal is more expensive than the other. STUPID question now: does it really matter if you buy a different side turn signal and install it on the other side? It seems like they are all essentially the same turn signals, no?
Bear with me, I got my bike in May and have only been riding it for 5 months now.
Ninja14 is offline   Reply With Quote
Old October 10th, 2014, 05:52 PM   #2
Nemy
Nemy's Avatar
Motorcycle(s): 2009 SE Ninja 250R
Not a dumb question... otherwise someone would've answered it by now. Sorry but all of my signals have been pulled so I don't have any to compare. Wierd that they're different prices though.
And welcome.
Nemy is offline   Reply With Quote
Old October 10th, 2014, 06:10 PM   #3
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Hate your bike took another tumble.
Depends on what you mean different. Like bulb an led? As long as they have the same wires, bulb type, an similar numbers you should be fine, if you mix LEDs an bulbs you will need a new relay.
The difference in price may reflect build quality, mark up, or many factors.
Hope this helps a bit
Old October 10th, 2014, 06:27 PM   #4
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Welcome.
If I remember correctly, you can flip it over. Try disassembling the on one the bike to see if it will work.
There are a few riders on here who might still have the OEM. They may part with them for a small fee.
Old October 10th, 2014, 07:41 PM   #5
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Left and right turn signals are the same with the VERY minor differences of the drain hole and the color of the plug. When I was fiddling with my lights, I had one OEM signal I was moving around between the four sides.
Where are you seeing the prices? Make sure they are the complete signal vs just some part of it. Could you link it?
<-- Linky
Old October 18th, 2014, 04:58 PM   #6
Linkin
Down Under
Linkin's Avatar
Motorcycle(s): Kawasaki ZXR250C Ninja
The indicators are exactly the same, left and right are interchangeable
Linkin is offline   Reply With Quote
Noob Tire question Harrison89 2008 - 2012 Ninja 250R Tech Talk 7 July 29th, 2012 06:07 PM
Noob Stalling Question ajcadoo Riding Skills 37 March 1st, 2012 03:42 PM
noob ? (sprockets question) Raiders fan General Motorcycling Discussion 3 April 5th, 2011 11:42 AM
Noob Jetting Question 00v_Lucky 2008 - 2012 Ninja 250R Tech Talk 6 July 11th, 2010 06:23 PM
Noob question - regarding jetting Betlog 2008 - 2012 Ninja 250R Tech Talk 5 January 6th, 2010 02:24 PM
