July 5th, 2010, 01:29 AM | #121 |
Join Date: Jan 2009 Motorcycle(s): 2008 250R (Black) Posts: 298
Yea took the tire off now. Surprisingly easy with the chain. Just loosened the rear axle, took it out and pushed the tire a little forward and the chain was completely loose. Didn't touch the chain tensioner at all, don't know why I was thinking i had to.
Edit. Easy to get the chain back on also. Great DIY once again Kelly! Bridgestone 140/70, love it! Last futzed with by Guinss; July 6th, 2010 at 01:21 PM. |
October 18th, 2010, 04:47 AM | #122 | |
Join Date: Nov 2008 Motorcycle(s): Ninja 250R 2009 Posts: A lot.
Here's the tire tool I used: One other note, my chain guard touched the new tire, so I placed a 3/16" thick washer (actually a cantilevered brake washer off one of my grand children's bike) between the chain guard and it's mounting hole. That resulted in the chain guard clearing the tire by about 1/2". |
October 18th, 2010, 10:42 AM | #123 |
That is so simple, it is genius.
October 18th, 2010, 05:31 PM | #124 |
Haha, I wish you posted that a couple of weeks ago. I dremeled a notch into the chain guard.
October 19th, 2010, 03:29 AM | #125 |
^^^Exactly what I was going to do, until I saw how much it flexed with hand pressure!
October 25th, 2010, 09:58 AM | #126 |
I only have a socket for the axel bolt side and not the axel nut side. Does it matter which end I torque the rear axel from?
October 25th, 2010, 10:04 AM | #127 | |
This is just IMHO. I have no reference for this. |
October 25th, 2010, 10:09 AM | #128 |
There's not a whole lot of science to this anyway. Seems that every time I torque an axle nut, it never falls on the alignment hole to insert the pin. You have to decided whether to go forward or back off a bit to align the hole. All tend to go forward.
October 26th, 2010, 12:26 PM | #129 |
WTH am I doing wrong?! I can't get the tire back onto the rim. I get one sidewall over and it looks very much like kkim's pic with the remaining sidewall very close to the rim, but I can not for the life of me finish getting the second sidewall over. I start it and make my way around but eventually each pry I make makes an equal or larger part of the sidewall slip back out on the other end. Also, by that point, the remaining sidewall has risen inches above the rim! It's very frustrating. I've been prying and slipping and cursing and sweating all morning.
October 26th, 2010, 12:37 PM | #130 | |
October 26th, 2010, 01:09 PM | #131 |
Both. I now have this to show for it.
IMG_0044.jpg IMG_0045.jpg As many times as I slipped and damaged the rims (even with protectors), i guess it was only a matter of time. |
October 26th, 2010, 01:38 PM | #132 | |
Do a YouTube search for "scudman" and look for his removing and mounting video. I found these helpful when I started changing my tires. I can change one now start to finish in about 5 mins. I hope your working with good tools though. Makes a ton of difference. I picked up a 3 piece tire iron set at cycle gear. Work perfect. Don't give up. You'll get it. It sounds as if you need to keep good pressure on the sidewall closest to you with your knee's while you slowly take small bites of tire and pry it over.
October 26th, 2010, 01:43 PM | #133 |
Wow, that's funny... I was just going to say the same exact thing. It was these videos, along with Kelly's DIY that gave me the confidence to do it.
October 26th, 2010, 01:55 PM | #134 |
CZroe,
what type of lube are you using? be sure the lube is where the edge of the tire slips over the edge of the rim when you're levering it on. Also, too much lube will actually make the job more difficult as things will slip and slide out of position too easily. Use small bites of tire and keep your starting point levered with one tool... so in essence, you need three levers when things get difficult. one other trick... when you get about halfway mounted, make sure the portion of the bead that's already on the rim is pushed down toward the center of the rim in that "well"/center section of the rim so it gives you a bit more wiggle room on the section you're working on. |
October 26th, 2010, 02:01 PM | #135 |
I've watched scudman and watched him again when I started having trouble ("if you're working hard, you're doing it wrong"). I weigh a lot and yet I can barely squeeze it down with all my weight, much less when I start applying some to the tire irons. I've bruised my knees with all the pressure I've applied. It seems that no matter what, it pulls my end up away from the middle when I get anywhere near the opposite side.
