Old February 1st, 2016, 09:46 AM   #1
Floki
Motorcycle Nurse?
Floki's Avatar
Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100
Re-doin Valve Seats
Is 160 to get them done a good deal?
Also, the clutch cover gasket gets replaced everytime the clutch cover comes off right?
Floki is offline   Reply With Quote
Old February 1st, 2016, 06:22 PM   #2
bruce71198
bruce71198's Avatar
are the replacing the seats or cutting them? I'll check what our local guy charges in the morning. If the gasket isn't ripped use it again.
Old February 1st, 2016, 06:26 PM   #3
Are you fully opening the throttle during the compression tests?
Did you do a leak-down test?
http://www.dansmc.com/compression_test.htm
[url]http://www.dansmc.com/leakdown.htm[/url
Are you sure your low pressure comes from leaky valves?
Leaky rings or/and guides of valves?
Yes, the gasket gets ruined each time, unless you put grease on both sides of the gasket and it does not take too long to remove the cover again.
Old February 1st, 2016, 06:31 PM   #4
Floki
Motorcycle Nurse?
Floki's Avatar
Cutting them. And I'm pretty sure that's where the fault is. One of my intake valves on the faulty cylinder was .012in
Old February 1st, 2016, 08:21 PM   #5
I mean... I've never looked into that because mine were in good shape, but that doesn't seem too bad for someone to do that work that has the proper reamers and setup for it.
You taking the head off and bringing it to them or are you delivering the bike and they're doing all the work?
Old February 1st, 2016, 08:34 PM   #6
Floki
Motorcycle Nurse?
Floki's Avatar
Already have the head off and boxed about. About to send it to HFD1 in Georgia
Old February 1st, 2016, 09:17 PM   #7
Well look at it this way: most machine shops and motorcycle shops charge somewhere from 75-100 dollars per hour. That means your valve seat cutting job is expected to take somewhere around 1.5-2 hours. Does this seem fair to you? If so, then it's a good price.
That seems fair to me, considering that they're cutting multiple angles and they're doing 8 valve seats in about 2 hours. That's just me.
As for the clutch cover gasket: that's a paper gasket yes? If it's in good shape, get some good RTV (Yamabond or Threebond are two of the best for staying set up really well under oil and not getting gooey) and dress the gasket a little in RTV on assembly. Be careful not to goober it up in the case. If the gasket tears at all, replace it. Not worth the money to have to deal with drips.
Old February 2nd, 2016, 04:45 PM   #8
bruce71198
bruce71198's Avatar
Our local guy charges $175 to do a single cylinder, 4 valve MX head. that includes setting the valve lash when done so $160 sounds real fare.
Old February 3rd, 2016, 11:42 AM   #9
mgentz
Board Member
APE Racing has decent prices as well....
Old February 10th, 2016, 01:40 PM   #10
APEmike
Motorcycle(s): 2014 Ninja 300
Thanks! lol
Just a heads up, angles aren't cut one at a time. The cutters are set up to cut them all in 1 go. The pain in the behind part is just getting everything lined up right. Thats why there isint a huge gap between a 4 valve head, and a 16 valve head. You can do all 8 on one side of a 4 cylinder nearly as fast as a 4 valve single because once you get the machine set up its a simple process of sliding over to the next hole. But the setup is the tricky, time consuming part...
And DONT get me started on the stupid Honda thing where they have 4 valves in a chamber all pointing different directions!!!
I ride because therapy is too expensive, and less fun.
APEmike is offline   Reply With Quote
Old February 10th, 2016, 01:41 PM   #11
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Originally Posted by APEmike View Post
Thanks! lol
RFVC heads.....ah, the 80's were good years, no?
Goin' fast on slow bikes!
Old February 10th, 2016, 01:45 PM   #12
APEmike
Yeah, them... I forgot the acronym. Yeah, the bike was designed and first build in the 80s but its still produced. XR650. The TRX400ex uses the same design.
Old February 10th, 2016, 01:47 PM   #13
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Really? That's surprising....I haven't torn in to a modern XR650 or 400EX. Figured they'd all have gone pentroof by now.
Old February 10th, 2016, 02:13 PM   #14
APEmike
Yeah the XR has only changed plastics in the last 30 years. Maybe some minor bits here and there but most stuff is unchanged or interchangeable.
Case in point...http://www.partspitstop.com/oemparts...6-670/cylinder
Btw, save that site to your favorites. OEM Parts fiche for nearly every bike made in the last 40 years, including our ninjette. I never buy from there but it helps figuring out whats what, what to call something, where its located, or just to look at the inner workings of stuff.
Old February 10th, 2016, 02:25 PM   #15
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Thanks! I also use Bikebandit.com which has fiches for everything (Including my 1972 XL250 race bike) as well as Ronayers.com. The problem with Bikebandit is they don't use factory part numbers but their fiches are super easy to navigate if you just need a blown up diagram.
Old February 10th, 2016, 03:22 PM   #16
bruce71198
bruce71198's Avatar
Thanks! lol
Don't leave out the 5 valve Yamaha's
Old February 10th, 2016, 03:27 PM   #17
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Eh, still not as bad as a Honda. Yamaha only requires three set ups for the three different planes. Honda is 4 planes no matter how you slice it.
Old February 10th, 2016, 05:30 PM   #18
APEmike
What I dont get about Yamaha Titanium valve engines is how they can get away with 20k valve lash intervals when other Titanium or steel engines (like ours) are all under 10k... Titanium is VERY soft and its only a hard coating that keeps them alive for any time at all. Must be coated in Unobtanium!
Old February 10th, 2016, 08:00 PM   #19
hfd1 tuner
Motorcycle(s): many mostly racebikes cbr565 fzr490 ex250ish
because they break before 20k.....I hate ti valves....great for short term sucks when it is time to do service work. Suzuki 1200.00 for just valves just stupid if you ask me.....
hfd1 tuner is offline   Reply With Quote
300 air switching valve and purge valve (CAL) removal joyspring 2013 - 2017 Ninja 300 Tech Talk 21 February 13th, 2017 01:36 PM
Fixed valve cover bolt leak & valve clearances Linkin Videos 3 June 24th, 2015 03:49 PM
new seats YellowNinja Pictures 10 October 10th, 2014 03:02 PM
Dropped bike off for valve adj. v. New valve stems? edxmon 2008 - 2012 Ninja 250R Tech Talk 14 July 17th, 2012 04:55 PM
Where to get Different Colour Seats Sinical 2008 - 2012 Ninja 250R Farkles 7 March 17th, 2012 10:23 AM
