Old March 24th, 2012, 03:15 PM   #1
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Lubricating Cables...
How do you do it? Kawasaki suggest dripping motor oil? That sounds difficult? How about using these? I've heard some people don't lube them at all...what happens if I don't?
Motion Pro Cable Luber
What do you guys use to lubricate your cables?
Old March 24th, 2012, 03:18 PM   #2
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
Use the Motion Pro tool and Dupont Teflon.
k-os is offline   Reply With Quote
Old March 24th, 2012, 03:20 PM   #3
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Just out of curiousity, can I use WD-40...
I have another question, how do I tell how much fuel I have and can use?
Old March 24th, 2012, 03:27 PM   #4
k-os
Don't use WD40. WD = Water Displacement. It's not the best lubricant. If you're really concerned about how much fuel you have left you'll have to keep track of how many miles you get on a tank (assuming your KLX has a speedometer and odometer).
Old March 24th, 2012, 03:28 PM   #5
WD 40 is great for cleaning the cables. To lube the cables, use teflon lube.
Old March 24th, 2012, 03:38 PM   #6
Some good info in the Similar Threads section below.
Old March 24th, 2012, 07:24 PM   #7
00NissanNinja
I hate driving...
00NissanNinja's Avatar
Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12)
Same, but I use Triflow smooth as slipping on ice
09 ninja 2fiddy SE Driving slow things fast
00NissanNinja is offline   Reply With Quote
Old March 24th, 2012, 07:32 PM   #8
The frequency is more important than the method or lubricant.
Lubricating the interior is not enough; the pivots at the ends and any surface against which the cable rubs, as well as the levers, need periodic attention, specially if the bike is exposed to rain.
Old March 24th, 2012, 07:44 PM   #9
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Can I use the Teflon lube on the pivots as well? How about the other parts of the bike. For example, can I use it on the rear brake?
Old March 24th, 2012, 11:55 PM   #10
Keep anything besides brake pads off the rotors. If you get anything on the rotors, it will soak into the pads, and will make your brakes pretty much useless.
Last futzed with by choneofakind; March 25th, 2012 at 07:09 PM. Reason: the 16 year old grammar nazi...
Old March 25th, 2012, 04:42 PM   #11
You could but grease that is resistant to be washed away by water and rain will work better.
The manual recommends Molybdenum Disulfide grease.
Brakes are a different story, they require brake high temperature grease in very small amounts on the slider pins only
Old March 25th, 2012, 04:48 PM   #12
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
keep anything besides brake pads off the brake. If you get anything on the disks, it will seep off into the pads, and will make your brakes pretty much useless.
Your grammar confused me.
Old March 25th, 2012, 06:53 PM   #13
huh? maybe take "off" out of my post and capitalize the first letter, but besides that, it's a solid sentence...
Old March 25th, 2012, 07:01 PM   #14
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
I don't know. Just confusing me lmao
Old March 25th, 2012, 09:00 PM   #15
This is how I understand choneofakind's statement:
Keep rotors and brake pads as clean as a surgical room.
Both get very hot during braking and can melt any regular oil or oil-dirt mix that is close enough, which could find its way into those critical surfaces.
The friction material of the pads tends to absorb any contaminant, which can reduce the friction capability permanently and also deteriorate the material itself or glue that joints it to the metal back-plate.
Water from the road splashing or rain gets evaporated due to the high temperatures, causing no permanent damage.
The pistons of the brake get automatically lubricated with the brake fluid and require no extra lubrication.
However, they should be cleaned up during brake service or pad replacement.
The levers and sliding pins of both brakes are the only mobile parts of the systems that should be lubricated as explained above.
Old March 25th, 2012, 09:04 PM   #16
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
I get it now
Old March 25th, 2012, 09:53 PM   #17
A+
didn't think I was the new coondog...
nick, I edited my post so you can understand it
Old March 25th, 2012, 11:15 PM   #18
and if they are old and rusty on the end or dirty when you push the pistons back in while changing pads, especially if you have ****** old nasty brake fluid in there it's possible to seize your pistons. which can mean your brakes get locked on and get hotter and hotter until they melt your caliper... i think @Nemesis has photos of this?
Old March 26th, 2012, 06:28 AM   #19
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
It's the other Asian (Dean) who has the photos, foo!
Old March 26th, 2012, 08:40 AM   #20
damn. i'm a racist.
