Old November 12th, 2015, 05:05 AM   #1
f0r54ken
Motorcycle(s): Kawasaki ninja ex250 2007
Taking a Stab at Compression issues. 2007 250 ninja.
So, I've gone to ending the "oil in the coolant" thread since that was resolved with a new head gasket. But I wanted to share what was happening with that compression issue as promised. Sorry didn't get the audio recording, But I took the top off and opened a few things.
So here is where that stands. As far as timing goes I think it's spot on, but maybe I'm wrong. I took it apart on a whim tonight and Grabbed my cellphone to record it. I checked ALL the rocker arms to make sure they were coming down like they should. They are all seated right and push when the cams or whatever turn over.
Open cover recording:
https://youtu.be/TJN9HN3K4qE
I set the clearance as close as I could to the middle of specs. They currently sit near.
Inlets/Gas Side 0.20mm (0.0078 in.)
Exhaust 0.24mm (0.0100 in.)
at 2|T on the rotor, The Piston Closest to the throttle (right side) is fully raised. I used a wooden kabob stick to feel it coming up and down within the spark well.
Now with all this being said, With everything put together the compression of each piston reports as follows. (engaged by the ingition.)
Left side is Starter motor side; while right side is clutch side.
Dry:
Left = 45 psi, no spark plugs on either side.
Left = 45 psi, with spark plug in right side.
Right = 45 psi, no spark plugs on either side
Right = 45 psi, with spark plug in left side.
Wet (Few drops of oil):
Left = 55 Psi, no spark plug on either side.
Right = 55 Psi, no spark plug on either side.
How does it ride you ask? It sounds like the explosions are happening on the inside of the engine and never escaping. Even though the engine is running it sounds like it's suffocating and barely coming out of the exhaust. I did not check this end of the muffler. Since it is an "h" tube it will be a deceiving result.
The rpm's will reach 5k before maxing out and then Decreasing on it's own down to 4k. Maximum speed of 40 mph. (Scooters were giving me stink eyes while passing.)
Piston rings may not be clocked right. Can't tell yet would need to take apart. but I figure improper clocking is unlikely since both pistons read the same compression. One should show worse than the other...Unless they are incorrectly clocked identically.
And Finally, BONUS INFO! My compression test fitting (12mm for this bike's spark well.) Got stuck in the well because the dummies who made the kit set counter clock rotation to remove it. To get the fitting off after trying multiple things the most successful result was using blue loctite thread locker on the compression tester rubber tube, and twisting it into the thread of the adapter stuck in the spark well. (To be clear Don't ever put Loctite on the Actual spark well thread. I put it on the compression tester set only. between the rubber connector and the Interchangable adapter head piece.)
I got it twisted pretty well, Left it for 24 hours. And counter clockwise twisted both pieces out pretty easily. Pro tip= Don't twist that in with two hands when you test it. Don't aim for snug; aim for attached, single hand tightened to the end with no torque added.
Anyway I hope this intel Strikes a Eureka moment for someone. You guys have been so great, Spooph, Greg, Ghostt, motofool, but finding a mechanic in vegas who knows what they are doing or isn't lying through their teeth is literally impossible. Unfortunately You guys are my only real hope with this Damn nightmare.
Thank you!
**Forgot to mention, Gas flow On Gray Line to carb is excellent. I don't know how to test the carb to the engine. :/ **
Last futzed with by f0r54ken; November 12th, 2015 at 05:22 AM. Reason: added note.
f0r54ken is offline   Reply With Quote
Old November 12th, 2015, 07:20 AM   #2
Ghostt
Ghostt's Avatar
The factory clearance specifications are .08 - .13mm (0.003-0.005 inches) for the intake valves and .11 - .16mm (0.004-0.006 inches) for the exhaust valves
violente et ignorantia
ZX-2R BLOG
Old November 12th, 2015, 08:23 AM   #3
greg737
Motorcycle(s): -
Are you working with a copy of the Kawasaki Ninja 250 Motorcycle Service Manual? It's full of interesting tidbits...
