Old November 12th, 2010, 02:50 PM   #1
AdreeN
Motorcycle(s): 250r
Mileage seems to be really bad!!
I just bought a 08 250r 2 months ago, loving it...but the mileage seems really low, or I just had high hopes for monstrous numbers.
On a full tank, doing almost 3/4 on the highway and the rest local.
I only get about 300 KM a tank.
I'm in Canada :P the equivalent in miles is approximately 186 miles per tank.
I don't actually ride until I run out of juice, it's just an estimate.
I guess I accelerate pretty quickly.
I usually just try to get away from cars ASAP.
I cruise at about 6-7k rpm, and on the highway I average about 120-130km/h (75-81 miles/h).
Don't know if anything was done to bog down the mileage from the previous two owners.
AdreeN is offline   Reply With Quote
Old November 12th, 2010, 03:18 PM   #2
DaBlue1
DaBlue1's Avatar
Gasoline doesn't vaporize very well at very cold temperatures. So some oil companies formulate fuel differently for cold-weather markets in the winter. Unfortunately, the changes that are supposed to make cold weather vaporization better, also result in less available energy for combustion. You won't get as far on a liter/gal of winter gas as you will on a liter/gal of summer gas. Other reasons that can affect your gas mileage are;
1. More idling to warm the bike up
2. Low tire pressure due to cold temps
3. Lower engine and oil temps- Ninjas run better in warmer temps
Old November 12th, 2010, 03:40 PM   #3
TenaciousD
TenaciousD's Avatar
Motorcycle(s): 2009 250R
Are you accurately measuring how much fuel you've used? If you're going by when the fuel gauge reads empty you will underestimate your fuel mileage. At least on my bike when the gauge reads empty I've actually got around a gallon of fuel. So, if you're using around 3 gallons of gas to go 186 miles, that's 60 miles per gallon which is about right. If you're truly empty at 186 miles then, yeah, you're not getting the mileage you should.
Kevin
2009 Ninja 250R
TenaciousD is offline   Reply With Quote
Old November 12th, 2010, 04:10 PM   #4
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Try to figure the actual amount of fuel you're using. Gas mileage is normally done either as miles per gallon (or kilometers per liter I suppose) or as the amount of fuel burned in 100km. Keep in mind that each time you fill the tank there will be variations in the maximum level you fill to because the tank is fairly flat on top. A mm difference in height can cause a fair fraction of a liter variation. The best way is to keep detailed records over time, liters consumed and miles ridden, and then divide one into the other.
On my bike I consistently saw 55-58 miles per gallon with the stock 14T front sprocket, and that jumped to 62-65 mpg with the 15T. I've gotten as low as 45 mpg when doing 80+ miles per hour with full saddlebags into a partial headwind (throttle topped out).
Edit to add, how to figure fuel use. Fill the tank, noting where the fuel level is exactly. Ride X number of miles, then refill the tank to the same exact level as before, and record fuel volume and distance. Say you put in 10.5 liters of fuel, and rode 192km. Divide the km by the liters and you get 18.29 km/liter. That works out to be 43 mpg in English units, which I would consider low. Remember, it's important to fill to the same exact point each time you top off the tank. The emptier you run your tank before refilling the more accurate the fill number will be since the percentage of error will be smaller.
Last futzed with by FrugalNinja250; November 12th, 2010 at 05:01 PM. Reason: More info
Old November 12th, 2010, 04:25 PM   #5
tjkamper
tjkamper's Avatar
What your describing doesn't sound too far off. Get an accurate reading of your mileage. As rule, I always try to fill up at about 180 Miles. and I usually have about a gallon of gas left in the tank.
Old November 12th, 2010, 05:09 PM   #6
AdreeN
Motorcycle(s): 250r
this will prob be the worst question ever asked on any forum...but how do i get an accurate reading lol.
Old November 12th, 2010, 06:30 PM   #7
FrugalNinja250
Easy. Fill the bike to a known point, such as the bottom edge of the filler neck, then read the fuel amount off of the gas pump display. Write down the miles off your trip odometer and then reset it.
Old November 12th, 2010, 07:47 PM   #8
Related thread on mileage.
/moved to new-gen tech...
Old November 12th, 2010, 10:14 PM   #9
Mileage seems about like mine. I've always thought something was fishy.
Old November 13th, 2010, 05:43 PM   #10
KELPHYN
KELPHYN's Avatar
That's about my average. Sometimes it's less. I usually check my kms at the half tank mark on the gauge to see how my mileage is doing. There has been the odd time when I've got only 200kms to a tank. (strong head-winds, lots of hills and high speeds) That's why I keep a close eye on the top half and adjust my driving style if I have along way to go between gas stops.
Old November 14th, 2010, 12:20 PM   #11
41MPG at my last fill up.
Old November 15th, 2010, 12:34 PM   #12
Rexbo
CVMA / AFM / M1GP #250
Rexbo's Avatar
Motorcycle(s): 2009 Ninja 250r, 2011 Zero S, 2009 KLR 650
also the speedo/odometer are usually inaccurate as well. They did a pretty ass job of calibrating them. Fill your tank to full at the bottom of the filler neck, then drive to another place (and use mapquest or something to figure out the actual distance) then fill it there back up to the fuel neck.
