September 9th, 2010, 06:37 AM | #1 |
Join Date: Sep 2010 Motorcycle(s): 2003 Kawasaki VN800B Posts: 13
Oil leak around shifter seal.
OK, I am looking at purchasing a 2006 Ninjette for my daughter for her 16th birthday. She is only 12 right now, but there are some mods I want to make to the bike and should be able to get those done in 3 years. Plus it is a smoking deal.
I have not personally inspected the bike, but the seller says it is in perfect condition except for a small oil leak around the shifter lever. I am just curious as too how much of a problem this is. Any information is appreciated. Thank you. |
September 9th, 2010, 07:26 AM | #2 |
A lot of time this is not a leak at all. Chain lube is usually the problem. It leaks out of the front sprocket cover and near the shifter shaft.
September 9th, 2010, 07:33 AM | #3 | |
That is good to know, thanks. I probably won't know for sure until I inspect/ride the bike, but it doesn't sound like a major issue. |
September 9th, 2010, 07:34 AM | #4 |
There is a thread here somewhere that has some pictures in it but I can't seem to find it. Still looking though.
September 9th, 2010, 11:45 AM | #5 | |
If it is a shift shaft leak, though, I think it's a real PITA to replace that seal. Hope I'm wrong, but you may want to do some research on how easy/hard it is to do so, just in case. And if it is a shift shaft leak, look for other signs that the bike has been dropped or repaired on the left side. Good luck... I'm sure you'll be "testing" her bike a lot in those 3 years. |
September 9th, 2010, 02:17 PM | #6 |
Leak on right fork seal | AmyF | 1986 - 2007 Ninja 250R Tech Talk | 17 | July 11th, 2014 09:29 AM |
OEM Brand New Fork Oil Seal, Dust Seal (08-12) | capriccio | Motorcycle-related | 3 | June 9th, 2013 05:11 AM |
Unusual oil leak from crankcase seal | xanderick | 1986 - 2007 Ninja 250R Tech Talk | 40 | November 15th, 2012 01:35 PM |
shift shaft oil seal replacement | lolibater | 1986 - 2007 Ninja 250R Tech Talk | 20 | October 10th, 2012 04:22 PM |
Fork seal and oil advice | capriccio | 2008 - 2012 Ninja 250R Tech Talk | 1 | July 23rd, 2011 04:05 AM |