Example: the very first item under the heading "Compression Measurement" (on page 4-11) says "Thoroughly warm up the engine so that engine oil between the piston and cylinder wall will help seal compression as it does during normal running."
The Service Manual cylinder compression range is 139 to 213 psi.
I know that by the time people get around to trying to diagnose their engine's health with a compression test they often have the bike pretty well disassembled to the point that it won't/can't run, but it's important to know how the manufacturer meant the test to be carried out.
And it's not just Kawasaki prescribing a warmed up engine for compression testing, every service manual I've ever read said to warm it up.
Old November 12th, 2015, 08:36 AM   #4
greg737
Motorcycle(s): -
Back in the mid-'80s the Ford Motor Co. had a problem with the subcontractor who was providing the manufacturer's OEM mufflers (for their V-8 engined models). The defective mufflers would quickly deteriorate and as they fell apart internally they would restrict/block the flow of exhaust gases. The result was exactly the "suffocating" sound you described for your EX250. And this greatly affected performance.
Did somebody stuff something up your bike's exhausts? (I've read accounts of people finding their children's toys crammed into exhaust pipes)
Old November 12th, 2015, 09:15 AM   #5
greg737
Motorcycle(s): -
watched your video, everything looks correct with the timing.
To better understand what you're seeing as you rotate the crankshaft it's important to remember that the camshafts are geared to move at 1/2 the rate of the crankshaft.
So 720 degrees of crankshaft rotation = 360 degrees of camshaft rotation.
Because the EX250 engine has a 180 degree "Flat Plane" type crankshaft the two pistons follow each other 180 degrees out of phase:
0 degrees crankshaft rotation = #1 cylinder TDC mark, spark plug fires
180 degrees crankshaft rotation = #2 cylinder TDC mark, spark plug fires
... then during the remaining 540 degrees of the four-stroke cycle the EX250's pistons are just carrying out the "housekeeping duties" of power stroke, exhaust stroke and intake stroke before finally getting back around to the money-shot moment of combustion.
From your video:
At 55 to 57 seconds on your video's timeline: Yes! You are definitely at "2T" (cylinder #2 top-dead-center, "TDC").
And, at this point in your video (55 to 57 seconds), not only is cylinder #2 at TDC but it is at the point in the 720 degree crankshaft cycle (four-stroke) where the spark plug is fired for combustion. You can tell because both of the camshaft lobes for #2 cylinder are off the tappet (not pressing it down to open the valve) and (bearing in mind the direction of camshaft rotation) you can see that the last valve that closed is the intake valve (it's pointed toward the rear of the bike which means it has a long way to go until it presses down on the tappet again).
Your timing marks look to be perfect. Remember, the manual shows the timing marks pointing to the top of the cylinder head casting (the metal part only, their illustrations do not include the rubber gasket).
Then, in the video, you turn the crankshaft 360 degrees (moving it from 180 degrees to 540 degrees into the 720 degree four-stroke cycle) to bring the 2T mark back into view again (2:33-2:48 on your video's timeline). Once again, everything looks just as it should at this point in the 720 degree four-stroke engine cycle. At this point the #2 cylinder has arrived back at TDC, just finishing its exhaust stroke.
The #2 cylinder cam lobes are now facing each other which means the exhaust valve is just finishing closing and the intake valve is just beginning to open. This is called "valve overlap" and most engines have a small amount of it.
Old November 12th, 2015, 09:18 AM   #6
greg737
Motorcycle(s): -
And... Ghost is right, you f-ed up the valve clearances.
Setting the valves this loose will have the effect of keeping them closed much longer than Kawasaki wants them to be because now it takes up a good bit of the cam lobe's lift profile just to close up the extra gap you've set on the tappet so there's less of the lobe's lift profile left to actuate the valves for the intake of air/fuel and the exhaust of gases.
