Old November 1st, 2012, 05:12 PM   #641
lolibater
lolibater's Avatar
Motorcycle(s): 2005 ZX6R, 2011 Sprint GT
how do i go about syncing the throttle bodies?
"The enemy is fear. We think it is hate, but it is fear." - Gandhi
lolibater is offline   Reply With Quote
Old November 1st, 2012, 09:43 PM   #642
Take some data of the bike for an entire ride. Get it completely up to temp. Let it idle for about 30 seconds at the end of your ride so you have a good batch of data of a hot engine that is in closed loop operation.
Then, you'll want to play it back, and make sure the following variables are shown on your playback:
  • uLsb: voltage signal of lambda sensor #1
  • uLsb2: voltage signal of lambda sensor #2
  • fLc: factor of lambda control cyl #1
  • fLc2: factor of lambda control cyl #2
I believe that 450 mV is the reading from the O2 sensors that indicates a 14.7 mixture. The fLc is the fuel control output basically.
You want to narrow the window on the x axis to be just a small portion of your data, like 10 seconds of the idle at the end. Then you want to compare the O2 readings from each side. I forget which side of 450 mV is rich and which side is lean. You'll have to check through the ecotrons info that came on your ProCal disk. I know it's on there somewhere...
Basically, if one side is showing consistently richer or leaner Oxygen sensor readings that the other, adjust the air screw a bit on one side to even them out. Turning the air screw out (CCW) adds more air (leaning the mix), turning the air screw in (CW) decreases the amount of air (enriching the mix).
Old November 1st, 2012, 11:48 PM   #643
lolibater
lolibater's Avatar
Does a manometer come into play at all?
Old November 1st, 2012, 11:54 PM   #644
EMSRacer07
EMSRacer07's Avatar
Motorcycle(s): Ninja ex250 1990
you could do that with both of the vacumm lines on the TBs but u got to split the one side with the MAP sensor or it wont run right.
1990 250F. ex300 motor swap, 15/42 gearing, flush side markers, newgen intergrated front fairing, rear integrated turn signals, DB Touring Bubble, zx600 rear shock, Custom DanMoto Exhaust
EMSRacer07 is offline   Reply With Quote
Old November 2nd, 2012, 12:42 AM   #645
lolibater
lolibater's Avatar
I'm not sure I understand.
Old November 2nd, 2012, 01:11 AM   #646
EMSRacer07
EMSRacer07's Avatar
your trying to see how much each TB draws in vacuum. Hooking both TBs to a sync tool it will show you which one is drawing more vacuum so u can adjust them accordingly. but MAP sensor needs to be in there somewhere or it wont run the bike so you need to T it on one side.
Old November 2nd, 2012, 01:14 AM   #647
EMSRacer07
EMSRacer07's Avatar
read here and maybe it will help you
could do it the way chone said too but that might be more complicated than it should be.
Old November 2nd, 2012, 04:41 AM   #648
n4mwd
n4mwd's Avatar
I'm a little confused as to why it would even need syncing when there are two O2 sensors being used. Wouldn't they self tune independently?
My Ninja Blog
Old November 2nd, 2012, 06:52 AM   #649
flynjay
flynjay's Avatar
Motorcycle(s): 2007 Ninja 250 (sold), '06 Ninja 650R
Another way to do it is to look at the injector pulse width. Adjust the air bleeds to get them as close as possible. It will take a little while for the learning to catch up with the adjustment so be patient.
I would make an adjustment, then go for a quick ride. When you get back, let it idle for 30s or so and then take a look at the data. You should be able to slowly zero in on a balanced system.
Either open the side that has a shorter width or close the side that has a longer width. All depends on the idle you want to achieve.
The O2 sensors will ensure the mixtures are perfect for each side, but the sync will make sure each side is getting the same amount of air, and therefore making the same amount of power.
flynjay is offline   Reply With Quote
Old November 2nd, 2012, 07:30 AM   #650
n4mwd
n4mwd's Avatar
That makes sense, but the injector pulse width is controlled by the O2 sensors right? Sounds like the old fashioned manometer is the best way to go.
My Ninja Blog
Old November 2nd, 2012, 07:58 AM   #651
flynjay
flynjay's Avatar
That's the point. If the injector pulse width is the same on both sides after the system has corrected the AFR to 14.7, then the two sides are balanced.
