Old March 29th, 2023, 09:55 AM   #1
ned883
Motorcycle(s): '04 Ninja 250
Talking New Member - Story of my 250 and plans
Hi guys,
My name is Nathan, I'm a new rider from central MA, and I ride a '04ish Ninja 250. I say '04ish because it's a hodgepodge of parts from who knows how many bikes. I bought a mostly complete 250 with a bad carb, a parts bike, and a stack of other parts from a guy last summer for $800. It turned out that the complete bike had a title that was tied up with a previous owner who was going bankrupt, so I moved everything over to the parts bike frame, which surprisingly had a good motor and clean title. Since then, I've learned to ride on it, it's been stolen (only for a joyride, nobody besides me wants to keep this bike) and recovered, and is now safely back in my shed for the winter with a broken ignition and lots of fuel conditioner.
I'm in CA right now, away from my bike in MA, but once I get back this summer I have some big plans for it. I'm going to do some maintenance, rebuild the carb again (last summer I only cleaned it, and it still needs some work), figure out a fix for the ignition, make an anti-theft system, do a 17" wheel conversion, and most importantly, ride the **** out of it! I miss my bike.
For the ignition, I'm thinking about just wiring in a switch without a key and just relying on my anti-theft system. For my anti-theft system, I'm thinking about wiring in an uncommon connector that intercepts the wires from my ECU, so I can disable the bike by removing my "key," which would effectively be a complicated jumper wire. I don't expect anyone to steal my bike with a truck, it's almost worthless. If someone wants my 250 that bad they can have it.
I want to do a 17" wheel conversion because as some of you probably know, the 16" tire selection is very limited. I want a nice performance summer tire, and I'm planning on riding in the winter in Boston to get to class (30 minute walk, 10 minute drive, 5 minute ride ), so I'll need a set of winter tires as well. I've seen in a few places that I might be able to use later gen 250 parts to put 17s on my early gen 250. I'ved got some more research to do, but it looks achievable. I know I could just buy a later gen 250 for the same result, but I like this bike; we've gone through a lot together already.
I also have a '99 miata if anybody here's into them.
Thanks for welcoming me to your forum!
ned883 is offline   Reply With Quote
Old March 29th, 2023, 10:12 AM   #2
Abu_Mishary
The Asian Caucasian
Abu_Mishary's Avatar
Name: Abu Mishary Mohd Fairus
Motorcycle(s): Kawasaki Ninja 250 SE 2015 (sold); Honda ADV160 (current)
MOTM - Jan '17
ned883! Glad you found us...
Losing someone is not painful. They are a part of us all this while and will always be with us. But missing them is.
Abu_Mishary is offline   Reply With Quote
Old April 3rd, 2023, 04:38 PM   #3
Snake
Snake's Avatar
Hell and welcome!
Old April 3rd, 2023, 04:55 PM   #4
It's good to meet you, Nathan... Welcome!
Old April 4th, 2023, 09:12 AM   #5
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Welcome! What part of CA are you in? I'm on the coast, between LA and Santa Barbara.
Old April 20th, 2023, 06:22 PM   #6
Greetings & Salutations!!!
I've done 17" conversion. Really easy by swapping entire rear-end: swingarm, brakes, sprocket & carrier, shock, linkage, rear-wheel. Completely bolt-on mod, perfect fit. Cheap parts off ebay, about $250 total.
Front, just weld on little brake adapter bracket and slide 17" front wheel in.
https://www.ninjette.org/forums/showthread.php?t=266182
The story of my 250, with a lesson at the end Tooch 2008 - 2012 Ninja 250R Tech Talk 3 March 22nd, 2019 11:15 PM
Another 250! New member jjmaine New Members 11 July 25th, 2016 04:45 PM
New member - Semi-big plans - help? cydisc General Motorcycling Discussion 24 April 27th, 2016 12:59 PM
[topix.net] - Sons of Anarchy motorcycle drama: A story behind the story Ninjette Newsbot Motorcycling News 0 October 26th, 2010 07:50 AM
[2wf.com] - Daytona 200; The story behind the story Ninjette Newsbot Motorcycling News 0 March 22nd, 2010 01:20 AM