Could be part of that "suffocating" feeling you mentioned in your post. Less intake valve lift = less air/fuel mixture into the cylinder and less exhaust valve lift = reduced clearing of burned gasses (and no "scavenging" effect because there's no "valve overlap" between the intake and exhaust valves).
You end up with the spark plug trying to fire a weak mixture of not much air/fuel combined with way too much old leftover exhaust gasses. And people on scooters go blowing past you.
Old November 12th, 2015, 09:43 AM   #7
spooph
spooph's Avatar
Motorcycle(s): '08 Ninja 250R
MOTM - Oct '15
If setting the valve clearances doesn't change the out come, remove the head and do a leak-down test on it (obviously with the exhausts removed). If the head is still on the bike, you could always run it without the exhaust for a short while just to see if that has any affect on it...
Or you could remove the mufflers and push a wire or something down the headers to make sure they are clear of obstructions, but starting with the valves would be the best bet.
Old November 12th, 2015, 12:07 PM   #8
Ghostt
Ghostt's Avatar
Did you lap the head and cylinder surfaces? This is critical.
Here's a quick write-up
Okay this goes for the Ninja 500, but I'm sure the Ninja 250 is the same, if not please let me know ;
The intake valves are case hardened to a thin level of hardness and much in the way of metal removal with destroy them.
Why do you think you need to lap them? if they are worn you need to re cut the seats and fit new valves ,no lapping required. If they are worn badly enough to need anything at all they develop a groove that offself is the detriment to flow. Lapping will make that worse.
Head Gasket repair
Lapping the head
A common failure of the EX engine is, a blown head gasket. The usual cause of this besides the obvious low water or frozen coolant reasons is, warpage of the mating surface between the head and the cylinders. The string of events leading to overheating is:
High pressure gas leaks from the combustion chamber into the coolant system, thereby over pressurizing it and blowing coolant overboard, then the coolant shortage causes overheating which causes even greater warp age, add on infanatum...
As well as the above, any engine that has had the head removed for any reason need to be re lapped. This engine is a very flexible unit because of the cam chain gallery down the middle. The only thing holding the two cylinders together is the very thin wall of the front and back sides of the chain gallery. 1/8” if you’re lucky. This means that the engine works like two single cylinder engines running from a single crank held together by scotch tape. As long as they remain together they are usually fine, but once disassembled they need to be re flattened
The repair:
Unfortunately it is not a simple as replacing the head gasket. Because the “gasket” is not compressible, it is not able to absorb even slight distortion or warp age that may not even be detectable with the usual straight edge type of inspection. The up side of this is that you can re use the gasket.
Tools needed:
A lapping plate; usually a steel flat plate or a pain of flat plate glass. I’ve used my table saw table successfully (the cast iron type)
Lapping compound: Valve lapping compound available at a Auto parts store
The means to wash the parts clean after lapping. A bucket of Kerosene is fine.
The Idea is to use the abrasive to grind down the high spots of the head and the cylinders till they are perfectly flat. See the pictures.
The process move the part over the surface of the Lapp in a figure 8 motion
Clean and inspect your progress often. Shown is a partially cleaned surface
Here are the completed two parts.
You are now ready for reassembly. Clean the old head gasket with lacquer thinner and Scotch brute or steel wool. Then repaint it with 1 coat of spray enamel on both sides (1 coat)
After assembly increase the Head Bolt torque to 40 lbs. ft.
Now’s a good time to degree you cams.
ZX-2R BLOG
Old November 12th, 2015, 03:42 PM   #9
Originally Posted by f0r54ken View Post
Dry:
Right = 45 psi, with spark plug in left side..........
Are you fully opening the throttle during the compression tests?
For your 2007 engine, these are the acceptable valve-rocker's clearance ranges (only for dead cold condition of the engine):
0.08mm - 0.13mm for the intake valves
0.11mm - 0.16mm for the exhaust valves
Those are just to compensate for the natural dilatation of the valves when the engine is hot.
The working gaps become almost zero, erring on the loose side, so the valves actually close completely.
The way you have those now, the breathing of the engine is diminished.
