Old October 31st, 2012, 06:00 PM   #1
W.Roworth
W.Roworth's Avatar
Sprocket Change
Im looking at slightly increasing the length of my gearing ratio and have heard a sprocket change is the best method....
I am completely in the dark about it though and need advice. Do I change front or rear? What amount of teeth would be best and what changes would occur?
Carpe Diem, then the throttle
W.Roworth is offline   Reply With Quote
Old October 31st, 2012, 06:14 PM   #2
Info in this thread:
DIY- Sprocket Swap
It's just math. The taller the gearing, the lower the engine revs at the same road speed. The shorter the gearing, the higher the engine revs at the same road speed. To go taller, you add teeth to the front sprocket, or subtract teeth from the rear sprocket. To go shorter, you subtract teeth from the front sprocket, or add teeth to the rear sprocket. To figure out how much of a change it would make, just find the ratio between front/rear for both setups, and compare. www.gearingcommander.com lets you plug in all sorts of parameters, and shows you the exact differences you will see in revs and/or speed.
Most people who do change sprockets on the ninjette go taller on the gearing to make the bike slightly calmer on the highway (less revs). Easiest way to do this is to swap out the front 14-tooth sprocket with a replacement 15-tooth sprocket.
There are a ton of threads that basically say exactly this, in many different ways. Search for threads with "sprocket" in the title, and there's more reading material than even the most ardent sprocket specialist needs.
Old October 31st, 2012, 10:54 PM   #3
W.Roworth
W.Roworth's Avatar
call me lazy but how many teeth are on the rear cog? what kind of revs would adding one tooth to the front change at 110kph? Im lookin to hear from people who have done it and what they think of the change.
Old November 1st, 2012, 06:22 AM   #4
You're lazy.
Old November 1st, 2012, 06:38 AM   #5
psych0hans
psych0hans's Avatar
Originally Posted by Alex View Post
You're lazy.
Old November 1st, 2012, 07:15 AM   #6
flynjay
flynjay's Avatar
15 tooth front sprocket is about 1000 rpm lower in pretty much any gear. 5th gear is like the old 6th gear.
Old November 1st, 2012, 10:46 AM   #7
It's not quite that significant. It changes it by 14/15ths, exactly as one would expect. If it was at 15000 rpm, it would be at 14000 rpm after the change for a 1000 rpm drop. But if it was at 9000 rpm, a more typical highway cruising range, it goes down to about 8400 rpm. From 6000 rpm, it would drop to 5600. If the tach makes it look like it's dropping more, it's just a representation of tach inaccuracy. Gearingcommander is a particularly useful site to play with all of these numbers very quickly as you propose different sprocket sizes; no muss / no fuss.
Old November 4th, 2012, 04:28 PM   #8
az3200
az3200's Avatar
Motorcycle(s): 2002 Ninja 250
so i'm a noob, but if you're cruising on the highway and swapped the front sprocket for the 15 tooth, and are at about 1000rpm less....about how much faster will the top speed of the bike be? 10mph or so?
az3200 is offline   Reply With Quote
Old November 4th, 2012, 05:01 PM   #9
maybe 1. You're still making a whopping 26 hp. The only change made by gearing changes is how fast you'll be going when you get to the power band.
Old November 4th, 2012, 08:32 PM   #10
ChaoSS
Motorcycle(s): 2012 red 250 ninja
You will change the theoretical top speed, the speed at which the bike would go if you could redline it in 6th, but that is not real world.
My bike hasn't gone over about 94 indicated (on mine that's going to be just a hair over 90 actual speed) and that was no redline. Now, i'm a big guy, and I have saddle bags that add to the wind reaistance, and really hadn't perfected my tuck. That being said I wouldn't excpect much more out of a stock ninjette.
I have a 15 tooth front on mine, for highway driving, keeps the rpms down a bit, and i'm thinking about a smaller rear, or a bigger tire. It isn't really like being in the next higher gear but when I first did it it did feel that,way
ChaoSS is offline   Reply With Quote
Old November 5th, 2012, 08:03 PM   #11
flynjay
flynjay's Avatar
If our bikes were gearing limited, yes the top speed would increase. But, alas we are power limited.
Sprocket Change? csmith12 2008 - 2012 Ninja 250R Tech Talk 17 April 9th, 2014 03:20 PM
Sprocket size change mrudich 1986 - 2007 Ninja 250R Tech Talk 1 April 2nd, 2014 06:27 AM
15 41 sprocket change gogiburn 1986 - 2007 Ninja 250R Tech Talk 4 September 22nd, 2012 02:05 PM
sprocket change sacreyc Help 3 July 12th, 2011 05:11 PM
Rear sprocket change red 2008 - 2012 Ninja 250R Tech Talk 16 November 20th, 2010 07:30 AM
