Old December 28th, 2011, 05:10 PM   #1
hazelberg
hazelberg's Avatar
Motorcycle(s): 06 Kawasaki 250R
Exclamation 06 Ninja 250- Starting Issues. Need help
So I just bought this bike two days ago. Rode it the last two days and everything was fine. Took it out today, started up fine. Cranked several times actually. But all of a sudden, it wouldnt turn over anymore. I hit the start button, and it doesnt even attempt to crank anymore. All it does is make a whiney, grinding noise. Any advice would be appreciated
hazelberg is offline   Reply With Quote
Old December 28th, 2011, 05:14 PM   #2
Try and jump it from another battery. If it starts right up, your battery is likely toast. When the battery is very close to dead, it doesn't have enough juice to engage the starter gear so it can sometimes make that whiny noise.
Old December 28th, 2011, 05:16 PM   #3
hazelberg
hazelberg's Avatar
Can I jump it off with the battery on my truck?
Old December 28th, 2011, 05:27 PM   #4
Yes, as long as the truck is off.
Old December 29th, 2011, 04:00 PM   #5
Dragone
Dragone's Avatar
Motorcycle(s): '86 VFR 750, '90 ZX7, '92 KZ1000, '05 ninja 500, '05 6RR, '06 10R, '07 ninja 250
It does sound like the battery may need to be replaced. Check and clean the terminals before you jump it from a non running vehicle.
Dragone is offline   Reply With Quote
Old December 29th, 2011, 07:19 PM   #6
Skippii
Milkshake Drinker
Skippii's Avatar
Whiney noise? I've drained my battery dead hundreds of times, and I've had wimpering, coughing, and the usual clicking noises, but never a whine. Is it a whine like an electric motor running quickly? If so, your starter motor may no longer be connected to your crankshaft...
Posted via Mobile Device
Old December 29th, 2011, 07:26 PM   #7
Skippii
Milkshake Drinker
Skippii's Avatar
Can you bump start it? That's sometimes easier than jumpstarting anyway. And fwiw, I jump my ninja from my car when it's running all the time, and jump my car from my bike. Never had a problem. check the running voltages if you're not sure (well, okay...we'll go ahead and tell you the ninja is a bit over 14 since that might be hard for you to test....). My car is almost the same.
Old December 29th, 2011, 10:19 PM   #8
hazelberg
hazelberg's Avatar
I jumped the bike off with the car and it started right up. My battery was garbage. Bought a new one and all is well
Old December 30th, 2011, 11:18 AM   #9
JLinde1339
Fighterer in Training
JLinde1339's Avatar
Motorcycle(s): 2001 Ninja 250R
What battery did you go with, if you don't mind? Just curious, as I'm also in the market for a new one.
JLinde1339 is offline   Reply With Quote
Old January 1st, 2012, 08:57 AM   #10
pantera
pantera's Avatar
Motorcycle(s): 2016 Kawasaki Vulcan 900 Custom / 2017 Kawasaki Ninja 300
Glad all is well
pantera is offline   Reply With Quote
Starting issues, Ninja 2010 won't crank BlueDragon 2008 - 2012 Ninja 250R Tech Talk 6 March 12th, 2015 02:49 PM
2006 Ninja starting issues squrtlesride 1986 - 2007 Ninja 250R Tech Talk 5 July 20th, 2013 08:42 AM
Issues with starting arieon69 1986 - 2007 Ninja 250R Tech Talk 15 September 7th, 2012 06:38 PM
Issues starting up Maielstrom General Motorcycling Discussion 2 August 8th, 2012 08:35 AM
Starting Issues mikkel General Motorcycling Discussion 4 July 30th, 2009 01:40 PM
