Old March 14th, 2012, 03:32 PM   #1
Brake light Harness. Which wire is which?
Hey guys I'm looking to get a brake light modulator from @CThunder-blue and use it for my pregen. Tri is going to see about putting on the right harness for me so that his modulator is plug and play for the pregen. This will benefit other pregen owners as well, because his modulator is adjustable, works with incandescent bulbs, and is reasonably priced, so I have a favor to ask of you guys and gals who own pregens.
Can someone take a couple clear pictures of the 3-pin harness that your brake light plugs into? The hope is that it is the same as the connector that the one used on the newgen 250R's so all Tri has to do is plug the wires into the connector in the right positions.
Also, I would like clarification on which wire does what;
  • blue wire = brake light 12V
  • red wire = running light 12V
  • black/yellow wire is the ground
Correct?
This is the only picture I can find on the faq.ninja250.org wiki, and it only shows one side of the connector. I want to get as many pictures as I can to make sure Tri has all the info he needs.
I really appreciate all the help I can get on this guys
EDIT: The flasher from modmy250.com works great!! Highly recommended!
Last futzed with by choneofakind; April 5th, 2012 at 06:54 AM.
Old March 15th, 2012, 11:47 AM   #2
Well it turns out this was enough info for Tri. I'm pretty confident on the wiring. If it's wrong, I'll swap the wires till they're right.
I ordered it from Tri today, and when I'm home over break, I'll hook it up and test it out, and let you all know how it goes
Old March 26th, 2012, 12:12 PM   #3
Sekter1
Motorcycle(s): Ninja 250 F-18
Looking forward to seeing how this has worked out for you!
Sekter1 is offline   Reply With Quote
Old March 26th, 2012, 12:19 PM   #4
Same! I'll be able to test this out next weekend (Easter weekend), not this weekend. I'll keep you posted with results.
Last futzed with by choneofakind; March 26th, 2012 at 02:53 PM.
Old March 26th, 2012, 02:39 PM   #5
Xer0-
Motorcycle(s): 06 250 rat, 20 400 krt
Same! I'll be able to test is out next weekend. I'll keep you posted
I'm interested in one too. Is the cost the same as the one for current ninjas?
Xer0- is offline   Reply With Quote
Old March 26th, 2012, 02:51 PM   #6
It's $37.00. Very reasonable, considering it's the only one that doesn't have to flash a million times, is small and easy to install, and works with either incandescent bulbs or LED's.
Not to mention, I'd buy from Tri over a random online store any day.
NOTE: I edited the original post to include a link to the lighting page on Tri's site, where you can find his modulator
Old March 30th, 2012, 04:20 AM   #7
CynicalC
CynicalC's Avatar
Motorcycle(s): '96 EX250
For all you DIYers, this might be of interest.
http://www.sentex.net/~mec1995/circ/motflash.html
Or
http://autolumination.com/1156_1157.htm Look for "THE BRAKER FLASHING BRAKE LIGHT BULB", a little less than half way down the page, above "THE BRAKER FLASHING LIGHT MODULE"
Might be worth a shot for $6?
Found these on another forum while searching for a DIY modulator.
Ç¥ñ頻| ßÿ Ñâ7µ®é. Äñt¡~§º¢Ïä| ßý Çhøî©è.
Old April 5th, 2012, 06:52 AM   #8
@CThunder-blue thanks so much for working with me on this one. I love the flasher.
everybody!! It works great!
I've got it flashing twice, and then staying solid. Still not sure whether I should make the time until re-activation 0 seconds or 15 seconds. Thoughts on this?
Last futzed with by choneofakind; April 7th, 2012 at 08:49 PM.
Old April 6th, 2012, 12:14 PM   #9
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
That's good to know Chris! I would go with the 15 second delay. Having it strobe constantly will get annoying to people.
The www.ModMy250.com guy
Old April 7th, 2012, 08:47 PM   #10
Haha I'll fiddle with that next time I'm home. Don't really feel like playing with it right now. You should add that onto your site so we all can buy them from you. Great product. I installed the ninjette.org vinyls as well. They look smashing
Tri is the man people!!
Old April 8th, 2012, 07:15 PM   #11
CThunder-blue
ModMy250.com
Wire harness gutted and made in to race harness smokinsingle 2008 - 2012 Ninja 250R Tech Talk 13 October 15th, 2014 07:01 AM
Wire integrated tail light such that the brake light stays off while signal flashes? CZroe 2008 - 2012 Ninja 250R Tech Talk 6 March 4th, 2012 06:36 PM
