Go Back   ninjette.org > Marketplace > Motorcycle-related
Old October 9th, 2015, 01:55 PM   #1
windingroads
Motorcycle(s): 1989 GL1500 Goldwing
1998 CDI, regrect, harness, coils, etc
I'd like to sell off the electricals from this bike as a clump. The box will include the CDI, solenoid, reg/rect, coils, and complete wiring harness ... $100 includes shipping anywhere in the lower 48 states. PM if interested.
windingroads is offline   Reply With Quote
Old January 3rd, 2016, 06:05 AM   #2
Waldo1
Waldo1's Avatar
Motorcycle(s): 00 and 02 RC51, 90 ZX7
Do you still have these items for sale?
Unregistered helped me
Waldo1 is offline   Reply With Quote
Old January 5th, 2016, 07:21 AM   #3
kxpower?
kxpower?'s Avatar
Motorcycle(s): Ugly 89 frankenstien special ex250, and the "Zooks" : 1982 GS450 and 1979 GS1000
Hey @Waldo1 I have a lot of this on a bike I'm stripping, anything in particular you're after? Or just the whole shooting match?
Oh god the bikes are multiplying!!!
kxpower? is offline   Reply With Quote
Old January 5th, 2016, 08:41 PM   #4
Waldo1
Waldo1's Avatar
My son has a mid 90s and we have never gotten to run correctly. It will not idle. If you keep the RPMs above 3,000 it runs great. I have done a compression and leak down test with great results. I have gone through the valves many times. I have had others double check my work. I have ultrasonic cleaned the carbs and bought all new needs, jets, float needs and emulsion tubes. I am thinking at least replacing the carbs with known goo running carbs.
I am also thinking there might be a problem with the electrical system (CDI, Pick-up and coils).
If you still have any of these items I would be intereted.
Old January 19th, 2016, 03:37 PM   #5
Waldo1
Waldo1's Avatar
kxpower have you considered my situation?
Old January 21st, 2016, 07:56 AM   #6
kxpower?
kxpower?'s Avatar
Sorry Waldo I've been working on a couple Suzuki's and hardly get on here anymore!
Mine never was very happy idling below 3,000 or so, a lot of these bikes just seem to like having the idle set high. Is that the only problem you're having?
I saw this thread: https://www.ninjette.org/forums/showthread.php?t=192558 , are you still chasing those symptoms? Have you determined whether it's fuel or spark related? Sound like you've got no problem in the compression department.
My off the cuff thought is that if it's still an ignition issue causing your problem I'd be looking very closely at your battery. At low RPM's the charging system isn't really doing much and a weak battery could cause a weak spark condition.
If it's the same issues let's revive your old thread in the tech section. We'll get you figured out.
Old January 21st, 2016, 09:00 PM   #7
Waldo1
Waldo1's Avatar
We never figured it out so my son bought an F4i. I have responded in the OG thread. I was leaning towards the ignition problem. I think at this point I will replace the coils, CDI and pickup coil. The battery is tops. It maintains volts and load when tested.
Old February 8th, 2016, 01:59 PM   #8
kxpower?
kxpower?'s Avatar
I put the harness with all the goodies up on ebay, here's the link if you're interested:
http://www.ebay.com/itm/262273530815...84.m1555.l2649
Old February 8th, 2016, 09:23 PM   #9
Waldo1
Waldo1's Avatar
Does is come with the pickup coil (59026-1086 COIL-PULSING)?
Old February 9th, 2016, 04:44 AM   #10
kxpower?
kxpower?'s Avatar
I have one, it's yours. I'll need to pull it out of a bad motor so it might be a couple days (Tuesday or Wednesday next week) before I can ship it all out.
Old May 18th, 2016, 07:46 PM   #11
Waldo1
Waldo1's Avatar
Well I picked up a set of carbs which I was told came from a running bike. That did not fix my problem. We tried the CDI but they are not the same. I guess the next step is to swap the entire harness over and see if that fixes it.
The one off my son's bike is the one on the left
Old May 19th, 2016, 07:35 AM   #12
kxpower?
kxpower?'s Avatar
OK so you have the 21119-1233? I had a few of these around, I may have the 21119-1233. I'll dig around in storage and see if I can put my hands on it tomorrow. I had to use the wrong one on mine, just re-pinned the connector on the harness and made a couple of jumpers. There's half a dozen different ignition module part numbers for various pre-gen model years.
I though you said in the other thread that you had corrected the problem? You couldn't get it to idle down? Could you re-state what exactly is wrong at the moment? I had a 5,000+ RPM idle on my gs450 (also a twin with CV carbs), and it turned out at some point I had knocked the butterflies out of sync. 15 minute bench sync and it purred like a kitten, after chasing the problem around for 2 months.
Old May 20th, 2016, 06:36 PM   #13
Waldo1
Waldo1's Avatar
Is there a way to re-wire my current system to use the CDI you sent? I guess I could just replace the whole harness.
I am trying to get the bike to run below 3k and/or idle. Still have not fixed the problem.
Two different sets of carbs and still have the same problem.
Old May 22nd, 2016, 07:46 AM   #14
kxpower?
kxpower?'s Avatar
Discussion continued here: https://www.ninjette.org/forums/show...13#post1105413
DIY - Replace the '08+ CDI (Ignitor) with the '88-94 CDI g21-30 2008 - 2012 Ninja 250R Tech Talk 177 April 11th, 2022 05:19 PM
2011 OEM Wiring Harness ECU Coils etc. MINT Shadowwolf1117 Motorcycle-related 0 May 6th, 2015 12:15 PM
Wire harness gutted and made in to race harness smokinsingle 2008 - 2012 Ninja 250R Tech Talk 13 October 15th, 2014 07:01 AM
wiring harness and pregen cdi thomason2wheels 2008 - 2012 Ninja 250R Tech Talk 10 November 13th, 2012 08:50 AM
