Old May 4th, 2011, 01:28 PM   #1
jaustin77
Motorcycle(s): ex250
Oil Leak, I think I found it but just needing some advice
I have an oil leak. I found the leak, I think. I think I also know what part to replace, but I'd like some advice just to be sure. I think the part needed is 11009-1873 from this diagram
http://www.ronayers.com/Fiche/TypeID...e_Cover%28s%29
Where the leak is, is on the Left side (Chain side) and is circled in red.
Also is this as simple as unbolting the left side (about 8 bolts) then rebolting it back on?
Thank You
jaustin77 is offline   Reply With Quote
Old May 4th, 2011, 03:18 PM   #2
have you tried just snugging up those bolts to see if that will stop the leak? not too tight... just enough to know that they are not loose.
spray down that area with some engine degreaser and rinse off. that way if it continues to leak, you'll see fresh evidence that it's still leaking.
sorry, haven't had that cover off so I can't help you there.
Old May 11th, 2011, 12:56 PM   #3
Ragnar1x
Motorcycle(s): CBR 600 F4i, 06 250R
You will have to drain your oil prior to changing that gasket. Might want to pick up a crush washer for the oil drain plug while your at it.
Ragnar1x is offline   Reply With Quote
Oil leak Xaero 1986 - 2007 Ninja 250R Tech Talk 11 November 16th, 2013 06:58 PM
Needing Some Tire Advice Flashy 2008 - 2012 Ninja 250R Tech Talk 6 June 19th, 2012 07:40 PM
Oil Leak Help sjc88 1986 - 2007 Ninja 250R Tech Talk 7 December 29th, 2011 04:13 PM
Rear brake fluid leak (container leak?), any advice appreciated. deaddemon 2008 - 2012 Ninja 250R Tech Talk 5 November 6th, 2011 01:52 PM
Preparing for a trip. Needing some advice. dubojr1 General Motorcycling Discussion 3 June 7th, 2010 12:40 PM
