Old March 21st, 2023, 12:40 AM   #1
SS310
Starter seemingly misaligned with gear
It feels im posting so often here, apologies but my bikes just a mess rn
Anyways, I went down a month ago and recently started working towards gettign the bike running again. Already discovered carb and electrical issues though I now have a starter issue. Most of the time itll crank normally, but sometimes ill make a nasty sound like the gear skipped, stop, then get free again if you hold it down. My friend who heard the sound said it was the same sound his truck made when the starter wasnt aligned with the flywheel right.
This sounds about right, though I am unsure how it would be possible for it to be misaligned. It can only go in one way and can only go in if the gear is meshed. I took the starter out and both gears look just fine.
Ideas? How bad of an idea would it be to keep using the bike if I cant find a solution before its ridable again?
SS310 is offline   Reply With Quote
Old March 21st, 2023, 06:07 AM   #2
The chances are that this is a result of normal wear over the years, and the starter's overrunning clutch is slipping. Post #3 of this thread gives the part numbers for the parts of that clutch: https://www.ninjette.org/forums/showthread.php?t=244118
The page at Partzilla has changed, so that link doesn't work. The page is now here: https://www.partzilla.com/catalog/ka.../starter-motor
Old March 21st, 2023, 11:07 PM   #3
SS310
So do I need #13193? How hard is it to change this out, coz I feel like I read something about it being a massive pain only a shop should do but I dont remember
Old March 22nd, 2023, 05:46 AM   #4
I haven't had mine apart. Post #3 of the thread I linked to gives three part numbers for the parts that wear, but it would be a good idea to take yours apart before deciding what it needs. I'd think that taking the starter out, which you have practice with, is most of the work, but maybe someone here who's done it can shed some light.
2010 Ninja 250 starter gear holder broken and flywheel gear broken BikeRider General Motorcycling Discussion 11 March 5th, 2019 06:50 PM
DIY Starter Gear Repair DannoXYZ 2008 - 2012 Ninja 250R Tech Talk 8 August 1st, 2017 02:56 PM
One Way Clutch Gear / Starter Drive Problem am777 2008 - 2012 Ninja 250R Tech Talk 4 October 30th, 2016 08:29 PM
starter idle gear akcalhoun 2008 - 2012 Ninja 250R Tech Talk 6 June 30th, 2013 07:42 AM
Hello starter oneway gear question jibberish71 1986 - 2007 Ninja 250R Tech Talk 8 May 7th, 2011 02:32 PM
