Old November 29th, 2013, 10:56 PM   #1
Quick1
Motorcycle(s): 1992 Ninja 250
Vacuum hose cross caused leak
Now that my car is totaled, I only have this bike that's been sitting for a couple years to get me around- but paying to have it repaired was out of my realm of possibilities. So, I did my first carb cleaning myself, but it was still clogged when I tried it out. The second cleaning, I took the tops out and some hoses off and was much more thorough, but made the noob mistake of attaching the vacuum lines back together wrong. I connected the #2 carb's vacuum to petcock instead of to coasting enricher and connected #1's vacuum to coasting enricher. This caused fuel to dump out of the overflow hose.
I figured I screwed something up during the carb cleaning and bought another new carb (off a running bike), but when I noticed the hoses were routed differently (the new carb had fittings for California), I swapped them over from the old carb (not knowing they were wrong). When I saw the fuel coming out the overflow again, I realized I was duplicating the problem & I researched and found the crossed vacuum lines. I reattached them correctly and it stopped MOST of the fuel coming out the overflow, but not all- still has a small stream that only flows when petcock is ON or RES. My first question is what do you think is wrong inside the carb now? Possible damage to the coasting enricher diaphragm? I figured maybe I should give up and leave it too a professional and took it in to the local Kawasaki dealership, but he started in with the sales pitch of thinking it needed not just carb work done, but probably the petcock too (I had installed one off a 2007) saying I damaged it from installing the vacuum hoses to it wrong. He wanted me to leave a deposit of $400, but estimated it will cost a minimum of $800!!! Guys- I'm not doing well financially (which is why I tried to do the work myself)..... I don't HAVE $800 to fix my old bike!
My second question involves spark. I pulled my spark plugs and tested them by arcing to the frame and I have a pretty good spark. But after reinstalling them, neither hooking up either of the carbs nor squirting starting fluid directly into combustion chamber will start engine. Any ideas on why a plug that sparks and has fuel, won't ignite?
Right now, I own a broken bike and a wrecked car and no way to get to my job....... I hope you all can help me figure this out.
Last futzed with by Quick1; November 30th, 2013 at 03:57 AM.
Quick1 is offline   Reply With Quote
Old November 30th, 2013, 04:39 PM   #2
agentbad
agentbad's Avatar
Well if you've tried starting a lot you might have drained the battery so there's that. I don't think it would hurt the carbs if you hooked up the vacuum hoses wrong. Maybe you have a stuck float. Sounds like the dealer is just trying to hustle you.
Old November 30th, 2013, 05:01 PM   #3
DaBlue1
DaBlue1's Avatar
A bike that old and that has been sitting for a while can have a list of possible problems. I would definitely have a compression test done on the cylinders and think about getting another (good) IC Ignitor to rule out if yours is bad or not. Even though you have spark, it may be timed wrong.
Also, have a look at the Trouble Shooting Guide.
Old December 1st, 2013, 01:32 AM   #4
Quick1
The thing is that I had it started last week until it ran out of gas (the fuel line wasn't hooked up), but when I connect the fuel line it overflows gas and won't start.
I pulled the carb again and checked the float and they are both at 18, so within range of 17 +/- 2. I checked both floats and in perfect shape with no debris on the needle or down in the seat. Floats were checked and do- indeed- float.
Old December 1st, 2013, 01:37 AM   #5
Quick1
Keep in mind that BOTH carbs are doing this.....the original which has been cleaned thoroughly and the new one which was pulled from a running bike.
Old December 1st, 2013, 03:43 PM   #6
agentbad
agentbad's Avatar
http://www.ninjette.org/forums/showthread.php?t=110362
http://www.ninjette.org/forums/showthread.php?t=146834
http://faq.ninja250.org/wiki/How_do_...n_the_carbs%3F
Old December 23rd, 2013, 01:48 PM   #7
OP - did you get everything sorted?
Old December 23rd, 2013, 01:57 PM   #8
Quick1
No.... I don't have access to covered storage & the rainy season hit here in Seattle. I think the veterans admin might fix it for me in a month or two. Lost my job already.....
Old December 23rd, 2013, 02:13 PM   #9
Shoot - sorry to hear that.
Old December 23rd, 2013, 03:19 PM   #10
Quick1
Smile
It's ok. I'm just unable to tear into it and troubleshoot. I live where it can't be left torn down & a pain in the arse to reassemble everything after trying one thing. I learned a LOT about rebuilding/understanding a carb and not so intimidated by trying to fix it myself, so I got that out of it!
Plus, it's nice being a part of this community. Pretty sure I'm a Ninjette rider for life!
2005 ninja 250 vacuum leak/clog? fuel664 1986 - 2007 Ninja 250R Tech Talk 31 July 29th, 2015 06:53 PM
Vacuum leak maybe? iflylow 1986 - 2007 Ninja 250R Tech Talk 4 February 24th, 2014 01:47 PM
2007 won't idle. Vacuum leak or something else? cookiebug79 1986 - 2007 Ninja 250R Tech Talk 23 September 30th, 2013 09:28 AM
vacuum hose routing Sebastian f7 1986 - 2007 Ninja 250R Tech Talk 2 July 28th, 2013 07:06 AM
Need help connecting a vacuum hose Yaozer 2008 - 2012 Ninja 250R Tech Talk 11 July 3rd, 2013 02:29 PM
