Old December 14th, 2013, 04:21 PM   #1
Mark Cook
Full Time Survivor
Mark Cook's Avatar
Motorcycle(s): 2012 Panigale S, 2010 Streetfighter, 2008 250r, 2002 Sv650, 1999 Sv650, 1965 CB160, 1963 Vespa GS160
Race Bike Build
OK since I'm working on building up a little racer too, I'll add to the merriment.
Here is what I've started with.
Basically a pretty rashed street bike with about 8500 miles on it.
Mark Cook is offline   Reply With Quote
Old December 14th, 2013, 04:26 PM   #2
Mark Cook
Full Time Survivor
Mark Cook's Avatar
At home in the shop.
Old December 14th, 2013, 04:28 PM   #3
Mark Cook
Full Time Survivor
Mark Cook's Avatar
And the Teardown begins.
Old December 14th, 2013, 04:30 PM   #4
Mark Cook
Full Time Survivor
Mark Cook's Avatar
Forks being prepped for emulators, springs and preload caps.
Old December 14th, 2013, 04:32 PM   #5
Mark Cook
Full Time Survivor
Mark Cook's Avatar
Quick mockup with bodywork to drill mounting holes.
This was a cheapy set off of ebay. Not bad for the cost.
Mounted forks to check for fitment of woodcraft clip-ons.
Old December 14th, 2013, 04:33 PM   #6
Mark Cook
Full Time Survivor
Mark Cook's Avatar
And as it sits today.
Now to get started on stripping out the wiring harness and putting it all back together.
Old December 14th, 2013, 06:36 PM   #7
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
So I'm following your progress. I look at each of your posts and noticed the time stamp on each and the amount of work done. Damn, you're fast at this rebuild. At this rate you should be done at about 10:00 tonight.
Old December 14th, 2013, 08:32 PM   #8
Mark Cook
Full Time Survivor
Mark Cook's Avatar
Mad skillz!
Old December 15th, 2013, 07:32 PM   #9
Mark Cook
Full Time Survivor
Mark Cook's Avatar
Pretty busy in the garage today.
Installed the woodcraft clipon riser spacers. I'll see if I truly need them when the triples arrive.
Installed the Moto X rearsets on the frame.
Fabbed up an engine stand, and tore down the top end for inspection. The cylinders look crappy, so I need to figure something out for a replacement. Will need to keep things stock for MCRA legality.
Installed the woodcraft sharkfin.
Also installed the tapered steering bearing races.
Overall a productive day.
More parts should arrive next week to allow more progress.
Old December 16th, 2013, 12:53 PM   #10
NINJosh.
Motorcycle(s): 2010 BMW F800GS, 2009 Kawasaki Ninja 250r, 2001 Suzuki DRZ400
hey Mark, i'm assuming the "sharkfin" is the thing mounted on the swing arm, what is that for exactly?
also, could you hook me up with a picture of your upper frame crossmember. it kinda looked in one of your photos that yours is crooked the OPPOSITE direction that mine is. i was kind of worried about mine being crooked at first, but the more frames i look at the more they all just look crooked.
the picture makes mine look a little worse than it really is but you see what i'm getting at.
good work man, can't wait to see it all put back together!
File Type: jpg Screen shot 2013-12-16 at 1.47.24 PM.jpg (97.7 KB, 19 views)
NINJosh. is offline   Reply With Quote
Old December 16th, 2013, 12:59 PM   #11
Mark Cook
Full Time Survivor
Mark Cook's Avatar
Sure thing. I'll head out to the garage later and take a shot.
The sharkfin is to protect in a crash in case your hand or foot gets caught in the chain.
Old December 17th, 2013, 09:14 AM   #12
Mark Cook
Full Time Survivor
Mark Cook's Avatar
Let me know if this helps.
Old December 20th, 2013, 03:37 PM   #13
NINJosh.
thanks
well, your's looks pretty good. it's definitely angled the same direction if it's angled at all. it look different in one of your early photos from the side of the frame. thanks again man!
