Old April 1st, 2014, 07:57 PM   #1
wanarace94
The Dark Horse
wanarace94's Avatar
Motorcycle(s): 09 ninja 250r SE, 71 honda Cl100
Digital Tach
I have a different sort of idea for a digital tach. I want to take an arduino and make a digital tach with a shift light for the 250. I am in the preliminary design phases right now trying to create a schematic. I have run into a few questions that I'm hoping people will have answers for.
1. I thought I read the new gen tach was powered by a cable. So a adapter would have to be created. Or is there a wire that has the rpm being run through it? I have not looked at the wiring yet on my bike.
2. What voltage is put out at the stator?
I am sure I will have more questions as time go on but this is it for now.
Thanks!
Kevin
http://mefi.us/images/fuelly/sig-us/146688.png
wanarace94 is offline   Reply With Quote
Old April 1st, 2014, 08:16 PM   #2
The pre-gen and new-gen speedos are run by a mechanical cable to the front wheel. But I thought that the tach was electronic on all generations of the bike.
Old April 2nd, 2014, 07:27 AM   #3
SuperAmp13
Motorcycle(s): 2012 Kawasaki Ninja 250R
The new gen tach rpms are run through a wire in the 9 pin harness. I want to say it is black in color, but i could be very wrong.
If you look up a wiring diagram it will tell you exactly what color it is. The only cable driven guage is the speedo.
SuperAmp13 is offline   Reply With Quote
Old April 2nd, 2014, 10:39 AM   #4
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Here you go.
<-- Linky
Old April 2nd, 2014, 12:02 PM   #5
SuperAmp13
Originally Posted by NevadaWolf View Post
Here you go.
So looking at this diagram (which btw, I am suprised brown is on there. I think brown is actually for the left or right turn signal) you want to hook the black to your tack wire for the digital guage and then black/yellow is ground to ground the entire system. You do not need to only ground the tach.
I literally just converted to a digital tach last week, so I remember these colors and how it works slightly. If you have any questions, let me know.
If you look at my thread, you will see the digital dash I put on.
http://www.ninjette.org/forums/showthread.php?t=173871
Old April 3rd, 2014, 11:46 AM   #6
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
2008+ Ninja 250r FULL Electrical Wiring Diagram here!
The black/yellow is the common ground wire. The brown wire is switched ignition power. The black wire T's off from between the igniter and coil, and is your tach signal.
I'm not sure if the 250 is exactly the same, but when testing the EX500 stator, you're supposed to get around 60VAC between any two of the three stator leads. The regulator/rectifier converts the AC to DC (rectifies) and limits the voltage to the standard "12V" values (regulates).
Old April 7th, 2014, 08:43 AM   #7
linkinpark9812
Motorcycle(s): Black 2012 Ninja 250R
Thanks!
Kevin
I would also recommend using an optoisolator for your tach signal. That way you don't have to deal with any noise from the computer setting off the igniter coils.
On that same note, I believe the 250 uses TDI for ignition. Basically, it GROUNDS the igniter coil wire during ignition, so it is a ground signal you would have to be detecting.
Once you get that, should be pretty easy. Program an interrupt for that pin on a high-low transition. Time between two ignitions and get an RPM!
linkinpark9812 is offline   Reply With Quote
Old April 15th, 2014, 11:32 AM   #8
wanarace94
The Dark Horse
wanarace94's Avatar
Thank you guys very much! I am going to be finalizing some of my ideas this weekend when I am home from college. I will keep you updated!
Old April 20th, 2014, 09:28 AM   #9
bitaria
Motorcycle(s): CRF450X, CRF250R/SM, Husky 630 SMS, Ninja 250R
Subscribe. I'm doing something similar with the idea of using it as racing data logger. Would be interested on updates, especially any efforts to clean up analog signal.
bitaria is offline   Reply With Quote
Old May 5th, 2014, 10:52 AM   #10
wanarace94
The Dark Horse
wanarace94's Avatar
I talked to an EE from a different engineering school in MKE both in agreement a capacitor is going to be worth a try.
My semester is done next week and I will be splitting my free time after my internship on this project and a few other ones i have going on.
Old May 5th, 2014, 02:08 PM   #11
bitaria
Feel free to post up a schematic if you get it working!
Old May 7th, 2014, 07:23 AM   #12
bitaria
http://www.allaboutcircuits.com/vol_2/chpt_8/2.html
You may find this useful, I did a bit more looking around last night, not sure yet which design will have the best results, but implementing a simple filter like this should do the trick for tach signal.
Delayed Tach 07_25_stl 1986 - 2007 Ninja 250R Tech Talk 8 January 13th, 2015 07:21 PM
Tach does not exceed 4k bryzenga 1986 - 2007 Ninja 250R Tech Talk 4 October 18th, 2013 06:59 PM
Help me fix my tach! corksil 2008 - 2012 Ninja 250R Tech Talk 7 October 1st, 2013 04:53 PM
Another tach issue Cosmos 2008 - 2012 Ninja 250R Tech Talk 2 July 19th, 2013 06:04 AM
tach replacement Broom 2008 - 2012 Ninja 250R Tech Talk 9 June 4th, 2009 05:34 AM
