Old March 6th, 2023, 10:35 PM   #1
Ramolias
Motorcycle(s): 2011 ninja 250
Angry Bad acceleration in 5th/6th gear
I'm new to this thread but I bought this 2011 ninja 250 from someone awhile back but they didn't take good care of it and let it sit, ive cleaned the carbs and change the plugs and oil and oil filter and tuned the carbs but even then whenver im in 5th or 6th gear the rpms hardly move up even with the throttle fully open and im barely getting past 50mph ive only hit 60 twice but that was downhill but Idk it has a leo Vince Exaust idk if that could be the cause ive tried putting a bigger back sprocket on so it went from a 45t to a 47t slight improvement but not much. Has anyone else had this problem or any idea how to fix it?
Ramolias is offline   Reply With Quote
Old March 7th, 2023, 05:45 AM   #2
Hello Elias, welcome! I assume that both exhaust pipes are getting hot equally quickly when you start it. If both cylinders are firing, it's almost certain that the carburetors are not fully clean. This will give you an idea of what needs to be cleaned: https://n4mwd.blogspot.com/2013/10/s...-passages.html
If at some point you decide to find a pro to restore them to new condition, the man is "Ducatiman" on this board.
Old March 7th, 2023, 09:41 AM   #3
Ramolias
Yeah i checked it and I don't think I was that thorough with it, ill try to pickup some carb cleaner and some wire on my way back from work and try it tomorrow, thank you
Old March 7th, 2023, 08:03 PM   #4
Barely hitting 50 mph on level ground is way down on power. It's possible there is a carb issue, and it's also possible that it's only firing on one cylinder. You can check that by using one of those infrared temp guns right on the two exhaust pipes coming out of the the cylinder head right after you've been riding it for a few minutes. The temps of both should be quite similar if both cylinders are behaving.
Old March 8th, 2023, 03:11 PM   #5
Ramolias
Talking
I followed and cleaned what the website said in the link and the bike runs amazing now so I guess my friends brother didn't clean it too well but i was able to hit 70+ so now im slightly scared but thank you, ive been trying to figure it out since January and thought thays just how the bike is
Old March 8th, 2023, 03:55 PM   #6
thedrewski86
thedrewski86's Avatar
Congrats Elias! My 2005 tops out at about 94mph per my GPS... they'll move with enough open road and a little tailwind
MoVal, eh? I'm in RivCo as well: Murrieta, but I work in Hemet. Maybe I'll see you around.
Don't think, look!
Old April 14th, 2023, 09:33 PM   #7
Bob KellyIII
Retired motorcycle Mc.
Bob KellyIII's Avatar
hehe Yah... my first thought was it wasn't running on both cylinders !
if that happens it is slow on acceleration ...really slow, and top speed is around 50mph ! the odd thing is it doesn't sound like it's running only on 1 cylinder
until you hear it running on 2 cylinders !!!!! there is no comparison but if you've never heard it running on 2 you wouldn't know ! one of the disadvantages of buying a used bike ! You don't know !
when I first got my 250R running it sounded ok to me but it wasn't running right ...and I knew that... but I took it for a short ride around the block anyway
and when I shifted into 3rd gear the 2nd cylinder kicked in and it took off like a rocket ! then I could tell the thing was running on 1 cylinder near idle....
...3 attempts at carb cleaning later and I finally got it to run fairly decent.
they are the most difficult carbs to clean I have ever came across !
.... this little bike is a rocket ! it goes like a 650 of my youth used to ! don't let the 250cc size fool you it's a big bike in a small package ! and it WILL get you into trouble !
....Ride safe !
Bob........
2008 250R: Between 5th & 6th gear arthury 2008 - 2012 Ninja 250R Tech Talk 9 June 21st, 2020 02:11 PM
Tail of the Dragon/Deal's Gap October 5th-6th gantt Group Rides and Local Events 41 October 9th, 2018 02:40 AM
[motorcycledaily.com] - Davies 5th and Melandri 6th in Race 1 at Magny Cours with the Ninjette Newsbot Motorcycling News 0 October 2nd, 2018 06:31 AM
[crash.net - MotoGP] - HRC: 1000cc only unleashed in 5th and 6th gears Ninjette Newsbot Motorcycling News 0 February 7th, 2012 01:10 AM
[roadracingworld.com] - Americans Hayden And Spies 5th And 6th In First MotoGP Practi Ninjette Newsbot Motorcycling News 0 April 9th, 2010 03:20 PM
