Old June 13th, 2012, 08:14 AM   #1
Shlink
12v Clock Wiring
Hello all! I bought a little 12v LED clock for my bike on Ebay a while back and never got around to installing it.
Now that I'm using my bike to commute to work I really want to put it on.
My question is with the wiring.
The clock has 3 wires coming out of it, and after a little test this is what I assume they are each for:
1. Ground
2. Always Hot (so the time doesn't reset when I turn the bike off)
3. One that turns the clock on when the bike comes on, so the LEDs don't slowly drain my battery all night.
I have some prior experience with low voltage wiring from adding LEDs and street glow tubes to my car.
I'd like to know where the best place to put the third wire is. Where can I access something that turns on with bike that wont be bothered by the clock.
For the always hot I might just run a wire with an in line fuse directly to the battery, unless someone has a better suggestion.
I'd love to hear what you guys have to say!
Thanks
Shlink is offline   Reply With Quote
Old June 14th, 2012, 07:07 PM   #2
k24_cm7
Motorcycle(s): '10 250R SE
third wire can either go to +12, which will leave the clock on always, or possibly to a switch (rocker or toggle switch) ..
or if you want it on when the bike is on , then you can piggy back it off the ignition fuse.
[2010 250R SE]
k24_cm7 is offline   Reply With Quote
Old June 20th, 2012, 07:11 PM   #3
Shlink
Decided to add a whole Aux fuse block by following Carmaroz1985's post.
Awesome info in there =D
Old June 21st, 2012, 08:05 AM   #4
camaroz1985
camaroz1985's Avatar
Motorcycle(s): 2008 WR250R, 2006 Ural Raven (Sold), 2009 Versys Green (Sold), 2008 Ninja 250R Green (Sold)
Glad I could help
camaroz1985 is offline   Reply With Quote
Old June 22nd, 2012, 01:36 PM   #5
Audi_O
Motorcycle(s): '09 Ninja 250r
Where did you mount it? Do you have any pics?
Audi_O is offline   Reply With Quote
Old August 26th, 2012, 04:33 PM   #6
Shlink
I mounted it right below the key.
The clock runs fast and I tend to reset it every Monday.
Usually by Friday its 3 minutes fast.
Sorry the pics are such poor quality.
Old September 5th, 2012, 06:54 AM   #7
Audi_O
This is how I mounted mine.
Old March 27th, 2013, 03:54 PM   #8
ryanG19
ryanG19's Avatar
Motorcycle(s): 2012 Ninja 250r Candy Apple Lime
Where are the wires for the ignition switch? I bought a little LED clock with a back up Li battery. Wiring it just lights up the green, otherwise it's black time.
ryanG19 is offline   Reply With Quote
Old March 28th, 2013, 08:09 AM   #9
Audi_O
I used the headlight fuse under the seat
Old March 28th, 2013, 04:34 PM   #10
ryanG19
ryanG19's Avatar
Ah ok. That seems just as easy. Got a pic of which wire it is? Can you splice it in higher along the line towards the head lights?
Old March 28th, 2013, 04:52 PM   #11
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
You're better off using your license plate light. It's a two wire connector that can be found by removing the passenger seat. It will lay along the right side (brake side) of the bike. It's a switched +12v and won't matter in case the clock shorts out. It would suck if the clock shorts out your headlight or ignition.
The www.ModMy250.com guy
Old March 29th, 2013, 09:56 PM   #12
ryanG19
ryanG19's Avatar
Worked like a charm:
Digital Clock? Hero Danny 2008 - 2012 Ninja 250R Farkles 20 August 19th, 2014 01:45 PM
What do you think of this Clock/Thermometer Display? ryanG19 2008 - 2012 Ninja 250R Farkles 5 January 26th, 2012 11:06 AM
An alternative clock Alex Off-Topic 11 January 26th, 2011 08:06 AM
Motofizz Clock/Thermometer Alex 2008 - 2012 Ninja 250R Farkles 6 January 20th, 2009 01:30 PM
onboard clock Guinss 2008 - 2012 Ninja 250R Farkles 10 January 19th, 2009 11:32 AM