Important caveat:
http://n4mwd.blogspot.com/2013/06/ov...ts-during.html
Old November 12th, 2015, 03:53 PM   #10
f0r54ken
Thank you guys, This information is very helpful. You guys will be mad but I'm working with the evolution service manual (2008+) I figured it shouldn't have been that much different. Looks like I was wrong.
Ok, So I will set the rockers to proper spec. I know I had low compression a week after the head gasket went with the coolant issue. But Greg I think you're right. The exhaust sounds stuck. It was pretty rapid and I don't have any kids to stick toys in it. once I adjust the valves to proper spec If it still sounds like a fart in a marshmallow factory I'll take the exhaust off and clean the inside like toilet brush.
Spooph, I plan on it I know the next step is a leak down test. Lemme ask too. is there a way I can check the valve stem integrity with just the cover off? I Could go down as far as removing the timing assembly too tonight. I'm avoiding taking the head apart again for now until I'm left with no other possibilities.
Ghostt, Thank you for those measurements. I kind of wonder if there is anything Else I should know. I suppose I can just suck it up and buy the service manual. :/
Unless someone has a digital version they can email me? Does it say it can't be resold? Not sure how copyright works for books. f0r54ken@hotmail.com
I did check the head for warping. I did not bore or lap any ends though just cleaned them well. I used a duct tape roll horizontally and pushed down around the cylinder section on the bottom of the head. then used the smallest feeler to check all around the roll for blips and chips. I repeated for both sides. Couldn't get the feeler to go between the roll and the bottom of the head. I hope I described that properly.
I used a new gasket with some copper spray and got no leaks after running for 25 miles. So that's good at least.
Old November 12th, 2015, 03:59 PM   #11
f0r54ken
Important caveat:
Ah yeah, I inspected all of the "dog ears" for damage before putting it back on, Since I'm adjusting them I'll inspect again too. Currently it sounds like my adjustment is nearly doubled over! I'll adjust the valves tonight I think that should at least take of the suffocating sound.
I forgot to mention, Yes I was open throttle on all of the tests. I also did it Closed throttle. all tests resulted in 45 psi still.
Old November 12th, 2015, 04:31 PM   #12
Ghostt
Ghostt's Avatar
I forgot to attach the pictures, keep in mind these are of a EX500, NOT a Ninjette.
ZX-2R BLOG
Old November 12th, 2015, 04:47 PM   #13
f0r54ken
So clean...You could eat Dinner off that engine.
Old November 12th, 2015, 05:08 PM   #14
spooph
spooph's Avatar
MOTM - Oct '15
I'm not aware of any way to inspect the valve stems without removing them from the head, however, if you have the head off, it's not difficult to remove them - I presume you have a valve compressor tool?
Something like this: http://store.schnitzracing.com/schni...lGEaAvcq8P8HAQ
Old November 12th, 2015, 06:00 PM   #15
f0r54ken
Jay-sus. more tools! haha
Hey when am I gonna beable to mark your guy's posts as helpful?
No, I don't have that tool. I'm pretty sure they aren't bent though. I checked where they lay on the bottom of the head when it was off. nothing was extruding or depressing more than the others.
( I hear that is the main sign of bending.
Also, In my experience to get the valve to bend you'd have to pretty much stick a garden hose in your engine and fill it with.
Short story, When I was riding through a storm with my car, I thought 8 inches of water running by the gutter wasn't so bad. I was wrong, With a low air intake, it sucked in a whole bunch of water and hydrolocked at 4k rpm. I miss the little guy :/
but yeah, I'd imagine bent valve stems should be pretty obvious. I'll be fixing the rocker height tonight. Hopefully I can fix the problems so I can spend time telling everyone how I did it instead of fixing a new one haha.
Old November 12th, 2015, 08:18 PM   #16
Ghostt
Ghostt's Avatar
Lapping is very important for proper gasket mating, and sealing.
