Old November 7th, 2021, 09:24 PM   #1
Leonardo Lupo
How hot does your bike run?
I have no temp gauge, is your radiator too hot to touch for long after 3 mins of minutes of idle? What is an easy way to see if my cooling system works without waiting to see if the bike smells like burning plastic?
Bringing Ninjas to The Outback!
Leonardo Lupo is offline   Reply With Quote
Old November 7th, 2021, 10:36 PM   #2
Idle is worse case scenario because of zero air-flow through radiator. Many decades ago when I did lots of commuting in city stop-n-go traffic, I'd have switch connected to radiator fan so I could manually turn on fan if I knew I'd be stopped for a while.
Get one of these and measure some numbers: https://www.amazon.com/dp/B08CXX63ZD/
Old November 7th, 2021, 10:43 PM   #3
Leonardo Lupo
Yep, my fan doesn't even turn on, I think it's because the gauge cluster has been removed?? I need to figure out the wiring for that and throw a switch in as well.
Old November 8th, 2021, 08:23 AM   #4
Leonardo Lupo
Made a short plug so that if I ever need fan permanently on I can unplug the "fan switch" at radiator and plug into the short. Mounted it on top of stock plug with cable tie. Trying to keep everything stock so will hold value when sold.
Old November 8th, 2021, 08:35 AM   #5
Cluster doesn't have anything to do with fan. Two completely different circuits that don't have anything to do with each other. Dash warning light is driven by sensor in thermostat housing.
Fan is driven by thermoswitch in radiator. Test fan thermoswitch in pot of water brought to boil. Note temperature when switch closes. Compare to number given in manual.
Does fan turn on when you short thermoswitch connector?
Old November 8th, 2021, 10:15 PM   #6
Leonardo Lupo
Yes and yes
Old November 8th, 2021, 11:49 PM   #7
At what temperature does fan thermoswitch connect contacts?
If it's within spec given in manual, just put everything back together and it should work like stock. Temperatures may hot have gotten hot enough to activate fan earlier. With infrared thermometer, you'd know for sure exactly what temperature coolant is in radiator around thermoswitch.
You can also get slightly lower-temp thermoswitch if you want.
Old November 9th, 2021, 12:43 AM   #8
Leonardo Lupo
Switch is very broken. I could. Would like to keep manual anyway as I might need to have manual control in 40C+ weather.
Old November 9th, 2021, 05:51 AM   #9
If the system is working properly, you never need to manually control the fan. It turns on when it's needed and off when it's not.
Old November 9th, 2021, 08:14 AM   #10
thedrewski86
thedrewski86's Avatar
I'm glad you said it. The manual fan switches bug me; they're great when you remember it, sucks when you forget. Kawasaki designed the system to work w/o rider intervention.
Don't think, look!
Old November 9th, 2021, 08:50 AM   #11
Manual switch should only be to supplement an already-working system. That is, everything is working fine in stock automatic condition if you leave switch off.
Manual switch should never ever be used to replace thermoswitch that's not working. At least replace thermoswitch with working one 1st so system works as designed.
Last futzed with by DannoXYZ; November 10th, 2021 at 07:23 AM.
Old November 9th, 2021, 08:53 PM   #12
Leonardo Lupo
Manua switch should never ever be used to replace thermoswitch that's not working. At least replace thermoswitch with working one 1st so system works as designed.
I agree, the switch should be fixed and manual control should only supplement the working engineered system. Ordering part now.
Old November 10th, 2021, 05:46 AM   #13
When would the properly working fan system need to be supplemented? If the coolant temperature gets high enough to turn on the fan, the fan runs. Any running of the fan more than that only overcools the engine, and that doesn't help anything.
Old November 22nd, 2021, 07:03 AM   #14
Leonardo Lupo
For example when the engine is off and I need to cool it down. It will be over 110 Fahrenheit. Another example would be if the switch breaks.
Old November 22nd, 2021, 07:13 AM   #15
When the engine is off, running the fan won't do much, since the engine's water pump is not running.
If the fan thermostat fails it just means you can't run the engine with the bike not moving, or moving very slowly, until you replace the switch. If that does happen and you really need to ride very slowly, as in heavy traffic, you can just take any scrap of wire and short the thermostat contacts together. The thermostats don't fail very often though. Mine have never given me any trouble on any motorcycle.
Old November 23rd, 2021, 03:51 AM   #16
Bob KellyIII
Retired motorcycle Mc.
Bob KellyIII's Avatar
I understand Leonardo's concern... being able to turn on the fan when idling at a stop would be a good thing ! just to keep the bike from over heating...
but I really don't think that is necessary .
if your going to stop turn the bike off ! don't keep it running to get hot ! ....
....if your making a desert machine where you know you'll be running is extreme heat, change the thermostat hook the fan to be on at all times with the key switch and pray it's enough to cool the beast before the pistons melt !
which is probably over kill.... but you could do it that way !
under normal riding conditions even HOT summers, the cooling system in it's stock form works great !
but 2 up in the outback in extreme heat, in deep sand ,...all bets are off !
Bob......
Old November 23rd, 2021, 07:35 AM   #17
Just run a good synthetic oil, and don't worry about high temps.
A water-cooled engine, with an operating cooling system, and synthetic oil can run extremely hot without any issues.
Conventional oil will breakdown from heat. Synthetic won't.
Engines like to be hot.
Old November 23rd, 2021, 07:59 AM   #18
For a liquid cooled engine to actually get too hot, the coolant has to boil. You'll see steam coming out. As Jay just said, engines like to be hot. Ring and cylinder wear is reduced at 200F+ and efficiency is higher.
Old November 23rd, 2021, 11:37 AM   #19
Yup, engine oil itself has to run above 100C to boil off all water condensation in crankcase. Thermal efficiency is better at higher-temps. Limit is materials durability.
Honda's working on some all-ceramic engine with no cooling system. Higher heat inside combustion-chamber and no losses to water-jacket. Would be awesome if it's 2-stroke as well, but Honda hates 2-strokes.
[motogp.com] - Viñales and Yamaha run hot on a cold Friday in Aragon Ninjette Newsbot Motorcycling News 0 October 16th, 2020 07:10 AM
[motorcyclistonline] - Hot Bike Tour 2016 and Hot Bike/Baggers Build-Off Dates Announ Ninjette Newsbot Motorcycling News 0 May 30th, 2016 12:40 PM
[motorcyclemonster] - Sardis, TN - Were Comin in Hot Poker Run Jun 7, 2014 Ninjette Newsbot Motorcycling News 0 April 22nd, 2014 02:50 PM
How hot does your bike run in hot weather greenaero 1986 - 2007 Ninja 250R Tech Talk 37 July 30th, 2012 05:05 PM
is it normal for ninja to run hot????? venmichaels 2008 - 2012 Ninja 250R Tech Talk 9 August 27th, 2011 11:17 PM