Well, I've damaged my rims more since the road hazard that caused all this and now my body (it will leave a scar), so I'm throwing in the towel for now. I'll practice later with my old tires and rims. |
October 26th, 2010, 02:24 PM | #136 |
Get some of this:
http://shop.advanceautoparts.com/web...%7CGRP2068____ I was able to get the first side on without tools on both the front and rear BT-016 tires. The last side is a PITA, but with knee pressure and prying. it can be done. |
October 26th, 2010, 03:15 PM | #137 |
One trick I use for mounting is to leave the new tire in the sun for a bit.... this of course softens it up a bit.
The trouble you are having is the reason I am in the process of building a tire station. It will be a happy day when I don't need to use tire levers/spoons!
October 27th, 2010, 11:33 AM | #138 | |||
What are the torque values and socket sizes for the axle nuts anyway? Can we get them edited into the OP?
I think the axle nuts are 22mm front, 24mm rear. Very diluted dish detergent in water. Quote:
http://www.ninjette.org/forums/showp...6&postcount=37 |
October 27th, 2010, 01:58 PM | #139 |
Look for this in Napa stores in CA:
Napa locations here: http://www.napaonline.com/Locator/Re...&ZIP=&st=STORE |
October 28th, 2010, 01:54 AM | #140 |
kkim: can you edit the OP to reflect 17mm/22mm 65 ft lb front and 17mm/24mm 72ft lb rear specs? That's also 9 kgf m front and 10 kgf m rear for you metric nuts.
October 28th, 2010, 09:30 AM | #141 | |
October 28th, 2010, 10:39 AM | #142 |
sorry, I can't edit the OP as Alex has things set up so people can't edit their posts after a certain amount of days.
October 28th, 2010, 07:48 PM | #143 |
All set, it's been edited.
October 28th, 2010, 10:05 PM | #144 |
April 10th, 2011, 03:54 PM | #145 |
ModMy250.com
Hey guys. I'm having a heck of a time installing the rear 150 tire on. I was able to get the front on and was using the same techniques for the rear; taking small bites while keeping pressure down on one side. It's just not working. I get to a point where I can hear the tire ripping. Any advice? I should also add I've watched youtube videos and read thru the diy. I'm also using the camel lubricant on the part that slides over the rim.
EDIT: Nevermind. I finally got it! . I had to just make sure the tire was pushed down into the well more so the other side would slip over. Yay. I can put it back together and commute with it tomorrow.
The www.ModMy250.com guy Last futzed with by CThunder-blue; April 10th, 2011 at 06:03 PM. |
April 11th, 2011, 09:30 AM | #146 |
You've got air in the line. Look up the procedures for bleeding it. Also, make sure you clean it up because it eats paint and most plastics.
April 11th, 2011, 11:14 AM | #147 |
ModMy250.com
BTW, I used the HF bead breaker and it worked great. Paid $25 for it. You could probably pay less if you use the 2x4 method, but then you have to cut pieces up, measure, and put it together. I had the tool out of the box and assembled in 1 minute since it comes in 2 parts. It would be nice if they drilled holes so you could mount it to something, but I can do that myself. I also picked up the wheel balancer for $50 and that worked out nicely as well. I had to adjust the bars so that they were level and sprayed some wd40 on the wheels, but well worth it. No need to jerry rig something.
The www.ModMy250.com guy |
April 11th, 2011, 11:26 AM | #148 | |
April 11th, 2011, 11:59 AM | #149 |
ModMy250.com
As long as they keep their machines calibrated, that's cool.
April 12th, 2011, 08:16 PM | #150 |
Join Date: Sep 2010 Motorcycle(s): TR7, Trident, SuperIII, BMW, HD, Duc, Vespa, MP3 Posts: 83
Rear tires are always harder than fronts - stiffer. New stiff tires are always harder to put on than old clapped out tires to take off (my experience anyway). I think rear tires are 2x harder to do than fronts. IIRC, scudman's youtube vids, and most of the others, are always fronts - I wonder why.
