Old July 17th, 2014, 12:26 AM   #1
djjontran
Motorcycle(s): 2001 ex 250
Where to relocate stuff?
Hi everyone. Been a while since I've been on here but I'm continuing my cafe project and was about to take off the rear fender. I was wondering how everyone relocated the stuff attached to the fender. I did the search but couldn't really find any detailed explanations of how stuff got relocated. If you could link me to a thread that would be cool too.
Oh I'm also taking out the airbox and am actually just planning to trim the rear fender like how @Chicagobob did.
djjontran is offline   Reply With Quote
Old July 17th, 2014, 07:28 AM   #2
Chicagobob
Chicagobob's Avatar
Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B
In my post, I showed where I put it - on the airbox. See https://www.ninjette.org/forums/showthread.php?t=117957 (Post #5)
If you take out your airbox, you'll have more room elsewhere to mount stuff, like on the rear fender, battery box, or maybe on a plate attached to the top of the frame rails. You should try to isolate it from spray from the rear wheel.
Chicagobob is offline   Reply With Quote
Old July 17th, 2014, 09:21 AM   #3
djjontran
@Chicagobob okay sorry if this is a silly question but I can't think of how to mount a custome plate to the bike frame. Would I just try to use whatever available stock holes there are or is there a way to mount to the frame without welding?
Old July 17th, 2014, 11:04 AM   #4
Chicagobob
Chicagobob's Avatar
There are several options that don't require welding. Since an electrics tray is usually not load-bearing, you could attach it with double-sided tape (foam core servo tape is the strongest). You could also use pop rivets, which require drilling (usually 1/8" holes), but can easily be removed (also by drilling). Finally, you could bolt it on, either with self-tapping screws, bolts into tapped holes (weak, because the tubes are made of soft steel), or bolts through the entire frame tube (May crimp the tube if tightened too much, and adds the bulk of nuts). I've even seen guys use hose clamps, which is how Vetter used to mount its fairings.
On our 250, we used the self-tapping screws to attach sheet metal items to the frame, but on later projects we've had cleaner results with pop rivets for light-duty fastening. We haven't had problems with them failing or vibrating loose.
Whatever you choose, good luck with your build.
Old July 17th, 2014, 11:13 AM   #5
typically i relocate parts to the trash can
Old July 17th, 2014, 12:31 PM   #6
djjontran
LOL I've definitely relocated a lot of items there.
Thanks Bob! I'll look into all of those.
Old July 21st, 2014, 05:59 AM   #7
Kruse08
Kruse08's Avatar
Motorcycle(s): 99 Ninja 250
You can check out my build thread as I am in the process of turning mine into a naked/cage bike. I made some new brackets and what not which helped relocate a good amount of parts and also was able to hide the fuse box under the gas tank. My thread is called "My first bike project!" if you want any ideas. It is not done yet so not all my pictures are uploaded.
Kruse08 is offline   Reply With Quote
Old July 21st, 2014, 08:55 AM   #8
djjontran
Nice! Thanks Kruse I have seen your thread and I definitely liked what you did.
Old July 21st, 2014, 09:13 AM   #9
Kruse08
Kruse08's Avatar
I know it may not be the nicest looking way of doing it as I am new to fabricating and I did not weld anything. Everything I did can be put back to original. I got my ideas from many different people throughout the forum and internet so credit is given to all of them. I am trying to do it cheaply but I did not have certain items so the price has increased over the past few weeks.
[roadracingworld.com] - What's Better Than Cool Stuff? Cool Stuff For Free! Take The Ninjette Newsbot Motorcycling News 0 March 12th, 2014 12:20 AM
HELP. WTF is This stuff? krolinked 2008 - 2012 Ninja 250R Tech Talk 20 February 9th, 2013 06:28 PM
Choke cable relocate pjed 2008 - 2012 Ninja 250R Tech Talk 7 April 21st, 2012 04:39 PM
Hugger and some other stuff bowersox3589 Motorcycle-related 4 October 12th, 2011 10:42 AM
License Plate Relocate Fail HKr1 General Motorcycling Discussion 24 April 16th, 2011 07:00 AM
