Old February 20th, 2012, 05:15 PM   #1
wolfpuss
Motorcycle(s): 06 ninja 250
06 ninja 250 won't start
Hello fellas.
I recently bought my first nijette and my experience has been awesome well until today.
Story:
I've been riding my little scooter for 3 days with no issues besides aesthetically.
well today i ran into a significant snag (i hope not)
I was out cruising and next thing you know the bike bogs down and eventually dies, it happened in front of a gas station so i pulled in and turned the petcock to reserve. I tried starting it with no success. So thinking that i ran out of gas i Immediately put some gas in and tired starting it ....still a no go. I eventually tried starting it with the choke on ( warm engine) and it fired up for a few seconds a died again. I tried repeating the process till my battery died. Thinking i flooded the engine, I ended up having to do the dreaded "push my bike home" for 3 miles.
Drained from my endeavors, i got home took the battery out and charged it. 2 hours later with the battery charger saying full charge. I decided to put it back in and start it to no avail.
Can anyone experienced this?
Some help would be awesome
Thanks
Randy
Last futzed with by wolfpuss; February 20th, 2012 at 09:05 PM.
wolfpuss is offline   Reply With Quote
Old February 20th, 2012, 07:04 PM   #2
planet-beaver
Motorcycle(s): Ninja 250, Vulcan 500
Two things that can stall the ninja like that. No fuel, no spark. If you were able to start it on the choke for just few seconds, it sounds like fuel. Just to make sure, spray some starting fluid in the air intake and see if it fires up for a second. If it does, it's the carbs that are gummed up.Even though the bike ran fine for few days, if it was sitting around without fuel treatment in the gas, the sludge will eventually make it's way to the jets and stop you cold.
planet-beaver is offline   Reply With Quote
Old February 20th, 2012, 07:27 PM   #3
wolfpuss
bump just finished checking everything. And i seem to found the problem. the petcock is not working!!
took the hose going to the filter and turned the petcock on. no flow!!!
even if i put it in reserve there is no flow whatsoever
Old February 20th, 2012, 07:43 PM   #4
setasai
setasai's Avatar
The petcock needs vacuum to flow. Apply a vacuum to the other port and that should allow the fuel to flow. Other way is to switch the petcock to prime, If you have a prime feature on yours. That should bypass the vacuum block. If nothing works then there might be a clog in your tank. Try using compressed air to clear the line.
2009 Ninja 250R SE Green Sport Touring Style:
ZG ST; Symtec heated grips; RAM GPS w/ mUSB; DIY reshaped seat; DIY Givi E21 Sidecases; 15T sprocket
Old February 20th, 2012, 08:51 PM   #5
wolfpuss
well the petcock works fine, i took out the spark plugs and cleaned them with carb cleaner. and tired starting it again to no avail. sounded like it was gonna catch and start but her answer was no. i guess its time for her to rest till i get a chance to work on her sometime tomorrow (suppose to be raining)
oh well...
Old February 20th, 2012, 11:29 PM   #6
shiftdrift06
Motorcycle(s): None
oh well...
By any chance when you clean the plugs, you test if they spark when crank it?
How do they look/color? Check the gap?
shiftdrift06 is offline   Reply With Quote
Old February 21st, 2012, 05:07 PM   #7
clean the carbs.
http://www.ninjette.org/forums/showthread.php?t=65198
Old February 21st, 2012, 05:57 PM   #8
wolfpuss
I ended up draining the carb bowls and replacing the spark plugs and she's back running again!! So happy so see her run lol
Had her running for a few mins at about 3k to get the old stuff out.
Thanks for the input fellas
05 Ninja 250 won't start on its own - help! AmyF 1986 - 2007 Ninja 250R Tech Talk 59 July 8th, 2014 11:46 AM
2004 250 ninja help -- won't start SON1C 1986 - 2007 Ninja 250R Tech Talk 6 March 24th, 2014 10:30 AM
2007 Ninja 250 won't start Time Mage 1986 - 2007 Ninja 250R Tech Talk 24 June 17th, 2013 10:14 PM
Ninja 250 won't start! please help me! Black knight 2008 - 2012 Ninja 250R Tech Talk 4 May 23rd, 2013 03:22 PM
2001 Ninja 250 - Won't start AGFE0914 1986 - 2007 Ninja 250R Tech Talk 28 April 11th, 2013 06:09 PM
