November 14th, 2016, 01:03 PM | #1 |
Lucid, yet unaware.
Join Date: Aug 2011 Motorcycle(s): 2006 Goldwing; 2009 KLR-650; 2011 Ninja 250; 2010 FJR-1300 Posts: 173
2011 Drive Chain Replacement
I checked the wiki but couldn't find ANY information listed under it.... as in no wiki articles?????
My 2011 has just under 17K and the drive chain is stretched to the service limit. Looking for some recommendations on a replacement chain and sources to buy it. From what I can determine I need a 520-106 chain, is this correct? I have also seen references to a 520-120 chain. Which is correct? Do most of you go with the o-ring or the more expensive x-ring? I have checked my sprockets and they still look pretty decent. The teeth look pretty full and there is no hooking going on. The chain is stock but the sprockets are not. They have a few less thousand miles on them because after having the bike for a bit, I went one tooth up in the front and one tooth down in the rear. Do you replace your sprockets every time you replace the chain? I have a chain breaker tool set from Motion-Pro that appears to have everything I need to disassemble install a rivet chain. Am I missing anything else that I should be aware of? Thanks. Gregg
2011 Ninja 250, 2010 FJR-1300, 2009 KLR-650, and 2006 Goldwing IBA #485, Goldwing Darkside #646 http://va-ldrider.blogspot.com |
November 14th, 2016, 01:09 PM | #2 |
You can get a lot of information here: http://faq.ninja250.org/wiki/Final_Drive
November 14th, 2016, 01:12 PM | #3 | |
Lucid, yet unaware.
November 14th, 2016, 05:14 PM | #4 |
i prefer non ring chains , less friction
November 14th, 2016, 05:16 PM | #5 |
X-ring chains probably have a little less friction than O-ring chains, because the arms of the X bend easier than solid O-rings squish, but I don't know if the difference is significant.
November 14th, 2016, 06:10 PM | #6 | |
EX500 full of EX250 parts
November 14th, 2016, 10:13 PM | #7 |
Certified looney toon
MOTM Jul '13, Jul '14
Our bikes take 106 links
The 120 is a standard generic length that needs to be broken down to 106. The nice thing about the Motion Pro tool is that is has the breaker part right in it. I have that tool and have used it every time I change chains. I'm not picky on my chain, so buy whatever 520 o-ring a shop has in stock. I'm also lame that I don't change my sprockets (15 and 45) at the same time so yeah my chain life hasn't been great but whatever.
November 14th, 2016, 11:20 PM | #8 | |
Lucid, yet unaware.
November 14th, 2016, 11:25 PM | #9 |
It's what I'd do but I'm cheap.
November 15th, 2016, 06:15 AM | #10 | |
Join Date: Jul 2015 Motorcycle(s): 2001 Ninja 250, 2019 Harley Ultra Classic, 2001 Suzuki SV650 Posts: A lot.
MOTM - Jan '16
But I also went back to my stock gearing. I didn't think the slight drop in RPM really did anything for my gas mileage, but it sure did feel like less acceleration compared to my bikes with stock gearing. |
November 15th, 2016, 06:45 AM | #11 |
Lucid, yet unaware.
I thought about going back to stock as well just to get some acceleration back but I don't know where I put the stock sprockets...
November 15th, 2016, 06:59 AM | #12 | ||
November 16th, 2016, 01:31 PM | #13 |
MOTM - Jan '16
And that lag at takeoff is pretty significant on a lowly 250 in stop and go rush hour traffic.
From my experience, in the way I ride, there isn't any difference in gas mileage between stock 14/45 and 14/42 gearing. When I had the taller gears on and would ride with my kids who have stock gearing fuel consumption was almost identical. I would be running about 1,000 RPM slower engine speed. But, when we would stop for gas pretty much identical amounts of fuel. My daughter would get a little better mileage, but I out weigh her by 65 lbs and she is a little lighter on the throttle than I am. My son actually seemed to use a bit more than me. |
November 16th, 2016, 02:33 PM | #14 |
I guess you're right that it's significant, but I have 15/45, which is the same as 14/42, and to me it has an extremely low gear. I can idle along in 1st at walking speed. If with stock gearing the engine was running at 7,000 rpm, now it's going 6533, less than 500 rpm slower. I agree that this is probably not a big enough difference to change gas mileage significantly.
November 16th, 2016, 05:13 PM | #16 |
With six transmission ratios, it's not hard to stay in whatever RPM range you desire, regardless of sprocket ratios. If I go to 15/42 or 15/41 I expect I'll use 6th gear less. 6th may become more like the classic overdrive.
November 16th, 2016, 05:39 PM | #17 |
Join Date: Jun 2013 Motorcycle(s): 2010 Ninja 250 Posts: 596
No worries about your logic there. I'm just being difficult with the terminology. :P
Engine speed is only a result of what leverage we get out of the gearing. Just from that we can't quite extrapolate whether gas mileage will be improved without assessing the rider's baseline driving habits. |
November 19th, 2016, 04:40 PM | #18 |
Lucid, yet unaware.
New RK 520XSO 106 link chain went on just fine. Used the breaker and rivet tool set from Motion Pro. The ends of the master link didn't flare or mushroom head like some pics I have seen but it flared enough. Took it out today for about 300 miles. All is well. Oh, didn't change the sprockets. They seem like they have plenty of miles left in them.
November 20th, 2016, 02:15 AM | #19 | |
chain and sprockets replacement | jcsalazar | 2008 - 2012 Ninja 250R Tech Talk | 6 | August 24th, 2014 02:19 AM |
[motorcyclistonline] - Drive Chain Maintenance | Drive Time | Ninjette Newsbot | Motorcycling News | 0 | May 9th, 2013 05:30 PM |
chain replacement | eddiekay | General Motorcycling Discussion | 3 | December 31st, 2011 10:34 AM |
Drive Chain Advice! | EvnEvn724 | 1986 - 2007 Ninja 250R Tech Talk | 1 | August 22nd, 2011 04:15 PM |
Cush Drive Replacement | jorgecornet | Videos | 11 | May 26th, 2010 08:27 AM |
