Old June 4th, 2011, 09:42 PM   #1
08ninja250
08ninja250's Avatar
Motorcycle(s): 2008 ninja 250
BT 003 RS Pressures
Hey Guys,
Im running a 110 front and a 150 rear on my race 250. What pressures are recommended for a hot tire?
Colin #191 - Area P, Elka Shock, Woodcraft Clip-Ons and Rearsets, Attack Race Bodywork, BT 003RS, .700 Fork Springs, DynoJet Stage 2 and BMC High Flow Air Filter.
613 MOTORSPORTS.COM
08ninja250 is offline   Reply With Quote
Old June 4th, 2011, 10:06 PM   #2
V2Neal
Bad-ass 250 racer
V2Neal's Avatar
Motorcycle(s): Ninja 250r, ATK 605, Honda CR250R
Pretty sure Stick told me 28/28 hot off the track.
CRA #28. Just wave as you go by!
V2Neal is offline   Reply With Quote
Old June 4th, 2011, 10:10 PM   #3
08ninja250
08ninja250's Avatar
Ok thats what I thought and what Ive been running
Thanks!
613 MOTORSPORTS.COM
Old June 5th, 2011, 10:24 AM   #4
Rexbo
CVMA / AFM / M1GP #250
Rexbo's Avatar
Motorcycle(s): 2009 Ninja 250r, 2011 Zero S, 2009 KLR 650
Yeah I've been running between 26-28psi in the rear tire depending on the track & temp. Found that dropping the pressure helps a bit when the track is bumpy or slippery but the higher pressure makes it a little more predictable.
Rexbo is offline   Reply With Quote
Old June 5th, 2011, 10:49 AM   #5
ztrack157
The Sportisi Master
ztrack157's Avatar
Motorcycle(s): 2008 Ninja 250
I set 25 and 25 cold and leave it
Sportisimoto USA is born.
ztrack157 is offline   Reply With Quote
Old June 5th, 2011, 12:27 PM   #6
08ninja250
08ninja250's Avatar
Rexbo, is that hot or cold?
613 MOTORSPORTS.COM
Old June 5th, 2011, 02:21 PM   #7
Rexbo
Rexbo's Avatar
hot... measured either on the warmers (before they got stolen) or right after comin off a session.
Funny thing is, with my pirelli front tire, it works best at like 23-24 psi hot, guess they're all a little different
Old June 5th, 2011, 07:49 PM   #8
ztrack157
The Sportisi Master
ztrack157's Avatar
Steven that lower than the pirelli recommended pressure of 31 hot I run 29 hot with the pirelli which is what my champ runs what works for him must work for me. I will note that you probably don't push the tires to the limit as hard as him or Bartlow does those tires are uber sticky
Old June 5th, 2011, 07:54 PM   #9
Rexbo
Rexbo's Avatar
Maybe... I started out at the 30psi but the front tire would keep chattering at chuckwalla, so I gradually aired it down and it just kept feeling better and better. It didn't feel nearly as planted at buttonwillow though, so maybe airing it back up would have helped there.
Old June 5th, 2011, 09:05 PM   #10
ztrack157
The Sportisi Master
ztrack157's Avatar
That chatter is suspension related not the tires. We will get it fixed when your up here next month.
Old June 13th, 2011, 12:27 AM   #11
ratlab
ratlab
ratlab's Avatar
Motorcycle(s): gsxr1000,R3x2,RC390,FZ07,XR100
25-25 cold for bt-003rs -that's only 3 degrees hotter coming off the track-on my 1000 i run 19-30 cold -dunlops- i am clueless about this little bike stuff-this forum is great
ratlab is offline   Reply With Quote
Old June 15th, 2011, 08:42 AM   #12
JS73
JS73's Avatar
Motorcycle(s): 08 Ninja 250
Yep, 28/28 hot off the warmers.
WERA #273 Novice
Boogeyman Racing.
JS73 is offline   Reply With Quote
Old June 15th, 2011, 03:47 PM   #13
sowega
sowega's Avatar
Motorcycle(s): 899, 748, 250, 250, 70
26.5 on both, fresh off the warmers.
sowega is offline   Reply With Quote
Old June 20th, 2011, 03:41 PM   #14
SPG
Motorcycle(s): 250 Ninjette
Holy crap! I have been running mine around 28/29 cold or 34/34 off the warmers. I had no idea I could run them that low.
Are you guys running the 28 or 26 hot pressures experiencing any negative side effects? I like stable and predictable (who doesn't in a tire), but my stable predictable bike just chattered it's front tire off of the track last weekend and I'm looking for ways to avoid it in the future.
Running 110/140 for what it's worth and the tires have about 12 track/race days on them.
-Sean
SPG is offline   Reply With Quote
Old June 24th, 2011, 07:20 PM   #15
Rexbo
Rexbo's Avatar
-Sean
Could be the fact you got a lot of track days on them, could be that you're running psi too high, or your front springs are too soft (bottoming) or too stiff (not enough travel), then maybe its the bridgestones (I don't like them) and possibly your rear shock is too soft. Lots of options
Old June 24th, 2011, 07:56 PM   #16
randy328
CMRA Mini Endurance #6
randy328's Avatar
Motorcycle(s): CBR954, CBR600RR, EX250
Bridgestone rep down here in Texas recommends 29f/26r hot.
randy328 is offline   Reply With Quote
Michelin Pilot Street, any experience with good pressures? verboten1 2008 - 2012 Ninja 250R Tech Talk 21 June 2nd, 2014 02:27 PM
[motorcyclenews.com - news] - How often do you check your tyre pressures? Ninjette Newsbot Motorcycling News 0 June 12th, 2013 12:40 PM
Pressures for Bridgestone BT090 R DOT Race tires tooblekain Ninjettes At Speed 2 September 4th, 2012 08:01 PM
finding the right pressures alex.s General Motorcycling Discussion 14 May 4th, 2012 06:40 PM
Tire Pressures? BT003 Jam3s 2008 - 2012 Ninja 250R Tech Talk 8 May 14th, 2010 03:51 PM