# of gallons on the pump divided by actual mapquest miles = actual mpg.
Rexbo is offline   Reply With Quote
Old November 15th, 2010, 01:01 PM   #13
FrugalNinja250
I don't know about the newgen bikes but I took apart a speedo/odometer on a pregen and did some calculations with the gearing to determine accuracy, finding it to be very accurate. With the stock sized unworn tire the odometer reads 0.9% high, and with an unworn Kenda K671 in the 100/90 size it reads 2.5% low. As the tire wears and becomes smaller the odometer actually becomes more accurate with the stock tire. Because the odometer drive system is all gears and direct mechanical connections there's nothing to calibrate or adjust on it. The speedo, on the other hand, uses magnetic eddy drag and can be (and usually is) fairly inaccurate.
Old November 19th, 2010, 09:40 PM   #14
AdreeN
Motorcycle(s): 250r
45.96 MPG, looks like i'm a little below average
Old November 19th, 2010, 11:17 PM   #15
jonthechron
Motorcycle(s): magHitVE
Sounds like your doing just fine, I ride like you and get the same mileage as you!
Old November 20th, 2010, 01:13 AM   #16
SteveL
old git
SteveL's Avatar
Motorcycle(s): BMW K1300S
My 250R FI averaged 3.5 Liters a 100Km overall for the 6000Km that I had it.
Steve
Some mistakes are too much fun to make only once.
SteveL is offline   Reply With Quote
Old November 20th, 2010, 09:28 PM   #17
Bueller999
Oldie but a goodie
Bueller999's Avatar
Motorcycle(s): 08 Ninja 650r, 06 SV 650 race, 08 250r race, 03 Buell XB9s, 01 KTM 300 EXC
That is bad, I mainly ride my 250 on the track, so I am not sure of the milage under those conditions but my Buell (984cc) gets a steady 50 mpg, and I am really heavy on the throttle.
Bueller999 is offline   Reply With Quote
Old September 13th, 2011, 06:17 PM   #18
reaperw
reaperw's Avatar
Motorcycle(s): ninja 250
How are you only at 6-7k doing 130km
reaperw is offline   Reply With Quote
Old September 13th, 2011, 11:31 PM   #19
Kurgan
Kurgan's Avatar
Motorcycle(s): '09 Ninja 250R
I think many of you are forgetting one very important thing about calculating average fuel mileage....higher octane fuel gets lower mileage.
So if you fill up with low octane 86/87 one time, then decide to splurge and go with 94 octane the next time, don't be surprised when that 94 octane gas runs out a lot faster.
It's completely normal and nothing is wrong with your bike.
Kurgan is offline   Reply With Quote
Old September 14th, 2011, 08:46 AM   #20
We all know better than to "splurge" because it only makes sense for engines tuned to require it to prevent pinging/predetonation. Now, knowing that, why would it get worse MPG?
Old September 14th, 2011, 09:03 AM   #21
leed
leed's Avatar
Motorcycle(s): Time will tell
The only reason I can think you would get worse MPG for higher octane, is perhaps that in "proper and ideal operating conditions" all octanes have the same amount of 'energy density.'
Being said, if you run a higher octane fuel in an engine that does not require it, that fuel is not being put under the 'correct' amount of pressure, so it is not detonating in its proposed ideal state, so its 'energy density' is lower.
That is, our Ninjette engines do not have have enough compression to meet the higher octane 'compression standard' that high compression engines are designed to have.
Old September 14th, 2011, 10:10 AM   #22
Roman250R
Motorcycle(s): 2008 Black Ninja 250r
I use fuelly.com
Fun, easy you get to look at what other people get.
Roman250R is offline   Reply With Quote
Old September 16th, 2011, 12:03 PM   #23
Kurgan
Kurgan's Avatar
Higher octane fuel burns faster and usually gives a bit better power, therefor requires more fuel, so you get less mileage.
That's why people who run E-85 Ethanol in their cars don't really travel any cheaper because they have to fill up more often. E-85 is effectively 110 Octane.
Plus even in economy car engines that are also "not tuned for the higher octane" it's good to run a tank of the good stuff every once in a while just to keep things cleaned out and running smoothly.
Old September 16th, 2011, 01:48 PM   #24
Not really. This thread goes into great detail about the octane discussion.
Old October 24th, 2011, 09:30 AM   #25
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Steve
Wow! According to my workings (below) that's 80.7MPG (imperial/uk gallons)
Code:
100Km = 62.14 miles
3.5 Litres = 0.77 imperial/UK gallons
(62.14 / 77) * 100 = 80.701298701
Do you employ any particular riding techniques to get that good mileage? Does fuel injection give better mileage than the Carb system?
Bad driver & bad rider. Guess who gets hurt... akima Videos 27 July 12th, 2013 12:26 AM
Bad gas mileage and when should I get my 250 looked over at the shop zainejack 2008 - 2012 Ninja 250R Tech Talk 12 May 26th, 2012 02:53 PM
bad mileage and sputter globalmaa 1986 - 2007 Ninja 250R Tech Talk 19 May 22nd, 2012 08:55 AM
Lane splitting.... bad bad bad oblivion007 Videos 29 May 8th, 2012 11:42 AM
[superbikeplanet.com] - How Bad Is The Melandri Situation? This Bad. Ninjette Newsbot Motorcycling News 0 June 12th, 2008 01:11 PM
