Old August 13th, 2011, 04:15 PM   #1
SweetB
Motorcycle(s): 2009 Blue Ninja 250, 2009 White Vespa S 150
Latex coated zipper pulls? Zipper pull covers?
I've noticed in my commute that the zipper pulls on my jacket pockets are banging around against the tank. Has anyone ever covered their puller-thingies with latex, rubber, or some other material to soften them? I'm also thinking that miht make grabbing and using them much easier. If not coated, maybe a sleeve of some sort that could slide onto the metal?
I found some Aerostitch zipper pull covers but they wouldn't work for my jacket.
SweetB is offline   Reply With Quote
Old August 13th, 2011, 04:58 PM   #2
jamesio
jamesio's Avatar
Motorcycle(s): None
have you tried an adhesive tank pad?
'09 Ninja 250R SE
TB Slip-On l Puig DB l Pazzos l Pro-Grips
jamesio is offline   Reply With Quote
Old August 13th, 2011, 05:26 PM   #3
SweetB
I have one on order but the zippers are banging onto the side of the gas tank.
Old August 13th, 2011, 05:36 PM   #4
bdavison
Wartown, USA
bdavison's Avatar
Use heat shrink....it works great.
Old August 13th, 2011, 08:55 PM   #5
SweetB
Oooh, good idea! I'll see which is easier to find and report back on.
Old August 13th, 2011, 09:03 PM   #6
setasai
setasai's Avatar
http://www.plastidip.com/home_solutions/Plasti_Dip
They sell it at home depot. Not sure what colors they come in but I think they'd totally solve your problem.
Old August 15th, 2011, 12:01 AM   #7
SweetB
I picked up some plastidip today and that stuff is amazing!! It's also a lot of fun to just dip random crap in. I've coated lots of stuff already, but the zipper pulls are perfect coated with this stuff.
Old August 15th, 2011, 12:05 AM   #8
Pets? Body parts?
Old August 15th, 2011, 12:16 AM   #9
setasai
setasai's Avatar
Glad it worked out. I'm sure there are a ton of other uses for that stuff.
Old August 15th, 2011, 04:44 AM   #10
azimmer11
azimmer11's Avatar
what'd you coat with it? pics or didn't happen.
azimmer11 is offline   Reply With Quote
Old August 15th, 2011, 10:18 AM   #11
gfloyd2002
User Title Free Since '12
gfloyd2002's Avatar
MOTM - Feb '12
Plasti dip is excellent for office pranks. Pen tips, stapler, mouse, phone handpiece, you name it.
As far as actual intended uses, great for covering servos, electrical connections. Waterproofing anything. Dipping guitar pic end for better grip. Covering ends of glasses to help them fit into your motorcycle helmet (after you cut off ends that hit padding inside helmet). Covering tweezer ends for grasping delicate objects, like jewelry. Sealing diaphram rips. Insulate wire near exhaust or engine. Covering sharp edges on something dangerous for dog or toddler. Protecting a soldered connection. On rope ends (or shoelaces) to keep from unraveling. Literally thousands of uses.
I love this stuff, up there with WD-40 and duck tape on the must have list for any home.
Old August 15th, 2011, 10:33 AM   #12
azimmer11
azimmer11's Avatar
can it replace a condom?
Old August 15th, 2011, 12:50 PM   #13
dubojr1
dubojr1's Avatar
Ummmmm..... No!
Old August 15th, 2011, 12:56 PM   #14
Honko
Honko's Avatar
Motorcycle(s): 2010 Green SE
I hear herculiner is good for that...
Honko is offline   Reply With Quote
Old August 17th, 2011, 03:32 PM   #15
SweetB
Used the black plastidip I picked up at Home Depot. Here's one zipper from my Triumph jacket coated in it, and the zipper on my Airhawk. Airhawk pic was taken while the stuff was still wet so it looks very puffy. The Triumph zipper looked very similar before drying.
Old August 17th, 2011, 03:49 PM   #16
Zipper Repair Help Mike K General Motorcycling Discussion 5 April 11th, 2015 02:07 PM
Zipper to connect the pants to your jacket redsuns03 Motorcycle Gear 14 August 12th, 2014 08:49 AM
Dainese Jacket Zipper Falcor Motorcycle Gear 10 January 18th, 2013 06:53 AM
Question about daily textile jacket using zipper vs velco jfauerba Motorcycle Gear 1 April 27th, 2009 02:10 PM
[tilted horizons] - Aerostich Remote Control Zipper Sliders! Ninjette Newsbot Motorcycling News 0 April 1st, 2009 09:40 AM
