Old November 4th, 2011, 08:42 AM   #1
91satanslegend
Motorcycle(s): 97 ninja 250
what is this hose?
What is this hose coming from the carb and is it important, because i took mine apart and did not see this hose....so im trying to figure out what this is and if its something i need before running the bike...
91satanslegend is offline   Reply With Quote
Old November 4th, 2011, 09:09 AM   #2
Lvr
I'm not sure what you mean by not seeing this hose... you mean you didn't notice if it was connected to anything? It's been a while since I've dug around by carburetors, but I'm fairly certain that's a vent hose, meaning it doesn't connect to anything at the other end
Lvr is offline   Reply With Quote
Old November 4th, 2011, 09:10 AM   #3
Lvr
A helpful way to check is to look for a clamp on the other end. if there is one, it defnitely connects to something. if not, it's probably a vent hose.
Old November 4th, 2011, 09:19 AM   #4
91satanslegend
ok if its just a vent hose, do i need one? or will i be fine without it?
Old November 4th, 2011, 10:03 AM   #5
Lvr
you'll want some length of hose there if it was there before; enough to direct it a bit away from the engine would be my guess. I have a new gen, but on mine the various vent hoses all run back and down to about where the rear shock is.
Old November 4th, 2011, 10:13 AM   #6
JLinde1339
Fighterer in Training
JLinde1339's Avatar
Motorcycle(s): 2001 Ninja 250R
I believe that's a vaccuum hose, or snorkel, as I've heard it referred to as. I may be wrong there. Those two may not be the same thing. But I've heard of people removing their snorkel with no ill effects. Mine is still connected, haven't played with it since re-jetting. But maybe someone can pipe up with absolute correct info on that.
Posted via Mobile Device
JLinde1339 is offline   Reply With Quote
Old November 4th, 2011, 10:16 AM   #7
little fish
little fish's Avatar
Motorcycle(s): 2003 Nija, 1984 es200 ATC
its an overflow hose that comes from the carb bowls . if the float gets stuck the overflow of gas runs out the tube to the bottom of the bike. no "technically" its not needed BUT i would rather have any gas run out under my bike than all over it waiting for a spark. some might argue that without the tube attached an negative presure can occure where the tube attaches and can cause gas to get sucked out. (don't know how true that is but i have heard of stranger things).
little fish is offline   Reply With Quote
Old November 4th, 2011, 10:18 AM   #8
Lvr
The snorkel is the rubber rectangular tube that forms the air intake section of the airbox. It's unrelated.
Old November 4th, 2011, 10:26 AM   #9
91satanslegend
well i had to take the carbs back out anyways because they are still leaking...UGHHH, and i might as well go by ace hardware and fit some tube to the overflow...
Old November 4th, 2011, 10:30 AM   #10
91satanslegend
btw, my carbs leaking, its coming from one of the screws under the carb, nearest the idle knob. could this be a broken seal???
Old November 4th, 2011, 10:47 AM   #11
GateKeeper
GateKeeper's Avatar
Motorcycle(s): 250 Ninja - Soon
broken seal, or a loose screw
before you put the new seal in, were the faces cleaned, no old seal materialwas left, any little bit could cause a leak
careful on tightening the screws, do each one a little bit, and if you can tighten in a criss cross pattern, snug em down, then apply more torque
GateKeeper is offline   Reply With Quote
Old November 4th, 2011, 10:58 AM   #12
91satanslegend
um... im going to go take em apart now, im pretty sure i tightened all the screws and the seals were clean..but they are probably old.
Old November 4th, 2011, 11:24 AM   #13
91satanslegend
here are the pics of the carb bowls.
Old November 4th, 2011, 11:28 AM   #14
blink
Always.
blink's Avatar
Motorcycle(s): '08 Ninja 250, '05 GSX-R600
to snort crack!
blink-182
blink is offline   Reply With Quote
Help Identify hose. BoBO 2008 - 2012 Ninja 250R Tech Talk 2 July 27th, 2014 06:06 PM
Where does this hose go? eric78 1986 - 2007 Ninja 250R Tech Talk 3 May 11th, 2014 06:40 PM
Unknown hose jman511115 2008 - 2012 Ninja 250R Tech Talk 12 July 8th, 2012 05:08 PM
Name this hose WAGESLAVEesc 1986 - 2007 Ninja 250R Tech Talk 10 August 18th, 2011 09:47 PM
What is this hose? caps 2008 - 2012 Ninja 250R Tech Talk 5 June 30th, 2011 04:58 PM
