Old June 14th, 2009, 03:49 PM   #1
krbreton
krbreton's Avatar
Motorcycle(s): '97 Ninjette, '06 Ninja 650R
ZX600 Rear Shock Question
Hi All-
Based on the advice in the ninja 250 FAQ, as well as my current weight of 200 lbs, I decided to upgrade the rear shock on my 1997 Ninjette. I bought a 1989 Ninja ZX600 Shock off ebay. When I got it, I pressure tested it, and then drained/replaced the oil with 7.5W Fork Oil. However, when I drained the shock, I only got about 150mL of fluid out of the shock, including heating the shock body with a hair dryer. I then replaced an identical amount of fluid using a syringe.
I am wondering - Since the FAQ says that there should be about 285mL of oil in this shock, is there some sitting in the shock still, or should I assume it was underfilled and then top it off. How would I know when there is too much oil in the shock? Should I just fill it until it starts running out of the fill-hole? Should I try to drain the whole thing again, now that the fresh oil has been in there and see if I get more fluid?
Any suggestions would be helpful. I don't want to put the shock on the bike until I have it set up with the oil level correctly.
Thanks in advance,
Kyle
krbreton is offline   Reply With Quote
Old June 14th, 2009, 03:53 PM   #2
Snake
Snake's Avatar
Did you try moving the shock in and out to try and force the old fluid out? Try that and then fill with the 285ml as reccomended.
Old June 14th, 2009, 05:51 PM   #3
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
I can't really help with your question, but welcome to ninjette!
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old June 15th, 2009, 11:24 AM   #4
krbreton
krbreton's Avatar
Hey Guys-
Thanks for the responses. I'll stick it on the bike and work it through a few times, take it off and drain it, and then fill with the recommended 285mL.
Hopefully, I'll get a chance to have somebody check it out at the next Bay Area Ninjette ride.
-Kyle
Old June 15th, 2009, 11:31 AM   #5
Snake
Snake's Avatar
Let us know how you like it after it is all set up.
85-86 Kawasaki Ninja 600 ZX600 Rear Mono Shock LittleRedNinjette Motorcycle-related 0 March 13th, 2015 12:24 PM
Gixxer rear shock question - rear stiffness too high cookiebug79 2008 - 2012 Ninja 250R Tech Talk 20 January 17th, 2015 08:19 AM
Rear shock question LoneRonin 2008 - 2012 Ninja 250R Tech Talk 5 September 22nd, 2014 03:09 PM
ZX600 shock AlanDog Free stuff! 5 November 22nd, 2013 10:59 AM
ZX600 shock davidw38901 1986 - 2007 Ninja 250R Tech Talk 6 October 23rd, 2013 09:50 PM
