Old October 16th, 2013, 06:09 PM   #1
red5
red5's Avatar
Motorcycle(s): 09 ninja 15.256
PSA - Check your engine covers.
Dropped a shim down the timing chain channel tonight. F**K! I fished around with a magnet for a bit with no luck so had to pull the cover. The two bolts that attach the clutch cable hanger were reasonably tight but all of the others were way loose. Not quite so loose that I could have gotten them out without a wrench but almost. Checked the the other side and most were about the same.
Pretty sure they had never been removed by the PO. So they were torqued during assembly and the gaskets settled a bit?
"We're not always doing business, but we're always open."
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." Carl Sagan
red5 is offline   Reply With Quote
Old October 19th, 2013, 11:50 PM   #2
Good info.
Old October 20th, 2013, 07:58 AM   #3
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
I have an '08 with 8,300 miles on it. In the midst of air box removal/rejet/sprocket swap and checked this yesterday. With an 8mm nut driver, the left side cover was reasonably loose, as in I could tighten the bolts with little or no force. Not sure of torque spec, but I would say they needed to be tighter. Will follow up with torque spec if I can find one.
Thanks~
Old October 21st, 2013, 08:18 AM   #4
red5
red5's Avatar
Thanks~
87 in lbs
Old October 21st, 2013, 02:18 PM   #5
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
You beat me. Thanks.
PSA: check your shifter bolt once in a while Jax1512 2008 - 2012 Ninja 250R Tech Talk 65 June 14th, 2019 02:23 PM
Engine case covers needed for track 300? kalleh Ninjettes At Speed 2 February 13th, 2015 04:17 PM
PSA - Check your master links csmith12 General Motorcycling Discussion 42 May 9th, 2013 09:12 AM
Check out my DIY engine stand headshrink 2008 - 2012 Ninja 250R Tech Talk 4 January 1st, 2012 12:08 AM
[motorcyclistonline] - GB Engine Covers | MC Hammered Ninjette Newsbot Motorcycling News 0 July 20th, 2011 11:20 PM