ZX-2R BLOG
Old November 12th, 2015, 08:59 PM   #17
f0r54ken
I couldn't find this suggested in the manual. (Grabbed one during my lunch break from the library) Is this something for a higher mileage bike? mine's at about 9000.
Better yet, I don't want to assume a problem with the mating points, as much as I don't want to assume there isn't one. I did clean it very well and had no warping. So after I adjust the clearance. what can I do with what tools to actually narrow down this lack of sealing? I want to be positive that I need to remove the head before I remove the head again.
Old November 12th, 2015, 09:08 PM   #18
Ghostt
Ghostt's Avatar
IMHO, it's necessary every time you remove the head. Take another look at my write-up, and I state my reasons, regardless of engine, it's a must do, given the type of gasket used, it's just how to be sure that both surfaces are absolutely flat, and level.
It's just good engine building practice.
ZX-2R BLOG
Old November 13th, 2015, 04:41 AM   #19
f0r54ken
God **** piece of mother ****ing horse **** b**** c*** a** mother ****er i can't believe it! The compression tester was broken! the brand. new. Compression tester! >
I hooked up the other one I bought that I was gonna return cause it didn't come with a 12mm fitting. But after doing the proper valve clearance and 2 hours I thought, Eh What the hell. The other compression tester Showed at least 140psi on C-2, but the battery is becoming exhausted. it's doing that Weeoh weeooohh weeeeeeoooohhh wind down. could only get the strength to 130 psi on C-1 I need to reassemble it and ride for a little to recharge it.
Now I question compression test behavior. Just to make sure, I held the ignition down 4 seconds and the sequence went like this,
"Roll - 30 psi - Roll - 65 psi - Roll - 90 Psi - Roll - 120 Psi - Roll - 140 Psi - Roll - 140psi - Roll - 140 psi."
Same behavior on both sides. Argh! I'm gonna put this back together and we'll see how it feels and sounds. This is the best, worst news i've gotten all month.
Old November 13th, 2015, 07:58 AM   #20
Ghostt
Ghostt's Avatar
I'd say put it back together, and ride.
ZX-2R BLOG
Old November 13th, 2015, 12:06 PM   #21
250rr
250rr's Avatar
Motorcycle(s): Cheap Italian Suit. Otherwise known as Dew Kitty
For compression issues, I may or may not be wearing this. Be forewarned, it may cause other, and more concerning, 'issues'.
250rr is offline   Reply With Quote
Old November 14th, 2015, 05:18 PM   #22
f0r54ken
Argh...I give up guys. I'm tapping out. Replacing parts and taking apart ain't so bad. but mystery problems?...I got enough problems. lol
After being put together it no longer sounds like the combustion is stuck inside which is great. But the bike still runs like sh!t and I can't figure out why. valves are just right now for the feelers I used. and the engine got this occasional knock. on it's test ride. So I'm gonna go buy a brand new bike this weekend instead (Carter power sports said diagnosis is 114.00 and if they had to open up the engine it would be 1300.00 + parts. No thanks!
We'll see in about a week. I'm gonna either part it out at a very fair price, Sell it for like $500 whole to a mechanic. I might keep it in the background and leisurely work on it. we'll see what comes first.
Old November 14th, 2015, 08:07 PM   #23
netdobeiras
Motorcycle(s): 2004 kawasaki ninja 250
just out of curiosity but how many miles on the motorcycle? thanks
netdobeiras is offline   Reply With Quote
Old November 14th, 2015, 09:57 PM   #24
f0r54ken
Just under 9000 I suppose it's still good for this.
[Solved] Starter issues Ninja 250 (2007) f0r54ken 1986 - 2007 Ninja 250R Tech Talk 47 November 1st, 2015 01:33 PM
JE High Compression Piston Kit (13.5:1 compression, 356cc displacement) Timpo 2013 - 2017 Ninja 300 Tech Talk 8 October 12th, 2015 07:21 PM
Several Issues with 2007 Ninja Paulgello 1986 - 2007 Ninja 250R Tech Talk 6 May 17th, 2015 11:47 AM