Old March 26th, 2012, 10:23 AM   #21
blink
Always.
blink's Avatar
Motorcycle(s): '08 Ninja 250, '05 GSX-R600
Why do you have to lube cables?
blink-182
blink is offline   Reply With Quote
Old March 26th, 2012, 10:34 AM   #22
why do you have to lube your engine?
Old March 26th, 2012, 10:50 AM   #23
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
damn. i'm a racist.
No wonder you only talk & hang out with Kevin & Max. Then again you could be a Racist Gay.
Old March 26th, 2012, 10:53 AM   #24
some day ill turn my IST into an ER!... someday. maybe then ill be cool enough to hang out and eat the sweet korean BBQ
p.s. jon, i want one of those socalmoto stickers!!! my 5 posts on scm make me a viable advertiser, right? :P
Old March 26th, 2012, 11:13 AM   #25
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
No cuz you're a racist. I don't handle out decals to racist. Try hitting up Inde...he's white and can give you one. =P
Old March 26th, 2012, 11:36 AM   #26
Old March 27th, 2012, 10:27 AM   #27
blink
Always.
blink's Avatar
what cables, are we talking about is my question...
obviously it makes no sense to lube plastic
blink-182
Old March 27th, 2012, 10:39 AM   #28
it sounds like you are confusing electrical wiring with control cables. like the things that connect your throttle and clutch to your carbs and transmission.
Old March 27th, 2012, 11:54 AM   #29
blink
Always.
blink's Avatar
Yes, thank you
blink-182
Old March 27th, 2012, 02:10 PM   #30
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Yeah. Alex.s got it. I'm going to get the Motion Pro Luber and Lube.
Old March 27th, 2012, 03:24 PM   #31
I use the motion pro luber. Make sure to get some paper towels too. Gotta catch the excess out the bottom
Old March 27th, 2012, 08:15 PM   #32
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Alright. So why were some people having problems with them?
Old March 28th, 2012, 07:35 AM   #33
idk cuz they spray cleaner and lube through it too fast? I mean it's not perfect, but it's easy to use. Not really sure how it could get messed up...
Old March 28th, 2012, 08:13 AM   #34
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
They said you can't do the throttle cable for some reason... at least for the 250...
Old March 28th, 2012, 10:48 AM   #35
should be able to. just disconnect the cables.
correct me if I'm wrong here people.
Old March 28th, 2012, 05:11 PM   #36
"They" are wrong.
All Bowden cables need to be lubricated.
http://en.wikipedia.org/wiki/Bowden_cable
Old March 28th, 2012, 07:31 PM   #37
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Alright. What happens when you don't lube them?
Old March 28th, 2012, 07:38 PM   #38
...well if you have to ask, you prolly should reconsider your actions. She's gotta be lubed.
Old March 28th, 2012, 07:41 PM   #39
k-os
You can get binding cables. Obviously a binding throttle is no fun.
Old March 28th, 2012, 07:57 PM   #40
Rain likes sneaking into them, corroding the steel cable.
Copied from above link:
"Bowden cables can cease to function smoothly, particularly if water or contaminants get into the housing. (Modern lined and stainless steel cables are less prone to these problems; unlined housings should be lubricated with a light machine oil.) Cables also wear through repeated use over a long time, and can be damaged through kinking or raveling. A common failure occurs on bicycles at the point where the housing enters a barrel adjuster; loose housing ends tend to fray the housing, making adjustments uncertain. Fraying due to fatigue is most likely if the cable passes over a pulley, which on bicycles is often below the recommended diameter, or where the cable is bent repeatedly where it attaches to the brake lever or caliper. Sharp bends tend to furrow the inner cable sleeves, though its significance for gear shifting and braking is poorly documented. If an inner cable is not replaced when it frays, it can suddenly break when force is applied strongly, causing the link to fail when most needed (e.g. to a brake)."
twisted cables syoo General Motorcycling Discussion 2 July 11th, 2013 09:38 PM
Lubing Cables FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 7 October 11th, 2012 04:13 PM
Lubing the throttle cables Boom King 2008 - 2012 Ninja 250R Tech Talk 1 March 26th, 2011 06:30 PM
Need help with throttle cables. ak_907_ak 2008 - 2012 Ninja 250R Tech Talk 4 April 2nd, 2009 02:47 PM
Throttle Cables... Do we really need 2? kkim 2008 - 2012 Ninja 250R Tech Talk 23 December 10th, 2008 08:47 AM
