July 7th, 2011, 05:05 PM | #1 |
Join Date: Jun 2011 Motorcycle(s): 98 Ninja 250 Posts: 45
Routing for fuel overflow hose
Can anyone tell me what the routing is for the fuel overflow hose? It connects to a port between the 2 cards. I think the hose is missing altogether so if anyone could give me an idea of how much hose to buy it would be greatly appreciated. I can't find a diagram in the FSM.
One last thing, what size hose do I need? Last futzed with by haze5736; July 7th, 2011 at 05:14 PM. Reason: added question |
July 7th, 2011, 05:25 PM | #2 |
I found a parts diagram with a description. Says the hose is 6.5x9.5x500. Can someone tell me what those numbers mean? And can I find that size tubing in most auto part stores?
July 7th, 2011, 06:21 PM | #3 |
I think it's saying it's 6.5mm inside diameter, 9.5mm outside diameter, 500mm length.
doubt you will find mm hose at a parts store, so just use some fuel line that will fit the over the vent between the carbs that's about 20". |
July 7th, 2011, 07:09 PM | #4 |
Join Date: Dec 2008 Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike Posts: 890
6.5mm is very close to 1/4". Use some 1/4" fuel line.
2008 250R Carb hose routing? | devildogae | 2008 - 2012 Ninja 250R Tech Talk | 12 | November 6th, 2016 04:32 PM |
Carb Hose Routing | jschatte | 1986 - 2007 Ninja 250R Tech Talk | 6 | July 8th, 2014 08:30 AM |
vacuum hose routing | Sebastian f7 | 1986 - 2007 Ninja 250R Tech Talk | 2 | July 28th, 2013 07:06 AM |
Need Visual Confirmation of Carb Hose Routing | indr | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 23rd, 2013 07:49 PM |
Routing for 'side hose' on fuel tank | kobachi | 2008 - 2012 Ninja 250R Tech Talk | 11 | December 12th, 2010 05:00 PM |