Old December 20th, 2013, 07:45 PM   #14
krakatak
krakatak's Avatar
Motorcycle(s): Ninja 250r
Looks like fun. If you need an extra set of hands, let me know. Glad that the rules are sorted out for next season, can't wait for the racing to resume...
krakatak is offline   Reply With Quote
Old December 20th, 2013, 08:02 PM   #15
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
I love da builds
Old December 20th, 2013, 08:23 PM   #16
Mark Cook
Full Time Survivor
Mark Cook's Avatar
Yeah I'll have my hands full after Sunday.
SV motor will be done, and I'll start on the SV/Ducati hybred.
Let's see... What else can I build?
Old December 27th, 2013, 08:41 AM   #17
Mark Cook
Full Time Survivor
Mark Cook's Avatar
Brief update as parts start arriving.
Triples and forks have been mounted as well as clip-ons. Will have to wait till I get the bike further along so I can sit on it and get the bar angles and heights correct. I really dislike the bodywork limitations with the clip-ons though...
Old December 27th, 2013, 09:26 AM   #18
r6boater
Motorcycle(s): '04 R1 and '08 Ninja 250
Cut it. Draik run clip-ons sans risers but we had to cut the bodywork to get them to be able to work.
Check out this Ninja 250 roadracing youth---> TheDraik77 <--- My son
r6boater is offline   Reply With Quote
Old December 27th, 2013, 09:30 AM   #19
Mark Cook
Full Time Survivor
Mark Cook's Avatar
Yeah, I'm considering that, but will need to wait until I get closer to completion before I start cutting...
Old January 5th, 2014, 07:51 PM   #20
Greenlawnracing
Motorcycle(s): Ninja 250, SV 650
Looks great! Where did you get the fork caps?
Greenlawnracing is offline   Reply With Quote
Old January 6th, 2014, 09:29 AM   #21
r6boater
Sling Shot Racing sells them.
Old January 6th, 2014, 09:59 AM   #22
shane liberty
shane liberty's Avatar
Motorcycle(s): None Yet
Fun build man.
Whatever you do DO NOT CUT THE SUBFRAME!!!!
Seems like a great idea to shave weight and to avoid the subframe smacking the ground and bending, but it's illegal. You're not allowed to chop up or shorten the frame in many supersport rules from different organizations. A couple of us, ahem, have made this mistake.
shane liberty is offline   Reply With Quote
Old January 6th, 2014, 10:27 AM   #23
Mark Cook
Full Time Survivor
Mark Cook's Avatar
It's actually legal here in St. Louis with MCRA. I still may cut it, but need to look closer at how strong the tail will be without the rear mounting points...
Originally Posted by shane liberty View Post
Fun build man.
Old January 6th, 2014, 10:29 AM   #24
Mark Cook
Full Time Survivor
Mark Cook's Avatar
Some progress yesterday since it was snowing like crazy.
Engine is bolted back together and bolted in the frame. Exhaust test fitted as well.
Old January 6th, 2014, 05:37 PM   #25
Greenlawnracing
True, but you make a trip to CMRA or CCS which are in your backyard (ok, more like left field) and you won't be legal in some classes.
Old January 6th, 2014, 06:31 PM   #26
Mark Cook
Full Time Survivor
Mark Cook's Avatar
I realize that, but since MCRA decided to have their own 250 rules that don't align with any other organization, I'm pretty much stuck with their series. I don't have any plans to race it in CCS, CMRA, or WERA anyway. I have too many extra curricular activities as it is now, so the 5 or 6 MCRA weekends will have to suffice.
Old January 7th, 2014, 07:48 AM   #27
DCMoney
DCMoney's Avatar
I realize that, but since MCRA decided to have their own 250 rules that don't align with any other organization, I'm pretty much stuck with their series. I don't have any plans to race it in CCS, CMRA, or WERA anyway. I have too many extra curricular activities as it is now, so the 7 or 8 MCRA weekends will have to suffice.
Fixed it for you!
MCRA.com
Old January 7th, 2014, 08:34 AM   #28
Mark Cook
Full Time Survivor
Mark Cook's Avatar
Originally Posted by DCMoney View Post
Fixed it for you!
Old January 21st, 2014, 04:26 PM   #29
NINJosh.
hey mark, are those armour bodies plastics? that's what i'm using. couple questions for ya. i see there that with the upper mounted up you don't have the top fairing bracket bolted on, are you going to put that back in at any point or are you gonna go without it. i was looking at mine today, and i guess it doesn't really seem all that necessary. also, did you have trouble getting your tail section on? i was trying to get mine on and there is no way it will go over the cross member in the subframe. i don't want to force it, i feel like i'm going to break it. am i missing some trick to this? i bought the bike without the plastics so i have no idea how the stock ones fit or where they mounted up, and definitely no idea how these ones should go back on. any tips?
thanks man.