Usually after I wrestle a front tire off and back on, paying someone (or finding a friend with a no-mar or hf changer to take a donation) to do the rear is looking pretty good. At least you save 50% of the cost of mounting a set of tires and saves many bruises. Even having a solidly mounted rim clamp to a bench makes quite a bit of difference, which I don't. The bigger and heavier the tire, fatter the rim, the worse, or nearly impossible, it is with spoons. For me anyway. A 190 on a 6+ inch rim even takes some skill on a manual changer. Still, it is sick to see how easy it is to do normal sized tires and rims on the most basic manual no-scratch tire changer. Every time I buy a set of tires and change the front I learn this over again the hard way Then I contribute to the local economy to mount the rear.
2010 Ninja 250R SE - I got this bike for my wife. It was a good trade. |
April 16th, 2011, 01:43 PM | #151 |
ex-ninjette.org guru :o
Join Date: Jun 2010 Motorcycle(s): 2003 SV1000 S Posts: 475
service manual says to use a new cotter pin on reassembly, is this necessary, or can I get away with reusing it. It's not that I'm cheap, I just don't have any here so I'd have to go pick a couple up...
April 16th, 2011, 01:48 PM | #152 |
I've reused mine before, but if it looks like it's about to break at the "bend" line, definitely replace it when you get the chance.
I try to be very careful to not overstress the cotter pin when removing it. That helps to keep it in a reusable condition, if you need to. |
April 16th, 2011, 02:28 PM | #153 | |
any final words of wisdom to someone that's never had the wheels off a bike before? |
April 16th, 2011, 02:42 PM | #154 |
If you're handy, it's not so bad. If you have a bike friend to help, it's much easier. The project on on what you are trying to do once they're off should probably be most of the work. Reinstalling the rear axle in from R to L is easier (opposite of OEM) unless you have a dummy dowel or something used to align from R to L that you'll drive out if you choose to put the axle back in L to R.
April 16th, 2011, 02:47 PM | #155 |
I would plan to change only one tire at a time. It's going to take longer than you expect, especially if this is your first time doing this.
plan for X amount of hours, budget for double that. to make installing the new tires easier, heat them outside in the sun, first... the longer the better... hours, if you can plan it that way, to make them more pliable to work with when it comes time to actually install them. double check, when you get ready to install the tire on the rim, that you have the tire orientated in the proper rotational direction. It's a bitch to completely mount the tire and then find out you've installed it backwards. Ask me how I know!!! gl... take your time and have fun. |
April 16th, 2011, 02:48 PM | #156 |
Don't forget tire lube and rim protectors. Might help to have three hands.
If it becomes frustrating, having a place to take them to mount if it becomes too much is a good plan B.
April 16th, 2011, 03:34 PM | #157 |
i'm chickening out and getting a local guy that has a no-mar tire changer to do it. he's doing them for 20/wheel which isn't too bad. I still have to get the wheels off and stuff, so I'll be doing that tonite. I'll see how he does them with the machine and see if I want to invest in one (or make one, since I can weld pretty well), looks a lot easier than doing with spoons by hand.
April 16th, 2011, 03:42 PM | #158 |
lol... I learned to do this as a poor, no money high school student. I had no options.
April 16th, 2011, 04:04 PM | #159 |
hey, the axle nuts are reverse thread are they? I can't get it to budge
April 16th, 2011, 04:07 PM | #160 |
DIY EFI KIT for our 250r | forbitel | 2008 - 2012 Ninja 250R Tech Talk | 331 | January 30th, 2024 07:03 PM |
Tires changing colors | Sirref | General Motorcycling Discussion | 42 | June 21st, 2014 09:16 AM |
changing tires | oompa | 2008 - 2012 Ninja 250R Tech Talk | 8 | April 21st, 2014 02:02 PM |
DIY - Changing jets WITHOUT removing the carburetors | VeX | 2008 - 2012 Ninja 250R Tech Talk | 22 | May 29th, 2012 04:39 PM |
DIY on washing my 250r? | SF-Dug | General Motorcycling Discussion | 116 | March 9th, 2012 10:23 AM |