Old November 2nd, 2012, 09:38 AM   #652
lgk
its pretty much the only way to do it unless each idle air circuit is controlled by individual servos and map sensors....
Old November 2nd, 2012, 04:56 PM   #653
lolibater
lolibater's Avatar
That makes sense. Thanks guys.
The bike isn't even starting now, out of the blue. It just cranks and cranks, like it used to when I had the ECT sensor in the wrong spot.
I've left it off for about 3 hours, and it still will not start.
Old November 2nd, 2012, 05:01 PM   #654
EMSRacer07
EMSRacer07's Avatar
make sure there are no air bubbles in the fuel pump, meaning its letting air bubbles out. Try with cracking the throttle a bit before starting it.
Any check engine lights?
Old November 2nd, 2012, 05:11 PM   #655
lolibater
lolibater's Avatar
no check engine lights.
I tried with throttle closed, open, and partially open. None worked.
How can I make sure there are no bubbles in the pump?
Old November 2nd, 2012, 05:13 PM   #656
EMSRacer07
EMSRacer07's Avatar
just looking at the bubble line and making sure bubbles are coming through. but to me sounds like a fuel issue maybe air in the line or air in the fuel pump.
Where do you have the fuel pump and how is it orientated?
Old November 2nd, 2012, 05:41 PM   #657
lolibater
lolibater's Avatar
the fuel pump is under where the tank mounts to the bracket on the frame. It started fine yesterday in this same orientation.
I double checked to make sure the components were in the right order of height.
Trying to bump start it, it sounds like it's almost going to start, but it won't probably becuase I live in the flattest area ever.
Old November 3rd, 2012, 08:49 AM   #658
Not complicated.
hook up computer.
Go for ride.
Before shutting off, let idle 30 seconds in driveway.
Check out the data.
Adjust air screws accordingly, 1 screw at a time.
Old November 3rd, 2012, 11:30 AM   #659
lolibater
lolibater's Avatar
All of my fuel lines are solid black, so I can't see if here are bubbles or not. I'm thinking that's what it is, because last time when I was having all those issues, my friend came to bleed the air out and it literally fired right up after that.
I wish I had watched how he did it. Any suggestions guys?
Old November 3rd, 2012, 11:49 AM   #660
How do you keep getting so much air in your lines? Do you need to re-route a little so the bubble line from the pump flows upward better to carry bubbles out? I've never had this issue.
I would just try cycling the key on and off a few times and letting the pump run to try and get as much air out as possible. Other than that, idk because I've never had air bubble issues.
Old November 3rd, 2012, 11:52 AM   #661
lolibater
lolibater's Avatar
I wonder if the quick disconnects are the culprits. the pump is mounted with the spade connectors on the downwards slope. Is that how yours is?
All I remember from last time was people telling me over and over that the pump does it itself, or to cycle the key on and off, and it never worked. My friend came over and manually bled it somehow and it worked after that.
Old November 3rd, 2012, 11:55 AM   #662
Yes, my pump is mounted with the power connectors/fuel output on the downhill side, and the intake/bubble line on the uphill side. It's kinda cool to watch the bubble line while the bike runs.
Old November 3rd, 2012, 11:57 AM   #663
lolibater
lolibater's Avatar
I just don't get it. It was working fine the other day. I took the tank off to install a bolt somewhere, and when I put the tank back on it hasn't started since.
Old November 3rd, 2012, 12:29 PM   #664
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
There's the problem, stop touching the bike
AFM #676
Supersports are for n00bs
Old November 3rd, 2012, 12:31 PM   #665
lolibater
lolibater's Avatar
I figured out how to bleed it and it sounded like it wanted to start after that , but then it stopped. After that I got a MIL light saying problem with MAP sensor. I took it ff, and it smelled a little like gas so I put it out in the sun.
Old November 3rd, 2012, 12:36 PM   #666
Try a longer piece of hose on the MAP sensor
Old November 3rd, 2012, 12:49 PM   #667
n4mwd
n4mwd's Avatar
I'm wondering the same thing.
When you turn off the engine, the fuel flow is stopped and heat from the engine can cause the gas to bubble. The only thing I can suggest is to put more of a downward angle on the pump. The outlet must be as low as possible and lower than the lowest part of the tank.
I think you said your quick disconnects are dual shutoffs - meaning that both sides are cut off when disconnected. I'm wondering if you replaced the return with a single shutoff if that would help.