Old January 22nd, 2014, 01:41 PM   #30
simook
Great build so far! Could you show more pictures of how you mounted the rear reservoir? It looks as if you have it inside the tail fairing.
simook is offline   Reply With Quote
Old January 22nd, 2014, 01:45 PM   #31
DCMoney
DCMoney's Avatar
Its just tygon 2375 tubing a cap and some clamps.
If your interested I've got a kit ill sell for $12 shipped.
MCRA.com
Old January 22nd, 2014, 01:49 PM   #32
simook
I see, it looked as if you still had the stock rear reservoir attached. I need to rear over the rules again and see if I can do away with the stock reservoir.
Old January 22nd, 2014, 02:45 PM   #33
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
looking good, wish i had the space to work on my 250r like that.
TEAM ALFALFA
www.apexassassins.com
Old January 23rd, 2014, 06:56 AM   #34
Aodrn
It's a long boring story
Aodrn's Avatar
Motorcycle(s): 2012 Ninja 250
Ok, school me on the advantage of removing the resevoir. Is the tubing that much lighter?
#41 MCRA
alex.s :crashing is a normal part of life... people are just in denial about that.
Aodrn is offline   Reply With Quote
Old January 23rd, 2014, 10:07 AM   #35
DCMoney
DCMoney's Avatar
I didn't do it for the weight savings, with my rear sets and riser plates the stock hose was rubbing on the rear wheel wearing a hole in the hose protective liner.
Plus it looks better.
MCRA.com
Old January 23rd, 2014, 10:09 AM   #36
Aodrn
Aodrn's Avatar
Form and function. I like it.
#41 MCRA
Old January 24th, 2014, 08:47 PM   #37
Mark Cook
Full Time Survivor
Mark Cook's Avatar
The reservoir removal for me, is simplicity and weight reduction/cleanup.
Anything that I can get away with eliminating goes in the trash can.
It all ads up.
Mark
Old January 24th, 2014, 08:50 PM   #38
Mark Cook
Full Time Survivor
Mark Cook's Avatar
Josh,
This was just a cheap set off of ebay.
I don't have an upper fairing bracket fabbed up yet, but I will be making an aluminum one to hold the upper in place. I think even though it's pretty solid as it is, once you get up to speed it will need support.
The tail is a bit of a PITA to get on, but it will go. Just had to figure out the way to make it fit. Patience.
thanks man.
Old May 6th, 2014, 09:30 PM   #39
Mark Cook
Full Time Survivor
Mark Cook's Avatar
OK, I've skipped a bunch of steps but if you're on the FB you can see progress there.
https://www.facebook.com/mark.cook1/...8480085&type=3
I made the folder public, so you should be able to see the photos.
A few more things to do, and I'll be relatively satisfied with it.
Made 35hp on the dyno. Not too shabby.
Old May 7th, 2014, 08:29 AM   #40
bitaria
Motorcycle(s): CRF450X, CRF250R/SM, Husky 630 SMS, Ninja 250R
35hp is pretty high for a Ninja 250. Obviously depends on the dyno, conditions at the time etc., but seems that ~31-32hp is more inline with "supersport" build on pump gas.
Do you mind sharing any power related mods? (airbox, oil weight, jetting)
bitaria is offline   Reply With Quote
stlcbr's '12 ninja 250 Race Bike Build stlcbr Ninjettes At Speed 118 August 11th, 2014 10:32 AM
CVMA Race bike build - buncha questions cookiebug79 2008 - 2012 Ninja 250R Tech Talk 4 July 22nd, 2014 01:30 PM
My 250R Race Bike Build icbm Pictures 5 August 16th, 2012 11:06 AM
[superbikeplanet.com] - '95 YZR500: Build Your Own GP Bike Ninjette Newsbot Motorcycling News 0 August 14th, 2012 10:10 AM
Plum Crazy Purple Race Bike Build kogary Pictures 12 May 18th, 2011 02:59 PM