In any event, I would disconnect the return disconnect and see if you can jam a nail or something in there to let the gas free flow into a gas can or something. That should get the bubbles past the pump.
My Ninja Blog
Old November 3rd, 2012, 12:54 PM   #668
lolibater
lolibater's Avatar
I let the map sensor dry and the error code is gone now. I cranked it for about 30 seconds, and it fired a few times, but did not start. It backfired once too. The noises it's making sound kinda awful lol. I'm sure my battery will die soon.
Old November 3rd, 2012, 12:57 PM   #669
n4mwd
n4mwd's Avatar
Does the new TB still have the problem with the MAP sensor filling with gasoline? I know that loli is using the old one.
My Ninja Blog
Old November 3rd, 2012, 12:59 PM   #670
n4mwd
n4mwd's Avatar
You need to hook up procal and find out if the MAP sensor is still working. Sometimes drying them out fixes them, sometimes not. The only way to be sure is to look at the data.
EDIT: The MAP sensor is a critical sensor and the engine will not run without it.
EDIT2: Didn't Matt send you a new one?
My Ninja Blog
Old November 3rd, 2012, 01:00 PM   #671
lolibater
lolibater's Avatar
There is no more mil light and when i run diagnostics it says "system working properly". I'll try to crank it fro 30 seconds again to see if it will start.
Old November 3rd, 2012, 01:04 PM   #672
n4mwd
n4mwd's Avatar
Don't crank any more unless you are logging data for Matt. You'll just run the battery down. One thing about EFI is that it generally either works or it doesn't. Time to send Matt the log file.
My Ninja Blog
Old November 3rd, 2012, 01:06 PM   #673
I honestly have no idea. I haven't had issue with the bike running, so I would assume that does not have that issue?
Old November 3rd, 2012, 01:09 PM   #674
n4mwd
n4mwd's Avatar
How long is your MAP tube?
My Ninja Blog
Old November 3rd, 2012, 01:18 PM   #675
lolibater
lolibater's Avatar
Yeah it just backfired a few times but no starting. I'll stop cranking it now and leave it off. No MIL light anymore. My Fuel Pressure Regulator is leaking some kind of brown stuff. Is that normal?
Old November 3rd, 2012, 01:19 PM   #676
lolibater
lolibater's Avatar
About 2 inches. Same length as the plugged tube on the other runner or w/e it's called.
Old November 3rd, 2012, 01:23 PM   #677
lolibater
lolibater's Avatar
let me know if this helps
Old November 3rd, 2012, 01:36 PM   #678
n4mwd
n4mwd's Avatar
Well for sure you have the new TB and not the old. Did you change it out or is that the one that came with the bike?
The fuel pump does look a bit high to me.
Just askin, but when you crank, you have the tank on there and everything hooked up right?
My Ninja Blog
Old November 3rd, 2012, 01:39 PM   #679
lolibater
lolibater's Avatar
Yes the tank is on when i try to start. This all came with the bike.
It's backfiring but not starting. Too lean? Fuel pressure regulator is leaking. How can I wipe the ECU to be more close to the parts I currently have. I don't think "learn mode" is going to fix this.
Old November 3rd, 2012, 01:39 PM   #680
@n4mwd if I had to guess, mine's about 2 inches.
@lolibater that is organized funny. I organized mine differently.
On mine:
The fuel line/filter goes down the left side of the bike to the pump. The pump pressurizes the fuel towards the TB on the right side. The pressurized fuel feeds the injectors from the right TB to the left TB. The pressure regulator is on the left side after the left TB, and the fuel return line meets up with the bubble line on the left.
It looks like this from the left:
It seems like you have a lot of tubing. I'm not sure if that makes any difference or not, just an observation.
ecotrons tech questions. bigbadbob 1986 - 2007 Ninja 250R Tech Talk 1 April 17th, 2015 10:50 AM
Ecotrons map swarfman64 2008 - 2012 Ninja 250R Tech Talk 2 January 15th, 2015 06:09 AM
WTB:Ecotrons petcock crimsondragon Items Wanted 2 September 21st, 2014 06:54 AM
Ecotrons kit garth285 Items Wanted 0 June 17th, 2014 05:09 PM
Ecotrons Gen2 FI Kit Install Terminal 1986 - 2007 Ninja 250R Tech Talk 85 October 15th, 2012 02:02 PM
